richparker Samba Member
Joined: November 24, 2011 Posts: 6981 Location: Durango, CO
Posted: Tue Mar 26, 2019 7:29 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
Ben,
I’m sure you have plenty of miles on that engine now. How does it run? Have you had to remap the Gen4? Have you made any major changes to the engine yet? _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
HastaAlaska Samba Member
Joined: November 22, 2012 Posts: 1420 Location: Off Grid
Posted: Sat Mar 30, 2019 1:07 am Post subject: Re: Overlanding a VW Bus Around The World?! |
It runs great, I have had to re map it a little bit, but it was easy and intuitive to do. I've had CB Performance remote connect into the Kombi to check everything as good. It's been parked up for a while in Jersey (UK) whilst we work on building the interior, but we're itching to get going hopefully next month.
Got a bit of mechanical work to do to before hitting the road. _________________ Around The World in a VW - Follow the Docuseries
2011 - PRESENT
Hasta Alaska Series - https://kombilife.com/hasta-alaska/
World Overland Series - https://kombilife.com/world-overland-travel-series/
Latest Adventures - https://www.youtube.com/@kombilife |
merlinsbus Samba Member
Joined: August 03, 2011 Posts: 75 Location: Portland, OR
Posted: Sat Mar 30, 2019 12:23 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
Very much excited to see the interior come together, been watching the videos closely! _________________ "If I wanted a restored truck the most cost effective way is to buy one already done. My truck is special to me and the journey has enriched my life. VW people understand". -Glideking
"Always remember: others may hate you, but those who hate you don't win unless you hate them and then you destroy yourself" -Richard Nixon |
Posted: Tue Jun 18, 2019 1:54 am Post subject: Re: Overlanding a VW Bus Around The World?! |
Had chance to meet up with our old kombi CoPito whilst filming the UK episodes.
Our new Kombi "Boomerang" is doing pretty well on the shakedown run. looking forward to sharing the videos of how it's all come together later this summer.
Hope you are all well.
Ben _________________ Around The World in a VW - Follow the Docuseries
2011 - PRESENT
Clementine79 Samba Member
Posted: Tue Jun 18, 2019 6:48 am Post subject: Re: Overlanding a VW Bus Around The World?! |
Very cool we are waiting to see the new videos, hoping to get us bus running like one some day! |
Posted: Wed Jul 10, 2019 9:03 am Post subject: Re: Overlanding a VW Bus Around The World?! |
Guys, I'm just putting together a maintenance schedule ahead of our departure for Phase 2 of the trip (UK to Africa)
Please could you look at this and tell me if there is anything you would add to this list, or any other comments would be welcome. Thanks
Each Fuel Stop
Check Oil Level / quality
Check Fan Belt Tension
Visual inspection for leaks and damage, fan belt tension
Weekly
Clean out rubbish
Clean Solar Panels
clean mud off CV Boots
Check Tire Pressure
3000 Miles
Change Oil
Fill Brake Fluid
Fill Windscreen Wash
Check Lights
Lubricate Hinges, locks and door catches
Valve Adjustment
5000 Miles
Adjust Rear Brakes
Check E Brake adjustment
Clean Pressure Relief Valve ?
Check Wipers
Tighten Wheel Nuts
7500 Miles
Rotate Tires
10000 Miles
Clean and re-oil air filter (more frequently depending on environment)
Check all exhaust nuts, intake manifold nuts, alternator pully etc
check hoses and clamps
Inspect fan belt
Adjust Spark Plugs
Add Water To Battery
Tighten Transmission Front Support Nuts
Check for water leaks and gas leaks
Grease Front End
15000 Miles
Pack CV Joints
Inspect / Change Brake Shoes
20000 Miles
Change fuel filter
Replace Valve Cover Gaskets
30,000 Miles
Change Transmission Oil
Re-grease Wheel Bearings
Re-grease CV Joints
Replace Spark Plugs
Paint Rust
Oil protection on undercarriage
45,000 Miles
Replace Brake Fluid _________________ Around The World in a VW - Follow the Docuseries
2011 - PRESENT
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Wed Jul 10, 2019 9:12 am Post subject: Re: Overlanding a VW Bus Around The World?! |
My suggestion would be to adjust your mileage points to line up a little bit. I.e.
3,000 miles
Change oil, etc
6,000 miles
Adjust brakes, etc
9,000 miles
Rotate Tires
12,000 miles
Clean air filter, etc (I'd probably do this one at all the oil changes, and leave the rest of that list at 12,000 miles.)
That way you are doing your maintenance all in one fell swoop, adding tasks to oil change days. Seems like it would be easier to plan. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22639 Location: NYC/Upstate/ROW
Posted: Wed Jul 10, 2019 9:34 am Post subject: Re: Overlanding a VW Bus Around The World?! |
Here you go, Ben...
Each Fuel Stop
Tighten Wheel Nuts - I would just inspect at fuel stops with a index mark
Weekly
Clean out rubbish ---Daily!
Clean Solar Panels
clean mud off CV Boots - Skip unless extreme
Check Tire Pressure
3000 Miles
Change Oil
Fill Brake Fluid None should be used in 2 years/24000 miles
Check Lights
Valve Adjustment
Gap plugs since they are already out.
5000 Miles
Adjust Rear Brakes
Check E Brake adjustment - This tells you when the one above is needed. When you adjust the brakes, the E-brake will be back in spec.
Clean Pressure Relief Valve ? - leave that alone
Check Wipers
7500 Miles
Rotate Tires
10000 Miles
Inspect fan belt
Adjust Spark Plugs
Grease Front End
15000 Miles
Pack CV Joints
20000 Miles
Change fuel filter
30,000 Miles
Re-grease CV Joints
Replace Spark Plugs = depends on what kind you are using?
Paint Rust
45,000 Miles
Replace Brake Fluid - 24 months max - In Central Africa, every 12 months
_________________ _________________ .ssS! |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Wed Jul 10, 2019 10:09 am Post subject: Re: Overlanding a VW Bus Around The World?! |
HastaAlaska wrote: |
1) Sell Bus
2) Buy Tacoma
*Note: Everything beyond steps 1 and 2 are widely considered as optional*
3) Oil change every 5k-10k miles
4) Shake off the air filter if its dirty
5) You could inspect for missing bolts/parts, but honestly it'll probably run without half of them anyways. So don't bother
Each Fuel Stop
Weekly
Clean out rubbish
Clean Solar Panels
Check Tire Pressure
3000 Miles
Change Oil
Fill Brake Fluid
Check Lights
Valve Adjustment
5000 Miles
Adjust Rear Brakes
Check Wipers
Tighten Wheel Nuts
7500 Miles
Rotate Tires
10000 Miles
Inspect fan belt
Adjust Spark Plugs
Grease Front End
15000 Miles
Pack CV Joints
20000 Miles
Change fuel filter
30,000 Miles
Re-grease CV Joints
Replace Spark Plugs
Paint Rust
45,000 Miles
Replace Brake Fluid |
I did a little simplifying for you. lol _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Posted: Wed Jul 10, 2019 11:50 am Post subject: Re: Overlanding a VW Bus Around The World?! |
Spike0180 wrote: |
1) Sell Bus
2) Buy Tacoma
3) Shoot yourself
4) Miss
5) Barter for Water Buffalo
I did a little simplifying for you. lol |
(Took some liberties because, Ahem, I was actually helpful, above.)
Well, tried to be helpful. _________________ .ssS! |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Wed Jul 10, 2019 3:30 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
I empty my garbage when it gets full, but I also made this recently:
http://asiab3.com/media/cavms.pdf
See you on the road,
www.airschooled.com |
Posted: Fri Jul 12, 2019 1:39 am Post subject: Re: Overlanding a VW Bus Around The World?! |
vwwestyman wrote: |
My suggestion would be to adjust your mileage points to line up a little bit. |
Great idea, that comment probably made life a lot easier And thanks for the other notes too, I've adjusted my schedule accordingly.
Not sure where I saw to Clean Pressure Relief Valve - Think in the idiots book. To be honest I've only done that a couple of times since 2014 and it's always been peachy. So are you saying I don't need to check in on this?
How often are you guys changing out fuel lines?
Very useful Robbie, thanks for sharing mate. Good to see you have the rear wheel bearings job at 50K, I have to do that now and I hate that job.
Also would be interested to hear what you guys think about the oil change interval. I have a filter on this engine, a deep sump and external oil cooler (the oil almost never gets up over 180F) It takes 6 qts oil oil and the last oil change cost me over $100 for the oil. I've read a lot about how oil has improved and 3000 mile changes is wasteful. I would tend to agree with that, especially given my current configuration. What are your thoughts?
In other news I fitted New 15" Steel wheels to my bus (mainly for better tire selection)
Campervan Culture bought up all the remaining MEFRO wheels (ET30) as they are NLA, supply is limited . https://campervanculture.com/shop/15-mefro-steel-wheels-set-of-5/
They bolt right onto the bus and the clearance looks good The tire is 205 / 70. Michelin Latitude Cross. not as beefy as the other ATs but better fuel economy and much better grip in the wet.
The BFG KOs I had previously worked great in Mud, but were crap in sand. They also were worn down very quick on the front. I'm betting the new set up will be better across the board. _________________ Around The World in a VW - Follow the Docuseries
2011 - PRESENT
Posted: Fri Jul 12, 2019 1:54 am Post subject: Re: Overlanding a VW Bus Around The World?! |
Consult CB for your engine service intervals.
In general, oil change intervals are shrunk more with operation in dusty conditions, and shrunk when the daily operation of the car doesn’t warm it up completely. VW mentions this in the owners manuals when talking about operation in extreme cold- changing the oil much more often.
Someone mentions “checking road draft boot” on stock Type 1’s, and that’s also on the bottom of the engine. Maybe that’s what made you think pressure relief valve?
I also enjoy logging fuel mileage and conditions. You can tell when something goes wrong you might not catch otherwise that way.
Ok, back to bed now... had a nightmare I lost my feeler gauges...
Posted: Fri Jul 12, 2019 4:04 am Post subject: Re: Overlanding a VW Bus Around The World?! |
The BFG KOs I had previously worked great in Mud, but were crap in sand. They also were worn down very quick on the front. . |
$100 dollars for an oil change? My engine is mostly all CB stiff and also has a 6 qt oil system. Oil and a filter only runs me $40 USD per oil change, $25 for oil and $15 for the filter. I change every 3k or so. Even if it does cost you $100 every 3000 miles, who cares. You got a FREE Pat Downs build and you better not fuck that up!
Interesting that you think the KOs suck in the sand. They say right on the side of the tire that they are the Baja Champion. If you’ve found they are wearing poorly in the front, that won’t change with new tires. Sounds like you need some front end work. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Fri Jul 12, 2019 5:14 am Post subject: Re: Overlanding a VW Bus Around The World?! |
That blue hi top looks familiar. I'd ask Dave, but he pussed out and probably got a job or something. |
Posted: Sat Jul 13, 2019 3:09 am Post subject: Re: Overlanding a VW Bus Around The World?! |
[quote="richparker"]
..Sounds like you need some front end work. |
Yep agreed. Front alignment has been done. Going through the front end this month with a fine tooth comb. Considering taking out the front torsion leaves for inspection. Never done it. Bit nervous about it. _________________ Around The World in a VW - Follow the Docuseries
2011 - PRESENT
Posted: Sat Jul 13, 2019 6:46 am Post subject: Re: Overlanding a VW Bus Around The World?! |
Considering taking out the front torsion leaves for inspection. Never done it. Bit nervous about it. |
That’s a big job, you should consider replacing the ball joint at the same time. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22448 Location: Escondido CA
Posted: Sat Jul 13, 2019 10:00 am Post subject: Re: Overlanding a VW Bus Around The World?! |
I think you will be happy with the tire size. Running 215's is a bit much. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Sat Jul 13, 2019 10:10 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
We’re the alignments done with the bus fully loaded or unloaded?
The specs for tire alignment assumes an empty bus with something like a 70kg weight in the front seat and a half tank of gas. If your bus is Consistsntly used with a heavier load, you should consider having the alignment done with some load. This might not be a popular opinion, but I travel loaded 90+ % of the time, when I did my alignment with my 200lb. tool box in its respective place, tire wear slowed greatly.
