kbrower68 Samba Member
Joined: August 05, 2018 Posts: 27 Location: Altoona, PA
Posted: Fri Jun 21, 2019 1:37 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Fuse is blown. What amp? |
GArBa Samba Member
Joined: January 27, 2014 Posts: 2105 Location: Milano, Italy
Posted: Mon Jun 24, 2019 3:14 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
what amperage is the blown fuse? stock #8 fuse is 8A (white), usually when wired to the roof motor it was switched with a 16A (red) or even a 25A (blue). _________________ cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v |
hopkin Samba Member
Joined: June 25, 2012 Posts: 2480 Location: Ottawa, Ontario
Posted: Mon Jun 24, 2019 11:30 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
I have an 8 Amp for fuse #8 (with the roof). It did blow once, about 6 years ago, no problems since. _________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
1991 Honda Civic (Original Owner)
1996 'Open Air' Mexican Beetle (current)
2015 Golf (current)
2017 Dune Edition (daughter's car) |
Antonio Trejo VW Parts Dealer
Joined: December 17, 2003 Posts: 937 Location: Mexico City
SizzleT Samba Member
Joined: May 10, 2018 Posts: 7 Location: Cookeville, TN United States
Posted: Tue Jun 25, 2019 9:30 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Okay I have a couple issues and I'm scratching my head:
I have a stumble that seems to be related to throttle position and load, but is intermittent and only at lower RPM's. Vacuum signal to ECU??
it also takes two or three seconds after going wide open throttle to feel the power come in, almost like it throws the timing to it all at once.
I can't help but the think these are related. If anyone has had these issues any information would be fantastic as it's about to irritate me beyond explanation. _________________ '74 Super
'74 Ghia
'01 MexiBeetle |
Bruce Samba Member
Posted: Tue Jun 25, 2019 5:55 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
radstude wrote: |
My right side brake light, keeps shorting out the filament. I've tried regular bulb heavy duty bulbs, & led. I've been changing bulbs about every two weeks. I cannot find a problem with the bulb socket or the wiring. Has anyone else, had this problem? |
Check your charge voltage from your alternator. If the regulator is bad, the voltage will go too high and pop your bulbs. _________________
GArBa Samba Member
Posted: Tue Jun 25, 2019 11:50 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
SizzleT wrote: |
Vacuum signal to ECU?? |
it's a possibility for sure. have you checked the green line? it may have come loose inside the ECU box.
It may also be the manifold pressure sensor, since the oily vapor recovery goes into the airbox unfiltered sometimes they get contaminated from oil mist and go bad. _________________ cars:
'97 type 1 1600i
'22 type C1 T-Cross
moped:
Posted: Wed Jun 26, 2019 6:59 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
GArBa,
I looked at the vacuum line, and it's frayed between the intake manifold and the green line. I'll replace with a new one to see if that helps _________________ '74 Super
'74 Ghia
'01 MexiBeetle |
Sotobaggins Samba Member
Joined: February 23, 2016 Posts: 264 Location: Orlando, FL United States
Posted: Mon Jul 01, 2019 10:15 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
I am grateful that my Mexi is working greatly and during the last escapade. This is what I went through Thanks VW Spotting
I PUT THE THINGAMABOB INSIDE THE WHATCHAMACALLIT TURNED THE DOOHICKEY AND THE WITEVERITIS STILL DOESN'T WORK
ANY IDEAS
Just remember even though you think you might not need it LEAVE IT ON THE CAR IF RUNNING because it might be there for a reason and if not if it falls off you did not need it ... _________________ 2001 Ultima Clasico Edicion Mexibeetle
2003 Black GTI 1.8T |
plagos_g Samba Member
Joined: May 25, 2015 Posts: 82 Location: Santiago, Chile
Posted: Mon Jul 08, 2019 5:56 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Big question.
If a car was running "fine" (normal idle, no fault codes), and after basic settings the idle goes into see saw (as in it doesn't hold a stable value). What happened or possibly happened? Anyone experienced such a thing?
What can I do to correct it? _________________ 1998 Volkswagen Sedan (MexiBeetle, daily drive)
1987 Volkswagen Kombi (crew cab, br) |
GArBa Samba Member
Posted: Wed Jul 10, 2019 5:49 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
no errors after basic settings? if the car was fine in the first place, why you did basic settings? _________________ cars:
'97 type 1 1600i
'22 type C1 T-Cross
moped:
Posted: Wed Jul 10, 2019 6:10 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Well, it was 'fine', as in it worked when I got there. The problem is the wiring is not in good condition and lots of intermittent faults were present. The question is, now that I made that mistake, how can be fixed, or why did it happen? I'm still learning how it all works, and have been checking 1600I.de too.
Also, the throttle body has a modified screw for the tps, if that's anything suspicious.
Also, lesson learned. If it ain't broken don't fix it... _________________ 1998 Volkswagen Sedan (MexiBeetle, daily drive)
GArBa Samba Member
Posted: Wed Jul 10, 2019 8:22 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
erase the fault codes, run the car for a while as it is and report the codes that show up. it may be as simple as a bad relay 30. _________________ cars:
'97 type 1 1600i
'22 type C1 T-Cross
moped:
antonb Samba Member
Joined: December 08, 2016 Posts: 239 Location: Moscow/Russia
Posted: Fri Jul 12, 2019 6:56 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Hi everyone!
On the Russia Day 12.06.19 it was succeeded to visit in one afternoon annual action "Avtostrada" in city Tula, it was pleasant the organizations and location.
This time I managed to organize the biggest for all history of festival quantity of VW aircooled mafia.
_________________ VW Käfer (Vocho), First registration date in Deutschland: 14/09/1984, Engine 1200.
(Hecho en México) |
cee-sar Samba Member
Posted: Tue Jul 16, 2019 11:13 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Anyone here using the 17" 911 Alloy rims on 75 Brazilian Beetle? |
hopkin Samba Member
Posted: Wed Jul 17, 2019 8:48 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
It's been a while since I posted some pics of my car, here a couple of shadow pics I took tonight heading to and from a Cruise Night.
Gerrelt:
The mini convertible beside my car is a '98, brought over to Canada from the Netherlands:
1974 SunBug (past)
1972 914 (past)
2015 Golf (current)
hopkin Samba Member
Posted: Mon Jul 22, 2019 7:59 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
My new gas tank just arrived, VW of Mexico brand:
The question of the day, does anyone know if this filter will fit?
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111209147A _________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
2015 Golf (current)
hopkin Samba Member
Posted: Tue Jul 23, 2019 7:48 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
I did a little update on my car this evening. The side markers installed in the UK were cheap and the clear lens has been getting cloudy over the past couple of years.
It took some searching as I had no part numbers but I was able to find Hella replacements that are the same size. The Hella light assembly is different so I replaced the entire assembly including the provided wiring pigtail.
The existing wiring was poorly done, a taped connection for the wires on each side [where they tapped into each side's circuit] and a screw terminal as hidden behind the radio bracket (and covered in tape). I was able to use the pigtail that came with the new light assembly, and clean up the wiring with proper terminals and connectors.
Here is the old cloudy lens:
Nice new clear Hella lens:
The wires for the right side marker were about 3-6 inches too short so they added this terminal to extend the wires :
1974 SunBug (past)
1972 914 (past)
2015 Golf (current)
AlmostHeavenWV_VW Samba Member
Posted: Mon Jul 29, 2019 7:53 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Wanted to share the two Mexi-beetles I saw at a car show a few weeks back:
2 Mexican beetles (1999 Mexico Taxi on left, 2003 on right) The Mexican taxi's interior had a very......well, 'unique' smell....that would make you feel realllly relaxed if you sat in it long enough
_________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
