vwinnovator Samba Member
Joined: July 11, 2005 Posts: 1555 Location: Still doing it in the back of your VW
Posted: Fri Jun 28, 2019 7:08 am Post subject: Been searching for uncracked '72/73 steering wheel |
I've been looking for 2 untracked steering wheels for a '72 and a'73 I'm building.
been running ads, NO LUCK. |
AlmostHeavenWV_VW Samba Member
Posted: Fri Jun 28, 2019 10:42 am Post subject: Re: Been searching for untracked '72/73 steering wheel |
Don't have any personally.
Try moving your WTB ad to the late model beetle parts category.
Being in the General parts section your ad may get lost in all the shuffle and massive number of ads.
Just a thought. _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
Zundfolge1432 Samba Member
Posted: Fri Jun 28, 2019 11:19 am Post subject: Re: Been searching for untracked '72/73 steering wheel |
vwinnovator wrote: |
anyone here have 2 or anyone know of an excellent reproduction avail? |
Call Derrick at wayout salvage 479 665 4126 |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3333 Location: 802 The Pointless Forrest
Posted: Fri Jun 28, 2019 12:17 pm Post subject: Re: Been searching for untracked '72/73 steering wheel |
Pardon my ignorance, what is an untracked steering wheel? _________________ "Albatross"! |
H2OSB Samba Member
Joined: April 14, 2013 Posts: 1294 Location: Modesto, CA
Posted: Fri Jun 28, 2019 1:40 pm Post subject: Re: Been searching for untracked '72/73 steering wheel |
calvinater wrote: |
Pardon my ignorance, what is an untracked steering wheel? |
This ^^^
unCracked steering wheel?
H2OSB _________________ (o\_i_/o) I'm not a vegetarian because I love animals, I'm a vegetarian because I hate plants. |
73SlowBug Samba Member
Joined: November 28, 2017 Posts: 439 Location: PENNSYLVANIA
Posted: Fri Jun 28, 2019 6:49 pm Post subject: Re: Been searching for untracked '72/73 steering wheel |
I don't think anyone makes a new version of the padded/"plastic" steering wheels in later models. I've been looking for a couple years. I found some leather wrap online yesterday that you sew on yourself. I'm not sure if you're interested in doing that as an alternative, but I'll post my results once done. Otherwise, it looks like there are very few stock steering wheels for 72+ models that are still in good shape visually. When you find one, it's not cheap. I think Tim Donahoe has a good one. He's still using it though. _________________ Daily driven....Slowly. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31380 Location: Hot Arizona
Posted: Sat Jun 29, 2019 8:19 am Post subject: Re: Been searching for untracked '72/73 steering wheel |
H2OSB wrote: |
calvinater wrote: |
This ^^^
unCracked steering wheel? |
I couldn't figure that one out either !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
bluebus86 Banned
Posted: Sat Jun 29, 2019 9:08 am Post subject: Re: Been searching for untracked '72/73 steering wheel |
cracked wheels can be repaired. File notches in wheel at cracks to remove crack, make undercuts, then use a body filler to fill, then sand to shape, prime and paint. It is a bit of a chore, but can result in a nice wheel. however new crack can always appear. keeping car out of heat, ie out of the sun, parked on hot days, and of course gentle use of the wheel can probably help extend the life of the wheel.
Bug On! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Meiang Samba Member
Joined: September 27, 2016 Posts: 656 Location: Perth, Western Australia
Posted: Sat Jun 29, 2019 9:19 am Post subject: Re: Been searching for untracked '72/73 steering wheel |
There are plenty of 1974 onwards new steering wheels available. But NOS 1973 and before seem to be a bit rare on the ground. You can buy a good used 1973 and earlier steering wheel and they are readily available. |
Meiang Samba Member
Posted: Sat Jun 29, 2019 9:20 am Post subject: Re: Been searching for uncracked '72/73 steering wheel |
PS
Someone knew what an untracked steering wheel was. Not me. |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Sat Jun 29, 2019 10:08 am Post subject: Re: Been searching for uncracked '72/73 steering wheel |
Slowbug mentioned a leather steering wheel cover. I used the Wheelskin brand leather cover on my 1974 steering wheel. Mine wasn’t cracked (it’s covered in rubber, anyway), but I wanted to preserve the rubber padding around the circumference of the wheel. Also, I liked the leather cover for its aesthetic quality,
However, if your spokes are cracked, the Wheelskin won’t cover the portion of the wheel where the spokes meet the wheel. And installing the Wheelskin takes awhile, but once done, it’ll last for years.
Tim
_________________ Let's do the Time Warp again!
Richard O'Brien |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6621 Location: Houston, Texas
Posted: Sat Jun 29, 2019 10:34 am Post subject: Re: Been searching for uncracked '72/73 steering wheel |
You can find some good used ones. You can also try restoring your own. The most difficult part is the part where it's cracked.
You might try https://kochs.com/ to see if they can restore your wheel. _________________ www.vwnos.com [email protected]
Posted: Sat Jun 29, 2019 1:48 pm Post subject: Re: Been searching for uncracked '72/73 steering wheel |
I hate to mention them, but MidAmerica used to carry a tube of stuff that they advertise is especially for restoring cracked steering wheels. It’s a kind of epoxy putty. You apply, let set up, then sand and shape. Afterwards, you paint.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
heimlich VWNOS.com
Posted: Sat Jun 29, 2019 1:52 pm Post subject: Re: Been searching for uncracked '72/73 steering wheel |
Tim Donahoe wrote: |
Tim |
I used an epoxy putty (not theirs) to repair mine. I drilled out around the cracks and then filled it in and sanded it down. I then painted it. It looked real nice. The issue with doing this type of repair is it doesn't prevent it from cracking again. There's nothing to hold the two sections together as the steering wheel bends and flexes. The cracks will be smaller but they will still appear. _________________ www.vwnos.com [email protected]
Posted: Sat Jun 29, 2019 5:32 pm Post subject: Re: Been searching for uncracked '72/73 steering wheel |
I just wrapped mine today. Overall, i like it. Went for a quick spin, and it's got a nice feel to it. I'd suggest giving the one of these a try before investing in a new wheel.
Posted: Sat Jun 29, 2019 5:37 pm Post subject: Re: Been searching for uncracked '72/73 steering wheel |
That’s a nice, tight wrap, Slow. It looks good.
Richard O'Brien |
heimlich VWNOS.com
Posted: Sat Jun 29, 2019 6:45 pm Post subject: Re: Been searching for uncracked '72/73 steering wheel |
Be careful with the buttons. They will also crack easily. _________________ www.vwnos.com [email protected]
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76945 Location: Sneaking up behind you
Posted: Sat Jun 29, 2019 6:48 pm Post subject: Re: Been searching for uncracked '72/73 steering wheel |
Did mine 22 years ago, still looks good.
_________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat Jun 29, 2019 9:00 pm Post subject: Re: Been searching for uncracked '72/73 steering wheel |
Glenn, that gives me hope for mine to last as long.
Richard O'Brien |
challomoner Samba Member
Joined: October 13, 2010 Posts: 1216 Location: IRELAND
Posted: Tue Jul 02, 2019 12:08 am Post subject: Re: Been searching for uncracked '72/73 steering wheel |
Search in Europe or cold wet states in the US. Heat damages the wheels as well as long term use, get one from a bug that rotted out inside 10-15 years and the wheel will be hardly used. |
