Official Mexican / Brazilian Beetles - All years
Page: Previous  1, 2, 3 ... 97, 98, 99, 100, 101, 102  Next
kbrower68
kbrower68 is offline
PostPosted: Fri Jun 21, 2019 1:37 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
Fuse is blown. What amp?
GArBa
GArBa is offline
PostPosted: Mon Jun 24, 2019 3:14 am    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
what amperage is the blown fuse? stock #8 fuse is 8A (white), usually when wired to the roof motor it was switched with a 16A (red) or even a 25A (blue).
cars:
'97 type 1 1600i
'14 type AA Seat Mii
moped:
'82 Benelli Magnum 3v
hopkin Premium Member
hopkin is offline
PostPosted: Mon Jun 24, 2019 11:30 am    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
I have an 8 Amp for fuse #8 (with the roof). It did blow once, about 6 years ago, no problems since.
1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
1996 'Open Air' Mexican Beetle (current)
Antonio Trejo Premium Member
VW Parts Dealer
Antonio Trejo is offline
PostPosted: Mon Jun 24, 2019 2:40 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
After 9 years in use, I remplaced today the Engine Temperature Sender (G27) in head at cylinder #4. (113 906 161 Z), this time I will try the sender made by Hella.
Parts VW
"From Volkswagen of Mexico factory..."
Genuine VW Sedan parts
Genuine VW Ultima Edition parts
Genuine VW Type 2 watercooled parts
SizzleT
SizzleT is offline
PostPosted: Tue Jun 25, 2019 9:30 am    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
Okay I have a couple issues and I'm scratching my head:
I have a stumble that seems to be related to throttle position and load, but is intermittent and only at lower RPM's. Vacuum signal to ECU??
it also takes two or three seconds after going wide open throttle to feel the power come in, almost like it throws the timing to it all at once.
I can't help but the think these are related. If anyone has had these issues any information would be fantastic as it's about to irritate me beyond explanation.
'74 Super
'74 Ghia
'01 MexiBeetle
Bruce
Bruce is offline
PostPosted: Tue Jun 25, 2019 5:55 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
radstude wrote:
My right side brake light, keeps shorting out the filament. I've tried regular bulb heavy duty bulbs, & led. I've been changing bulbs about every two weeks. I cannot find a problem with the bulb socket or the wiring. Has anyone else, had this problem?
Check your charge voltage from your alternator. If the regulator is bad, the voltage will go too high and pop your bulbs.
GArBa
GArBa is offline
PostPosted: Tue Jun 25, 2019 11:50 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
it's a possibility for sure. have you checked the green line? it may have come loose inside the ECU box.
It may also be the manifold pressure sensor, since the oily vapor recovery goes into the airbox unfiltered sometimes they get contaminated from oil mist and go bad.
cars:
'97 type 1 1600i
moped:
SizzleT
SizzleT is offline
PostPosted: Wed Jun 26, 2019 6:59 am    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
GArBa,
I looked at the vacuum line, and it's frayed between the intake manifold and the green line. I'll replace with a new one to see if that helps
'74 Super
'74 Ghia
'01 MexiBeetle
Sotobaggins
Sotobaggins is offline
PostPosted: Mon Jul 01, 2019 9:58 am    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
Just saw this and very interesting
Enjoy https://www.youtube.com/watch?v=epRBdo7oPUY&fb...zxusiGNk0c
2001 Ultima Clasico Edicion Mexibeetle
2003 Black GTI 1.8T
Sotobaggins
PostPosted: Mon Jul 01, 2019 10:15 am    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
I am grateful that my Mexi is working greatly and during the last escapade. This is what I went through Thanks VW Spotting
I PUT THE THINGAMABOB INSIDE THE WHATCHAMACALLIT TURNED THE DOOHICKEY AND THE WITEVERITIS STILL DOESN'T WORK
ANY IDEAS
Just remember even though you think you might not need it LEAVE IT ON THE CAR IF RUNNING because it might be there for a reason and if not if it falls off you did not need it ...
2003 Black GTI 1.8T
plagos_g
plagos_g is offline
PostPosted: Mon Jul 08, 2019 5:56 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
Big question.
If a car was running "fine" (normal idle, no fault codes), and after basic settings the idle goes into see saw (as in it doesn't hold a stable value). What happened or possibly happened? Anyone experienced such a thing?
What can I do to correct it?
1998 Volkswagen Sedan (MexiBeetle, daily drive)
1987 Volkswagen Kombi (crew cab, br)
GArBa
GArBa is offline
PostPosted: Wed Jul 10, 2019 5:49 am    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
no errors after basic settings? if the car was fine in the first place, why you did basic settings?
cars:
'97 type 1 1600i
moped:
plagos_g
plagos_g is offline
PostPosted: Wed Jul 10, 2019 6:10 am    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
Well, it was 'fine', as in it worked when I got there. The problem is the wiring is not in good condition and lots of intermittent faults were present. The question is, now that I made that mistake, how can be fixed, or why did it happen? I'm still learning how it all works, and have been checking 1600I.de too.
Also, the throttle body has a modified screw for the tps, if that's anything suspicious.
Also, lesson learned. If it ain't broken don't fix it...
GArBa
GArBa is offline
PostPosted: Wed Jul 10, 2019 8:22 am    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
erase the fault codes, run the car for a while as it is and report the codes that show up. it may be as simple as a bad relay 30.
cars:
'97 type 1 1600i
moped:
antonb
antonb is offline
PostPosted: Fri Jul 12, 2019 6:56 am    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
Hi everyone!
On the Russia Day 12.06.19 it was succeeded to visit in one afternoon annual action "Avtostrada" in city Tula, it was pleasant the organizations and location.
This time I managed to organize the biggest for all history of festival quantity of VW aircooled mafia.
VW Käfer (Vocho), First registration date in Deutschland: 14/09/1984, Engine 1200.
(Hecho en México)
cee-sar
cee-sar is offline
PostPosted: Tue Jul 16, 2019 11:13 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
Anyone here using the 17" 911 Alloy rims on 75 Brazilian Beetle?
hopkin is offline
PostPosted: Wed Jul 17, 2019 8:48 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
It's been a while since I posted some pics of my car, here a couple of shadow pics I took tonight heading to and from a Cruise Night.
Gerrelt:
The mini convertible beside my car is a '98, brought over to Canada from the Netherlands:
1974 SunBug (past)
1972 914 (past)
hopkin is offline
PostPosted: Mon Jul 22, 2019 7:59 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
My new gas tank just arrived, VW of Mexico brand:
The question of the day, does anyone know if this filter will fit?
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111209147A
1974 SunBug (past)
1972 914 (past)
hopkin is offline
PostPosted: Tue Jul 23, 2019 7:48 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
I did a little update on my car this evening. The side markers installed in the UK were cheap and the clear lens has been getting cloudy over the past couple of years.
It took some searching as I had no part numbers but I was able to find Hella replacements that are the same size. The Hella light assembly is different so I replaced the entire assembly including the provided wiring pigtail.
The existing wiring was poorly done, a taped connection for the wires on each side [where they tapped into each side's circuit] and a screw terminal as hidden behind the radio bracket (and covered in tape). I was able to use the pigtail that came with the new light assembly, and clean up the wiring with proper terminals and connectors.
Here is the old cloudy lens:
Nice new clear Hella lens:
The wires for the right side marker were about 3-6 inches too short so they added this terminal to extend the wires Rolling Eyes :
1974 SunBug (past)
1972 914 (past)
AlmostHeavenWV_VW Premium Member
AlmostHeavenWV_VW is offline
PostPosted: Mon Jul 29, 2019 7:53 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
Wanted to share the two Mexi-beetles I saw at a car show a few weeks back:
2 Mexican beetles (1999 Mexico Taxi on left, 2003 on right) The Mexican taxi's interior had a very......well, 'unique' smell....that would make you feel realllly relaxed if you sat in it long enough Laughing
1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor
Page 98 of 102
