'63 Panel Camper to Deluxe conversion project
Page: Previous  1, 2, 3 ... 21, 22, 23, 24, 25  Next
edgood1
edgood1 is offline
PostPosted: Sun May 26, 2019 12:25 pm    Post subject: Re: '63 Panel Camper to Deluxe conversion project Reply with quote
1987 Syncro Westfalia powered by Subaru
bally
bally is offline
PostPosted: Sun May 26, 2019 4:02 pm    Post subject: Re: '63 Panel Camper to Deluxe conversion project Reply with quote
Looking good the right way up again. Must be a great feeling 😊
Culito wrote:
Working on an old VW can be good therapy...
edgood1
edgood1 is offline
PostPosted: Mon May 27, 2019 10:04 am    Post subject: Re: '63 Panel Camper to Deluxe conversion project Reply with quote
I talked to a few local dustless blasting companies about getting the body shell blasted inside and out. I was quoted $1500 and $2200. I'll be doing the body work the old fashioned way.
edgood1
edgood1 is offline
PostPosted: Tue May 28, 2019 12:42 pm    Post subject: Re: '63 Panel Camper to Deluxe conversion project Reply with quote
I'm slightly modifying my plan. After flipping the bus back upright I noticed surface rust starting to pop up on the side that was facing the ground so I'm going to sand the sucker down and shoot it with epoxy to prevent this.
layer by layer.
It goes sparkly blue->light blue primer, dark orange, light orange, beige primer, dark blue, light blue (original), grey primer, brown primer, metal.
here i'm getting down to the dark and light blue.
edgood1
edgood1 is offline
PostPosted: Wed Jun 05, 2019 5:34 am    Post subject: Re: '63 Panel Camper to Deluxe conversion project Reply with quote
I like to post to and read through this thread to remind myself of how much time and work I've put into this project. Thus I'm going to post many pics of this sanding work as it's a major undertaking. Getting into all the nooks and crannies is time consuming.
edgood1
edgood1 is offline
PostPosted: Sun Jun 09, 2019 3:42 pm    Post subject: Re: '63 Panel Camper to Deluxe conversion project Reply with quote
Sanding, grinding, sanding, wire wheeling, sanding and then more sanding....
edgood1
edgood1 is offline
PostPosted: Tue Jun 25, 2019 11:16 am    Post subject: Re: '63 Panel Camper to Deluxe conversion project Reply with quote
after lots and lots of sanding i took a break to do some metal work today.
i added some "filler" plates under the rear window inner panel
I made and welded in the little panel bracket at the bottom of the B pillar:
and installed the last piece of headliner clip above the drivers side windshield:
I gotta weld in some nuts for the rear cargo door strap. the holes are there, just no threaded nuts behind them. The door has them though....
bally
bally is offline
PostPosted: Wed Jun 26, 2019 2:15 am    Post subject: Re: '63 Panel Camper to Deluxe conversion project Reply with quote
Nice work; it's coming together! I need to weld in some of these brackets too. Thanks for the reminder 😃
Dave
edgood1
edgood1 is offline
PostPosted: Thu Jun 27, 2019 12:43 pm    Post subject: Re: '63 Panel Camper to Deluxe conversion project Reply with quote
Dave
thanks Dave.
I did the surgery on the "C" pillar this morning:
Clatter
Clatter is offline
PostPosted: Thu Jun 27, 2019 6:11 pm    Post subject: Re: '63 Panel Camper to Deluxe conversion project Reply with quote
Excellent!
Getting those layers of old paint out of the way will make the blasting go SO much faster!
Less chance of warp-age as well.. Wink
Very Happy Very Happy Very Happy
Razz
Bus Motor Build
Fastback Build
What's That Noise??
edgood1
edgood1 is offline
PostPosted: Fri Jun 28, 2019 9:42 am    Post subject: Re: '63 Panel Camper to Deluxe conversion project Reply with quote
Clatter wrote:
Excellent!
Razz
i intend to sand it all down with a DA sander, no more blasting.
edgood1
edgood1 is offline
PostPosted: Mon Jul 01, 2019 5:11 am    Post subject: Re: '63 Panel Camper to Deluxe conversion project Reply with quote
I had a quick hour to work on the bus and decided to start tackling the giant holes someone had drilled in of the spring plates.
At first I was going to try to add some filler material around the edges of the holes and open them up but in the end i decided to just fill them completely and redrill
edgood1
edgood1 is offline
PostPosted: Thu Jul 11, 2019 9:44 am    Post subject: Re: '63 Panel Camper to Deluxe conversion project Reply with quote
ive been bad on updates, the camera on my phone is broken.
I shot epoxy primer today:
gonna need a lot of body work...
Burlyhammer
Burlyhammer is offline
PostPosted: Thu Jul 11, 2019 9:48 am    Post subject: Re: '63 Panel Camper to Deluxe conversion project Reply with quote
Very nice!!! Cool
BarryL Premium Member
BarryL is offline
PostPosted: Thu Jul 11, 2019 11:59 am    Post subject: Re: '63 Panel Camper to Deluxe conversion project Reply with quote
Yes ^^^ and unbelievable how you've stuck with this project.
edgood1
edgood1 is offline
PostPosted: Thu Jul 11, 2019 12:36 pm    Post subject: Re: '63 Panel Camper to Deluxe conversion project Reply with quote
Burlyhammer wrote:
Very nice!!! Cool
thanks guys. I'm so tempted to just paint it and roll it as is... gotta be patient...
type2rescuemaine
type2rescuemaine is offline
PostPosted: Thu Jul 11, 2019 6:26 pm    Post subject: Re: '63 Panel Camper to Deluxe conversion project Reply with quote
Looks amazing! Gonna keep going with the 23 window idea or stick with 15?
edgood1
edgood1 is offline
PostPosted: Fri Jul 12, 2019 3:31 am    Post subject: Re: '63 Panel Camper to Deluxe conversion project Reply with quote
Definitely 23. I wanted to get the body into epoxy to protect the work I've already done from rust.
edgood1
edgood1 is offline
PostPosted: Mon Jul 15, 2019 5:42 am    Post subject: Re: '63 Panel Camper to Deluxe conversion project Reply with quote
got about 20 hours of body work in so far and not even close to done.
these vents were engineered by the devil himself
Fifty-Eight Rag
Fifty-Eight Rag is offline
PostPosted: Mon Jul 15, 2019 6:47 am    Post subject: Re: '63 Panel Camper to Deluxe conversion project Reply with quote
I agree!
I worked a set of those on a 62 Single Cab...they were hell!
Twisted Evil
1956 Oval
and a barn full of VW parts
1956 Oval build thread
1967 Beetle Restoration
http://www.thesamba.com/vw/forum/viewtopic.php?t=495269&highlight=larrys
1962 Single Cab Restoration
http://www.thesamba.com/vw/forum/viewtopic.php?p=7959298#7959298
Page 22 of 25
