markd89 Samba Member
Joined: November 04, 2005 Posts: 657 Location: Los Angeles
Posted: Tue Jun 25, 2019 6:32 pm Post subject: Pops out of second gear - hack that is working |
Bus transaxles are spendy to rebuild. I have a TDI engine from a 97 Passat and have more money and hassle invested in the Trans than I am willing to admit. I don't abuse the trans but don't baby it either.
A couple of months ago, it started popping out of second gear when driven very lightly (i.e. not decelerating, not accelerating). This would be usually when I am driving up to a stop sign or following someone moving slowly. It's intermittent and happens maybe 25% of the time in that scenario.
My bus mechanic guru told me that this has to be something internal and not in the linkage.
I found that I could prevent the problem by keeping a finger on the shifter, but that's just not convenient in all scenarios and sometimes I would forget.
I made the following ugliness with a piece of aluminum, 3 strong magnets and JB-Weld. It's positioned to grab on to the shifter when it's in the 2nd gear position. It provides just enough hold to prevent the pop out of gear issue and otherwise is transparent to the driving experience. A side-effect is that it will also grab when in reverse. That's not desired but not problematic either.
_________________ 78 TDI Sunroof Bus
Los Angeles |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Tue Jun 25, 2019 6:45 pm Post subject: Re: Pops out of second gear - hack that is working |
Start saving for another trans, or rebuild. Popping out of gear 99% of the time is the engagement drive teeth on the gear itself are worn. If that is the case, it will only get worse to the point popping out regardless of what pressure is attempting to hold it in gear. Another thing to consider is that while pressure is being put on the shifter, it is causing unnecessary wear on the 1st-2nd slider, and the shifting fork. |
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Tue Jun 25, 2019 7:06 pm Post subject: Re: Pops out of second gear - hack that is working |
on the bright side, your wiring is very well sorted _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Wed Jun 26, 2019 8:55 am Post subject: Re: Pops out of second gear - hack that is working |
Well, I will have to say I understand the wiring stuff.
I've cleaned mine up quite a bit from before, but my bus has felt like some kind of experiment for several years now, with originally just trying to get it on the road and then making things nicer and more clean and all that along the way. So I get it.
Haven't you already had your trans rebuilt once to go with the TDI?
Only time will tell if my newly rebuilt trans will last this time around with the supposedly stronger gears and such. But I think it is becoming clear that the old 091s just don't like the TDI motors all that well. I'm hoping that this current rebuild will last long enough for some kind of breakthrough, such as somebody starting to manufacture all-new, tougher parts (or a whole new trans), or really great CV joints that will allow the flipped Passat trans to not have to mount so low, or something like that.
If it goes out again and there aren't any of these things by then, I may have to start thinking about other options altogether. Sorry this is going on! _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Thu Jun 27, 2019 9:01 am Post subject: Re: Pops out of second gear - hack that is working |
vwwestyman wrote: |
If it goes out again and there aren't any of these things by then, I may have to start thinking about other options altogether. Sorry this is going on! |
Yes, the wires are a bit of an embarassment. Most of that is not from the TDI but years of radios and extra gadgets. I'm sure I'll clean it up one day. Despite looks, everything is at least well fused.
The trans was rebuilt twice. The first time the shop put in new 3rd/4th and supposedly rebuilt everything else. After a short while there was a noise. The noise turned out to be a bearing that had not been replaced which was allowing one of the shafts to move a little and the gears to move in and out of mesh a little.
The second time, I got the bearing, changed 4th (from .70 to .77) which I now regret and got a 4 spider diff that I probably didn't need. I got to pay for both rebuilds and am trying to draw the line on more.
I don't know enough about transaxles to know if the torque increase is what damaged 2nd. I shared your concern of whether the 091 is really viable long term, but the Vanagon people seem to be OK with TDIs and the only difference between the 091 and 094 is supposed to be the reverse gear. That gives me some hope.
I did get lightly rear-ended on the 405 shortly before this happened, so thinking that might have damaged something.
I'm also hoping to make it last until there's a better option for transaxles or until there's lots of Tesla batteries available cheaply and then maybe I'll convert to electric.
Mark _________________ 78 TDI Sunroof Bus
Los Angeles |
Posted: Thu Jun 27, 2019 9:12 am Post subject: Re: Pops out of second gear - hack that is working |
Globespotter wrote: |
I do have to give points for ingenuity.
Thanks. This was really why I posted it.
I know it's not the right way, but sometimes a hack to buy some time is what we need. _________________ 78 TDI Sunroof Bus
Los Angeles |
[email protected] wrote: |
Thanks much. I appreciate the info! _________________ 78 TDI Sunroof Bus
Los Angeles |
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1858 Location: anchor pt. alaska
Posted: Fri Jun 28, 2019 7:28 am Post subject: Re: Pops out of second gear - hack that is working |
I wouldnt go so far as to say vanagon people do ok with TDIs. Theres been plenty of trans destruction over there too . No personal experience, but i read about it. |
sodbuster Samba Member
Joined: August 08, 2004 Posts: 1086 Location: wherever my baywindow takes me.
Posted: Fri Jun 28, 2019 8:43 am Post subject: Re: Pops out of second gear - hack that is working |
Do this if you must but save your pennies. There will come a point (and it may come sooner than you think.) that your "hack" will no longer cut it. The longer you wait and the worse it gets, (and it will get worse.) it will only cost more money. |
