gitchesum Samba Member
Joined: November 10, 2003 Posts: 513 Location: North Cali
Posted: Mon Jul 15, 2019 9:36 am Post subject: Re: Breather issue. |
Glenn wrote: |
Not sure what the problem is....
I have a 2180 with FK8 and Steve Tims heads and have no problem with just both valve covers vented to a Berg breather.
And that breather is vented how/where ? _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 rag w/356B brakes
61 356B
Honda XLR 250, 69 Z50, Yamaha 100 Enduro...and others.
GMC SLT 4x4 Dmax
Kubota L3710, not enuf attachments.
And various VW's that come and go... |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2745 Location: Hamble, Hampshire, UK
Posted: Mon Jul 15, 2019 9:44 am Post subject: Re: Breather issue. |
A stock breather on a stock 1600 mid 70s Eurpoean T1 engine after VW deleted the downpipe and fed the air cleaner instead is almost 3/4 inch ID.
Fit a bigger barb and hose to the fuel pump blockoff amd feed that to the breather box.
The setups that work all have bigger hoses. _________________ Ancient vehicles and vessels
HotStreetVw Samba Member
Joined: October 03, 2004 Posts: 871 Location: Wild West
Posted: Mon Jul 15, 2019 10:20 am Post subject: Re: Breather issue. |
jeffrey8164 wrote: |
buguy wrote: |
I like that idea of putting a filter/breather where the oil fill cap was. Smart |
It looks pretty now but will eventually be a goopy mess.
Been there. |
How is it any different that a breather box with a filter? The CSP box is baffled. _________________ 4inBhore
50 Split - 2724cc NA. Haltech injected
62 Notchback - 2542cc Turbo WIP |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76945 Location: Sneaking up behind you
Posted: Mon Jul 15, 2019 10:56 am Post subject: Re: Breather issue. |
gitchesum wrote: |
Glenn wrote: |
And that breather is vented how/where ? |
Vented to the right rear fender with a foam button filter. It's a low pressure area and helps evacuate the case. _________________ Glenn
Member #1009
#BlueSquare |
buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Mon Jul 15, 2019 12:35 pm Post subject: Re: Breather issue. |
Makes for good burnouts too! |
Glenn Mr. 010
Posted: Mon Jul 15, 2019 1:11 pm Post subject: Re: Breather issue. |
Never had a drop of oil from there. _________________ Glenn
Member #1009
#BlueSquare |
buguy Samba Member
Posted: Tue Jul 16, 2019 9:07 am Post subject: Re: Breather issue. |
Never thought for a second you would have. That would be suicide! |
Posted: Fri Jun 17, 2022 9:23 am Post subject: Re: Breather issue. |
Resolved...This is crazy, but after all I tried and changed the whole breater setup, it persisted.
So I washed everything off for a new start, fired it up and let it idle.....nothing!
Reved it for a while to maybe 2K, and here it comes....outa the oil pressure sender ! A fine mist of oil.
I've had these fail before, but it usually shows up at idle too.
Almost embarrassing. _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 356B
GMC SLT 4x4 Dmax
plywoodkid Samba Member
Joined: April 17, 2018 Posts: 217 Location: Ventura County, CA
Posted: Fri Jun 17, 2022 3:53 pm Post subject: Re: Breather issue. |
Great news the …….set up is fine. Just the sender.
Don’t be too hard on yourself, sender misting is not that common…..at least I’ve never seen it. Did the mist come from the male bolt or the device itself? |
Posted: Sat Jun 18, 2022 7:10 am Post subject: Re: Breather issue. |
plywoodkid wrote: |
Between the plastic and the metal area...I believe. _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 356B
GMC SLT 4x4 Dmax
