ATTN: Check Your Power Steering Switch Wiring!!!
Aryana
Aryana is offline
PostPosted: Sun Jan 07, 2018 1:30 pm    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
dhaavers wrote:
^^^ FWIW: I ran the leads for the "glow" fuse holder out through the grommet
for easy visual from <outside> the junction box if/when necessary... Cool
(Sorry - no pic) Embarassed
- Dave
That’s a good idea. Thanks.
kamzcab86
kamzcab86 is offline
PostPosted: Sun Jan 07, 2018 2:49 pm    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
Yeah, I saw that you two Daves did that and considered it. While easier to see if it blows, it's also seen every time the engine lid is off and my anal eyes couldn't tolerate that. Anxious
~Kamz Anxious
2016 Golf GTI S
dhaavers
dhaavers is offline
PostPosted: Sun Jan 07, 2018 5:17 pm    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
^^^ Do what you gotta do, Kam... Wink
- Dave
"The WonderVan"
Alaskaberrys Premium Member
Alaskaberrys is offline
PostPosted: Wed Jun 26, 2019 9:26 am    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
Yesterday I added insulation to the power steering contacts.
djkeev wrote:
I would suggest that everyone install a 7.5 amp inline fuse for the fuel injection / fuel pump circuit.
It is cheap insurance warding off potentially big problems.
Keep in mind that If the fuse does blow, your engine shuts off.
But for me, better that than a fire!
Dave
On my “to-do” list today!
Here’s the quality install I’m aiming for;
dhaavers wrote:
FWIW: Member farfromslow recently posted a pic of a perfect install:
- nice heat shrink on connectors...
- clear fuse holder (assume for "glows-when-it-blows" type fuse)...
- nothing more or less than needed...
Git 'r done! Cool
- Dave
SteveMc wrote:
And mark up your Bentley wiring diagram for when your van dies and you forgot you installed a fuse.
Seems like an excellent idea (thinking of future owner -me- lying in a puddle in the side of the road changing out a fuel pump - to no avail)
My question is this the proper spot in the Bentley - 97.124? Pretty sure it is, but would like to post the correct spot shown in farfromslow’s post above. ‘91 2.1l auto (Canadian)
crazyvwvanman
crazyvwvanman is offline
PostPosted: Wed Jun 26, 2019 9:37 am    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
No, that spot would only protect the fuel pump wiring.
The spot to protect everything is on a previous diagram page, where the current track 5 box next to your arrow leads to.
Look for a circle with P1 and a connector labeled T2m.
The fuse goes in the red wire between those points.
Mark
PostPosted: Wed Jun 26, 2019 11:57 am    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
Mark
Thanks Mark!
Marked up Bentley 97.122 showing added 7.5a fuse location.
....off to fetch parts and install it Cool
djkeev
djkeev is offline
PostPosted: Wed Jun 26, 2019 5:04 pm    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
I installed a fuse but because having a fuse is NOT expected by anyone, I clearly marked the box with a label clearly stating that there is a fuel injection fuse.
Dave
Ghia
Vanagon
Beetle
Aryana
Aryana is offline
PostPosted: Wed Jun 26, 2019 6:34 pm    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
Dave
That's a really good idea. I had a friend wash his engine bay and then his van wouldn't start. Took a long time to remember that fuse was installed and of course it was the reason it wouldn't start. It did it's job!
dhaavers
dhaavers is offline
PostPosted: Wed Jun 26, 2019 8:59 pm    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
FWIW, I hung my fuse outside the box where it GLOWS if it BLOWS...
Twisted Evil Rolling Eyes Wink
- Dave
"The WonderVan"
nemobuscaptain
nemobuscaptain is offline
PostPosted: Mon Sep 09, 2019 12:07 pm    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
This is a damn good thread. Should be FAQ IMO.
Ohio Valley Tribe, Full Moon Bus Club https://www.facebook.com/groups/294422277314227/
https://www.facebook.com/groups/FullMoonBusClub
RIP Bob Hoover https://www.thesamba.com/vw/forum/viewtopic.php?t=427791
Hoover Sermons: https://www.vwsage.com/images/vwsage/Bob%20Hoovers%20Sermons.pdf
djkeev
djkeev is offline
PostPosted: Mon Sep 09, 2019 3:33 pm    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
It already is in the FAQ.
https://www.thesamba.com/vw/forum/viewtopic.php?p=6236044#6236044
Scroll down to fuel injection
Dave
Ghia
Vanagon
Beetle
nemobuscaptain
PostPosted: Mon Nov 11, 2019 10:08 am    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
Dave
You da man, Dave!!!
16CVs Premium Member
16CVs is offline
PostPosted: Wed May 06, 2020 9:22 pm    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
I think having a fuse is not a bad idea. But doing this makes a more secure connection that is not hampered by a lack of room. When using this with proper connectors you no longer have to worry about those stupid flag connectors.
You can use the factory flags or just lob them off and use a good quality open barrel connector with a clip on cover.
Stacy
Samba member # 14980
Franklinstower
Franklinstower is offline
PostPosted: Thu May 07, 2020 9:58 am    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
Could this be a concern for any converted vans, be it Subaru, Bostig, Tiico, ALH, etc?
'89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug
16CVs is offline
PostPosted: Thu May 07, 2020 12:02 pm    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
Just a WBX issue as I know it.
Stacy
Vanagon Nut
Vanagon Nut is offline
PostPosted: Thu May 07, 2020 12:51 pm    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
The OE 1993 - 1995 wiring diagrams for the engine I used in my VW inline engine conversion do not show a PS switch as an input to ECU. AFAIK the engine management simply sees any change in idle (via cam position sensor?) then compensates for that.
I'd guess that most OBD1/2 engine management systems, thus conversions, behave in a similar manner. So that, and removal of the WBX wiring harness, remove that potential issue.
There are other OE wires in the Vanagon that are not fused. And, depending on how a conversion was done or what the OE wiring diagrams show, more unfused 15 or 30 buss wires could end up being installed. In regards to those wires becoming a potential issue, it all comes down to the quality of conversion work that is done.
Neil.
1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN
Steve M.
Steve M. is offline
PostPosted: Fri Dec 10, 2021 7:07 am    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
There's been some more people with new to them Vanagons since the last time this thread was looked at so just bumping it to bring the title up to be seen again.
dabaron
dabaron is offline
PostPosted: Fri Dec 10, 2021 8:20 am    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
Dave K has a clever solution which requires no wiring modifications... fused relays for the ECU and Fuel Pump!
i have added the set Dave gave me... makes disabling the fuel pump very quick!
1991 Vanagon GL Camper
"burnin oil and cookin coils" -- Destructo
BiWerks Design, LLC
Steve M.
Steve M. is offline
PostPosted: Fri Dec 10, 2021 8:50 am    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
Yes, that is a very good idea for this. "Glow" fuses are maybe the best innovation for fuses since the fuse.
1988M5
1988M5 is offline
PostPosted: Sun Dec 12, 2021 9:49 am    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
According to pages 42 & 43 from http://www.mk2g60.yolasite.com/resources/Digifant/...rt%201.pdf
There are many things unfused from the the "fuel pump relay" output (terminal 87) that are unprotected from shorts. ICU, PS switch, all 4 injectors, fuel pump and O2 sensor heater.
BK
1991 tin top GL
Some BMWs.
Page 4 of 5
