raoul mitgong Samba Member
Joined: July 05, 2009 Posts: 1338 Location: Denver, CO
Posted: Wed Jun 19, 2019 9:37 am Post subject: Re: Lost keys in Las Vegas |
Paul,
Check this picture and let me know if you think this 7 could be an upside down 4?
If this is a 4, then the entire number is stamped upside down from all the others I've seen on the interwebs. If a 7, then the 8 and 3 are upside down...
Slider handle doesn't match so I'd need to get into the ignition or hatch from here.
-d
(Sorry for the major thread jack)
_________________ 84 Westy with a 2.1 (Groover)
86 Tintop Syncro (Crow)
86 Tintop Syncro to Westy project (Tom Servo)
91 Westy (Only the top 12 inches of this van (a burn victim)) |
erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
Posted: Wed Jun 19, 2019 2:55 pm Post subject: Re: Lost keys in Las Vegas |
raoul mitgong wrote: |
Paul,
-d
6378
is my guess. That's not a 4 but I see what you mean. If it had the vertical line, it'd be 1.5x as tall as the other numbers. |
Paulbeard Samba Member
Posted: Wed Jun 19, 2019 4:06 pm Post subject: Re: Lost keys in Las Vegas |
I vote for 6378 as well. Are all the others the same? _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3417 Location: OR & CA (Oregon/California)
Posted: Wed Jun 19, 2019 6:16 pm Post subject: Re: Lost keys in Las Vegas |
I'd say it 6878...
in this pic, the 8 is copied and moved on the top, another copy was tinted in purple, moved on top of the "3"and a bit on the right to show the matching.
Posted: Wed Jun 19, 2019 8:53 pm Post subject: Re: Lost keys in Las Vegas |
Here is an inverted 4 from another Vanagon handle. I'm 99% leaning 4. Who's got a confirmed 7?
jimf909 Samba Member
Posted: Wed Jun 19, 2019 9:50 pm Post subject: Re: Lost keys in Las Vegas |
0to60in6min wrote: |
I'd say it 6878...
This makes the most sense. 6878 means the only exception is that the first 8 didn't fully register. The others require shenanigans like the 3 being reversed and a 4 being unusually large.
6878 _________________ - Jim
Abscate wrote: |
erste Samba Member
Posted: Wed Jun 19, 2019 10:24 pm Post subject: Re: Lost keys in Las Vegas |
The 8 does line up (outer profile). Maybe the '8' stamp broke in the middle and couldn't register?
6878
I can't wait to check for this code when I get my vanagon back. |
Posted: Thu Jun 20, 2019 8:33 am Post subject: Re: Lost keys in Las Vegas |
if the 7 is an inverted 4 then the code should be read from right to left and would be 8439, and it's not the case.
in 6878, the number 7 looks very like as a 7 as in this pic showing 9237 (from a hatch lock)
Posted: Thu Jun 20, 2019 8:57 am Post subject: Re: Lost keys in Las Vegas |
That hatch 7 is the same height as all the other digits. My "7" sure seems smaller compared to the others. It is only $30/key but I should still dig into my hatch to make sure.
-d _________________ 84 Westy with a 2.1 (Groover)
Posted: Thu Jun 20, 2019 11:36 am Post subject: Re: Lost keys in Las Vegas |
I'd think that the section where the code was stamped is not flat - the center is lower than the top and bottom of code. The 6 and the 8 didn't register fully, same as the top and bottom of the 7. |
Posted: Thu Jun 20, 2019 12:03 pm Post subject: Re: Lost keys in Las Vegas |
I think we are all in agreement that it is f'ed up. In what way is the question.
Not sure if I should report back when I get a working key in case someone really wants my van for free.
Posted: Sat Jun 22, 2019 2:48 pm Post subject: Re: Lost keys in Las Vegas |
Just got my key from Steve's…looks and works fine, better looking than what I had (it has the plastic head surround where all my others are flat metal).
As I noted upthread (or perhaps via PM) the number and a photo of the botched stamp might be enough. Steve asked for a pic of a working key to verify so perhaps 2 or 3 good numbers and the photo will allow him to figure it out. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
— dhaavers |
Posted: Sat Jun 22, 2019 7:36 pm Post subject: Re: Lost keys in Las Vegas |
Paulbeard wrote: |
As I noted upthread (or perhaps via PM) the number and a photo of the botched stamp might be enough. Steve asked for a pic of a working key to verify so perhaps 2 or 3 good numbers and the photo will allow him to figure it out. |
Locksmiths are clever people. Steve probably had the key made before you provided him with any info. _________________ - Jim
Abscate wrote: |
Posted: Sat Jun 22, 2019 7:49 pm Post subject: Re: Lost keys in Las Vegas |
jimf909 wrote: |
Locksmiths are clever people. Steve probably had the key made before you provided him with any info. |
😱 _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
— dhaavers |
Posted: Mon Jun 24, 2019 4:09 pm Post subject: Re: Lost keys in Las Vegas |
It was a 4. _________________ 84 Westy with a 2.1 (Groover)
