socal1904 Samba Member
Posted: Sat Jun 22, 2019 8:29 am Post subject: It died! |
Was on my way to the show, hit a bump on the freeway, and she then died, able to pull over and get her off the freeway. No loose wires, headlights come on, radio comes on but no crank, no reaction from ignition. Everything seems to be in order, waiting on tow, any ideas?
Thanks |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31266 Location: Hot Arizona
Posted: Sat Jun 22, 2019 8:35 am Post subject: Re: It died! |
socal1904 wrote: |
Thanks |
Check for positive voltage getting to the ignition switch. Positive voltage goes first to headlight switch on these models.
Also check battery cables. Most likely this is not complicated or involved. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
rcroane Samba Member
Joined: January 03, 2013 Posts: 1996 Location: Springfield, Virginia
Posted: Sat Jun 22, 2019 9:21 am Post subject: Re: It died! |
Check wires at starter. Mine have been loose before, resulting in same symptoms. _________________ '65 Sunroof Bug |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13842 Location: White Mountains Arizona
Posted: Sat Jun 22, 2019 10:57 am Post subject: Re: It died! |
Somehow or other you lost the 12v at the coil. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Texasdoc Samba Member
Posted: Sat Jun 22, 2019 11:20 am Post subject: Re: It died! |
Not sure about the beetle specifically, but sudden/instant death is usually electrical. Slow or gradual is usually fuel. Loud noises are mechanical. |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5305 Location: Central Florida
Posted: Sat Jun 22, 2019 12:33 pm Post subject: Re: It died! |
Check fuses? Always helps to carry some tools with you like a voltmeter. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
wimkever Samba Member
Joined: July 16, 2004 Posts: 411 Location: Holland (the Netherlands)
Posted: Sat Jun 22, 2019 1:16 pm Post subject: Re: It died! |
Sharp64 wrote: |
Check fuses? Always helps to carry some tools with you like a voltmeter. |
There are no fuses in the start circuit, nor in the ignition circuit. _________________ a beetle is like a cocker spaniel, always funny but sometimes not listening |
Posted: Sat Jun 22, 2019 3:42 pm Post subject: Re: It died! |
wimkever wrote: |
Sharp64 wrote: |
There are no fuses in the start circuit, nor in the ignition circuit. |
Hmm. Yeah brain fart. Sorry. This did happen to me once and it was the coil wire falling off. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
Posted: Sat Jun 22, 2019 7:25 pm Post subject: Re: It died! |
Got it home, made sure nothing obvious had come loose, all wires in their place. Took out the ignition switch, made sure all the wires were securely on the terminals, scraped off some paint, screwed it back in, turned the key and she fired right up. Could it be the switch going bad? Maybe something else as well?
Thanks for all the feedback!! |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9663 Location: Oregon
Posted: Sat Jun 22, 2019 9:57 pm Post subject: Re: It died! |
socal1904 wrote: |
^^^^^^ This! Clean electrical connections are the key to properly functioning 50+yo VW's.
Glad you got it sorted. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Sat Jun 22, 2019 10:33 pm Post subject: Re: It died! |
Just wondering how it decided to go wrong, hadn’t had any issues with it before. Could hitting that bump at speed cause it to “loose” proper ground, or is it the switch going bad? Getting a new switch to have as a back up just in case. |
Posted: Sun Jun 23, 2019 5:02 am Post subject: Re: It died! |
In general, how do your connections look? It’s a boring, tedious job but after 50 years the connectors can build up quite a bit of oxidation. Several methods to do so but may help to take a weekend to go through all of your electrical connections and clean everything. Brighter lights, better starts etc will typically be the result. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
Posted: Wed Jun 26, 2019 8:36 pm Post subject: Re: It died! |
After a few successful starts it died again and the symptoms returned. Installed the new switch and seems to be all good now, fingers crossed!😁 |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5986 Location: Brooklyn
Posted: Thu Jun 27, 2019 9:10 am Post subject: Re: It died! |
battery cables clean and tight. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Fri Jun 28, 2019 11:37 am Post subject: Re: It died! |
All other connection "appear" to be in good order, new battery cables and ground straps. |
Posted: Mon Jul 29, 2019 9:38 pm Post subject: Re: It died! |
It happens every so often, turn the key and nothing, no lights on the dash, no crank. Check all connections, everything seems to be in order, try again and she starts. Could it be a bad coil? If it is, what would cause a newish coil to go wrong? New spark plugs, new “good”wires, new ground straps😖, frustrating! |
mukluk Samba Member
Joined: October 18, 2012 Posts: 6985 Location: Clyde, TX
Posted: Mon Jul 29, 2019 9:55 pm Post subject: Re: It died! |
socal1904 wrote: |
A bad coil wouldn't cause you to have no lights on the dash. Next time the problem presents itself, use a trouble light or volt meter to see where you're losing power between the battery and the ignition switch. Specifically, check both terminal ends of the red wire between the ignition switch and light switch, and the heavy red wire coming from the rear of the car into the light switch. Those three terminal locations should always have full battery power present, regardless of ignition switch position. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Mon Jul 29, 2019 9:57 pm Post subject: Re: It died! |
Suspect your ignition switch is going bad.
That's what it sounds like from here.
Good Luck.
socal1904 wrote: |
Buy Once, Cry Once!
mukluk Samba Member
Posted: Mon Jul 29, 2019 10:01 pm Post subject: Re: It died! |
67rustavenger wrote: |
Good Luck. |
He already replaced the switch, no change in symptoms. Taking that into account and the fact the radio works when the problem happens, it sounds like he's getting power up to the fuse block but intermittently losing power to the ignition switch. _________________ 1960 Ragtop w/Semaphores "Inga" |
H&HRacing Samba Member
Posted: Tue Jul 30, 2019 4:37 pm Post subject: Re: It died! |
Power comes from the back to the headlight switch and then to the ignition switch and fuse block, check that connection at the headlight switch. |
