sanhozeezee Samba Member
Joined: June 17, 2019 Posts: 171 Location: SF Bay Area
Posted: Fri Jun 21, 2019 11:15 pm Post subject: leaky RGB with a twist |
hey sambonians. new to samba but a long time lurker here. i finally pulled the trigger on a new to me 67 split. for the most part it’s well sorted but i noticed one thing that i’m stumped on. here goes...
passenger side RGB is leaking (i have the seal kit and will be tackling it this weekend). what started out as what looked like regular old tranny fluid/oil is now a red sludge like liquid. viscosity is light enough it could drip from appears to be the box but on the floor it’s semi raised and red in color.
anyone else experience this? i’ll try and snap some pics in the morning but thought i’d throw it out there in case anyone’s come across this before. |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12409 Location: Over 2002 posts deleted!
Posted: Sat Jun 22, 2019 5:05 am Post subject: Re: leaky RGB with a twist |
RED?
Could it be that someone put in transmission fluid in it instead of gear oil?
Still, a leak is a leak and will need to be taken care of. _________________ Some people are so busy being clever they don't have time enough to be wise. |
Posted: Sat Jun 22, 2019 5:48 am Post subject: Re: leaky RGB with a twist |
pyrOman wrote: |
RED?
Still, a leak is a leak and will need to be taken care of. |
not sure but doesn’t the trans feed oil to the RGB’s? i thought i read that somewhere. another thing is when i did see the first signs of leakage it appeared to be just oil. it leaked about the size of a silver dollar and the next day or so the red stuff started coming out. strange right?!?! |
Clara Samba Member
Posted: Sat Jun 22, 2019 8:05 am Post subject: Re: leaky RGB with a twist |
Yes, the center section and boxes are connected.
If someone put a red oil in the trans or RGBs, it will have red oil in it. Like Pyro said. I have not seen this, but odd things happen.
I would
Buy a gallon jug of proper gear oil. I use Sta Lube GL-4. And the pump.
Take the bus for a drive.
Drain the gear oil from boxes and center while warm and stirred up.
Fix the seal/leak.
Fill with new GL -4 gear oil. Fill boxes, put rear wheels on ground. Then fill center till it reaches the fill hole and starts oozing out. There will be some leftover from the gallon jug. |
Posted: Sat Jun 22, 2019 9:06 am Post subject: Re: leaky RGB with a twist |
thanks for the tip clara. appreciate the help
here are some pics of the box itself and the oil on a paper towel for contrast
busdaddy Samba Member
Posted: Sat Jun 22, 2019 9:14 am Post subject: Re: leaky RGB with a twist |
From here it looks like the red is iron oxide, the leak is washing the rust dust out of the slightly loose spring plate to box joint. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Posted: Sat Jun 22, 2019 9:29 am Post subject: Re: leaky RGB with a twist |
Is it leaking from one of the reduction box mounting bolts?
I think that means it's leaking from the freeze plug on the back of the late-model "big nut" reduction box so that might have to be pulled and re-sealed.
The seal kit is for the axle seal behind the brake drum.
Maybe someone else can chime in on whether it will leak from there if the freeze plug is leaking.
I would definitely plan on draining and replacing the transmission fluid but you might have a different leak on your hand than you think. _________________ How to Post Photos
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Sat Jun 22, 2019 9:34 am Post subject: Re: leaky RGB with a twist |
I’ll betcha the leak is connected with the shock mount which looks to have been welded back on. Looks like a complete tear down is in your future. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
edgood1 Samba Member
Joined: September 30, 2004 Posts: 2049 Location: Plymouth, MA
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Sat Jun 22, 2019 3:34 pm Post subject: Re: leaky RGB with a twist |
Might be 607 Almasol from Lubrication Engineers, Inc.:
https://duckduckgo.com/?q=607+Almasol&t=canonical&ia=web
Using that in a transaxle that we got rebuilt, but found that the new manufacture second gear syncro was so tight that it was impossible to downshift into second gear. As per advice of the transaxle rebuilder, changed to Almasol gear oil and second gear is much easier to shift into.
Definitely a red gear oil... _________________ In Stereo, Where Available!
big bus mike Samba Member
Posted: Sat Jun 22, 2019 3:53 pm Post subject: Re: leaky RGB with a twist |
Redline MT90 is also red in color. It was recommended by my transaxle guy. |
Posted: Sat Jun 22, 2019 5:50 pm Post subject: Re: leaky RGB with a twist |
edgood1 wrote: |
Is the forward spring plate mounting bolt welded to the spring plate??! Hard to tell from the pic but it looks suspect. |
I thought the leak was coming from there... which is weird
Unless it's a massive overflow of anti-seize instead _________________ How to Post Photos
Posted: Sun Jun 23, 2019 9:34 am Post subject: Re: leaky RGB with a twist |
thanks for the replies fellas. i tried i work on this yesterday only to be blocked by the infamous "big nut" 46mm axle nut. no one in the area sells a socket this big lol. i did manage to find a buddy who has one button't be able to get it til he gets back.
in the meantime, to answer some questions, the spring plate bolt isn't welded to the spring plate. i wired brushed it to get a better idea of what's under all the gunk. i think doing that may have disrupted the "gunk seal" and started the new red leak. the oil is coming from the RGB seal for sure. the bright side is the other side is bone dry! |
Posted: Sun Jun 23, 2019 10:03 am Post subject: Re: leaky RGB with a twist |
Get a 3/4" drive socket and a breaker bar to fit that.
If you use 1/2" drive, you will break it all too often.
Check out your local Fastenal store for such. See if they have the Proto "L" shaped breaker bar. That is the strongest style of breaker bar. _________________ In Stereo, Where Available! |
MrPolak Samba Member
Joined: June 20, 2004 Posts: 1337 Location: AG ,atnaltA
Posted: Sun Jun 23, 2019 3:40 pm Post subject: Re: leaky RGB with a twist |
Here is my method:
Posted: Sun Jun 23, 2019 5:35 pm Post subject: Re: leaky RGB with a twist |
not 100% sure but appears to be leaking from the axle seal. i hope it's not the gear box seal itself!
i borrowed a 46mm axle nut from a friend so i plan on tackling this tomorrow or tuesday. |
b-man Samba Member
Posted: Sun Jun 23, 2019 5:40 pm Post subject: Re: leaky RGB with a twist |
Snap-On 3/4” drive breaker bar and 46mm impact socket.
Had it for over 35 years now, it will never fail me.
_________________ 1956 Dove Blue Panel
1966 Velvet Green Single Cab
1957 L41 Black Oval Window Beetle |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3446 Location: San Diego
Posted: Sun Jun 23, 2019 5:44 pm Post subject: Re: leaky RGB with a twist |
Thats a nice tool, but you cant tighten the nut with the wheel off and off the ground, unless you use another method like above to secure the drum. Still better to tighten it with 4 wheels on the ground and ebrake set wheels blocked |
b-man Samba Member
Posted: Sun Jun 23, 2019 6:11 pm Post subject: Re: leaky RGB with a twist |
chrisflstf wrote: |
Understood, the picture is merely to showcase one of the proper tools to do the job. I did the final tightening with all 4 wheels on the ground.
I had stored that particular transaxle for nearly 30 years, eventually using it to refresh my 1956 panel. Happily I found out that before removing that transaxle from my ‘66 single cab and storing it I had the foresight to loosen both axle nuts, also with all 4 wheels on the ground. _________________ 1956 Dove Blue Panel
