chift Samba Member
Posted: Sat Jun 22, 2019 1:58 pm Post subject: Re: The Stupid Question Thread |
Hey Folks,
Ran into a small issue and looking for options. While attempting to remove the starter bushing using a thread tap, only a portion of it came out. Now, with what's left the tap cannot bite into the old bushing. Any suggestions on getting the rest out?
I don't have a larger thread tap, but that is what I was thinking my next steps were
Thanks |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51129 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Jun 22, 2019 2:53 pm Post subject: Re: The Stupid Question Thread |
You might check with your FLAPS to see if they have an internal puller for rent or loan. Aside from that try grinding the end of the tap shorter so most of the tapered part is gone. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
MaritimeBay Samba Member
Joined: September 16, 2013 Posts: 120 Location: Fredericton NB
Posted: Sun Jun 23, 2019 8:24 am Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
What does the back side of the flywheel look like? (case side). |
Quite oily. That’ll be the culprit. Thanks bus daddy, and everyone else on this forum that takes the time to spread your knowledge. This place is really a treasure. Was able to check the endplay. Comes in at 0.004” real nice. Also got a chance to build a homemade flywheel lock rather than waiting for one to be shipped across the country.
_________________ 1977 2.0L FI Westfalia.
They call my home the land of snow. |
Angus II Samba Member
Joined: June 01, 2016 Posts: 707 Location: Mammoth Lakes Ca. 93546
Posted: Sun Jun 23, 2019 8:51 am Post subject: Re: The Stupid Question Thread |
Hello,
It may be a good time to clean up that flywheel surface a bit. |
Terminatez Samba Member
Joined: June 07, 2015 Posts: 340 Location: Sun Valley, CA
Posted: Mon Jun 24, 2019 9:20 am Post subject: Re: The Stupid Question Thread |
Any leads for the ice box/fridge door seal for a 72 ice box? _________________ 1972 Westfalia P30 hardtop Campmobile [On-going Restoration]
aeromech wrote: |
I don't think I've ever seen an engine in worse shape. |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Hikelite Samba Member
Joined: August 31, 2012 Posts: 557 Location: Colville, WA
Posted: Mon Jun 24, 2019 2:50 pm Post subject: Re: The Stupid Question Thread |
chift wrote: |
Hey Folks,
Thanks |
It sounds to me like you need to pull the motor. Then you can press the new bushing in and it will push out what's left of the old bushing. _________________ ~Kevin
My 1968 Campmobile |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Wed Jun 26, 2019 3:20 pm Post subject: ambulance fans |
I picked some ambulance fans up for a song. My question is, when installed, where do they blow out? the adjustable vents on the dash? the tree down behind the e-brake?
will their operation be hindered/changed because I have the armrest vents on my doors that shoot air to the back? |
71whitewesty Samba Member
Joined: February 25, 2010 Posts: 1544 Location: oregon
Posted: Wed Jun 26, 2019 4:42 pm Post subject: Re: ambulance fans |
alman72 wrote: |
The air will come out the same as your fresh air vents. The two round holes on each side and the two dash slots that are far right and left. _________________ 71 Westy 1600 DP, all stock Bus 1
1970's Snow Trac 1600 SP (sold 12/2016)
1968 Tucker sno cat, sold 2021
1969 Tucker Sno cat 542
2017 VW Alltrac
71 tin top stock 1600 DP (project but runs)
Twin 71 White Westy, Bus 2, that I pulled from a 15 year slumber in a dry eastern WA field in 2015.
1966 Sundial Camper "Boomer" |
Posted: Wed Jun 26, 2019 5:05 pm Post subject: Re: ambulance fans |
71whitewesty wrote: |
alman72 wrote: |
The air will come out the same as your fresh air vents. The two round holes on each side and the two dash slots that are far right and left. |
And the vents in the bulkhead for the enjoyment of your passengers in the back, same effect as pulling the blue levers down while under way except they'll blow when stopped too. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
oshima Samba Member
Joined: December 12, 2011 Posts: 112 Location: Knoxville, TN
Posted: Wed Jul 10, 2019 6:44 pm Post subject: Re: The Stupid Question Thread |
When I activate my turn signals, the battery light alternates with the turn signal (i.e., turn signal light on = battery light off, turn signal light off = battery light on). The battery light does not come on otherwise (except normally). I'm assuming this is a bad ground - where should I start looking? _________________ 1978 2.0L Fuel Injected |
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Fri Jul 12, 2019 12:12 pm Post subject: Re: The Stupid Question Thread |
Okay, I've read on The Samba about a screen (or sock?) in the fuel tank that needs to be replaced occasionally.
Where is this located, how is it replaced, and where do you buy new ones? _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22450 Location: Escondido CA
Posted: Fri Jul 12, 2019 12:34 pm Post subject: Re: The Stupid Question Thread |
KentPS wrote: |
Where is this located, how is it replaced, and where do you buy new ones? |
From a split window - but the same install.
http://oacdp.org//5867part/189.png
The part.
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111209147A
It's your first line of defense against particulate in the gas/gas tank. How often do you check its condition? Depends on how crappy the inside of your tank may be. The older tanks that have sat with moisture in them scale more and release more particles into the gas. A new repop or conditioned tank - none. If you notice a lot of crap on your secondary filter then your sock may be shot or non-existent.
When you need a fill up is the best time to check. Less gas to dump from the tank before you unscrew the tit from the bottom of the tank. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Fri Jul 12, 2019 1:31 pm Post subject: Re: The Stupid Question Thread |
notchboy wrote: |
KentPS wrote: |
The part.
When you need a fill up is the best time to check. Less gas to dump from the tank before you unscrew the tit from the bottom of the tank. |
No sock on a 76, 74 was the last year with the outlet strainer, 75+ has a non removable outlet. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Jul 12, 2019 1:32 pm Post subject: Re: The Stupid Question Thread |
KentPS wrote: |
Fuel injected buses don’t have one _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Posted: Fri Jul 12, 2019 1:46 pm Post subject: Re: The Stupid Question Thread |
Thanks Notchboy, BD and Robbie. That's all good info.
And now I know not to look for one when the engine gets replaced next week. _________________ -Kent-
---williamM |
Posted: Fri Jul 12, 2019 4:36 pm Post subject: Re: The Stupid Question Thread |
KentPS wrote: |
And now I know not to look for one when the engine gets replaced next week. |
Oh yeah, FI. _________________
t3kg wrote: |
1964 1500 S
wcfvw69 Samba Purist
Posted: Fri Jul 12, 2019 6:58 pm Post subject: Re: The Stupid Question Thread |
KentPS wrote: |
lol Kent! _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Fri Jul 12, 2019 7:16 pm Post subject: Re: The Stupid Question Thread |
wcfvw69 wrote: |
KentPS wrote: |
lol Kent! |
Wow! Where did you find my senior portrait from high school?!? _________________ -Kent-
---williamM |
Sven F Samba Member
Joined: July 24, 2009 Posts: 92 Location: Croatia / Denmark
Posted: Sat Jul 13, 2019 9:10 am Post subject: Re: The Stupid Question Thread |
Does anyone have a trick for rotating the front brake caliper pistons to the correct position to fit the anti-squeal shims?
I don't feel like taking the pistons out and re-bleeding if I don't have to. I don't have the fancy tool obviously.
Also looking for someone to remove my remaining 5% doubt that this is the correct way to position the shims. Thanks!
