Plastic VW manufactured parcel tray installation question
fifthcenturycheese Premium Member
fifthcenturycheese is offline
PostPosted: Tue Jun 25, 2019 12:31 pm    Post subject: Plastic VW manufactured parcel tray installation question Reply with quote
I was wondering how the plastic VW parcel tray is installed without the firewall side slipping down onto the pedal assembly? I know there are the two tension screws to hold it in place on the sides. What holds it at the firewall, is there factory instructions for this? Thanks, Mike
FL-Frank
FL-Frank is offline
PostPosted: Tue Jun 25, 2019 3:01 pm    Post subject: Re: Plastic VW manufactured parcel tray installation question Reply with quote
I simply routed a ziptie through the tray and around the steering column tube. Holds the middle of the tray up and away from the pedals perfectly. Very Happy
“Tinker Toy” 1967 Savannah Beige Beetle Sedan...........Mostly Original Survivor
“Fritz” 1964 Gulf Blue Karmann Ghia Coupe...Complete Pan-Off Restoration SOLD
PostPosted: Tue Jun 25, 2019 4:57 pm    Post subject: Re: Plastic VW manufactured parcel tray installation question Reply with quote
I'm not sure about that tray but Yes, I've had other trays and they had a little piece of wire or cord that went around the steering column.
stale air
stale air is offline
PostPosted: Tue Jun 25, 2019 5:16 pm    Post subject: Re: Plastic VW manufactured parcel tray installation question Reply with quote
Im not sure what type of tray you are working with, but most of the ones that ive seen, VW, and like mine Kamei, there are only the 2 set screws on either side. Slid forward, it will sit on the the formed sheet metal ledge, making it prettty sturdy.
WANTED: Original VW Accessory front hood script
1958 L245 Type 113
1961 L87 Type 117
PostPosted: Tue Jun 25, 2019 11:02 pm    Post subject: Re: Plastic VW manufactured parcel tray installation question Reply with quote
This is the tray I will be installing.
glutamodo Premium Member
The Android
glutamodo is online now
PostPosted: Tue Jun 25, 2019 11:22 pm    Post subject: Re: Plastic VW manufactured parcel tray installation question Reply with quote
I transplanted a 1970 vintage parcel tray over to my 62... still seemed to be "silver beige" in color and it fit fine. It just wedges against the carpet I guess. Mine has never shifted.
I will say that I think the webbing might be closer to vinyl. Vinyl is a "plastic" I guess but of a different class.
Andy T.
-Volunteer Post-Production Sound Editor for Starship Excelsior - A Star Trek Fan Production.
panicman
panicman is offline
PostPosted: Wed Jun 26, 2019 8:32 am    Post subject: Re: Plastic VW manufactured parcel tray installation question Reply with quote
I have the Kamei parcel shelf as well and as Stale Air and Glutamodo’s, mine fits snugly against the firewall and does not tip or slip. It hasn’t moved at all that I can tell in almost 7 years.
1960 T1
PostPosted: Wed Jun 26, 2019 11:22 pm    Post subject: Re: Plastic VW manufactured parcel tray installation question Reply with quote
GOT IT! I really like this parcel tray better than the others. Here's what it turned out to look like.
hitest
hitest is offline
PostPosted: Thu Jun 27, 2019 10:21 am    Post subject: Re: Plastic VW manufactured parcel tray installation question Reply with quote
That is an amazing find these days- great job!
'62 L390 151, '62 L469 117, '63 L380 113, '65 L512 265, '65 L31 SO-42, '66 L360 251, '71 L12 113, '74 ORG 181
FU#5
