Mickey bitsko Samba Member
Joined: June 13, 2019 Posts: 511 Location: New Mexifornia
Posted: Fri Jul 19, 2019 7:10 pm Post subject: "P" rated tires |
Looked all thru Baja section looking for off road tire ideas , all different sizes makes and models , not one person had what load range they are running front or rears. I have 215/75 BFG A/T load range C front and rear on my '70 type 1 , they're around 5 years old with maybe 5k mi on them. Seem way to stiff for my liking, at least the fronts.
Any suggestions? |
kpf Samba Member
Joined: March 01, 2017 Posts: 853 Location: California, US
Posted: Fri Jul 19, 2019 7:41 pm Post subject: Re: "P" rated tires |
What tire pressure do you run in the front? _________________ 1971 Super Beetle |
Posted: Fri Jul 19, 2019 8:10 pm Post subject: Re: "P" rated tires |
I know I'll get grief for this, 8 f 10 r , honestly, the fronts have almost no sidewall bulge. That being said, I drive 5 miles the a river road to go fishing and hunting and that's what I'm building my build.
Along with the stiffness us the weight, totally unnecessary imo. |
oprn Samba Member
Joined: November 13, 2016 Posts: 12740 Location: Western Canada
Posted: Sat Jul 20, 2019 3:29 am Post subject: Re: "P" rated tires |
On my sand rail with 5 rib implement tires on the front I run 6 psi. The rears are 14" quad tires that I run 4 psi in. You can let almost all the air out of the fronts before they start to look low.
Posted: Sat Jul 20, 2019 4:33 am Post subject: Re: "P" rated tires |
Thanks for the response, maybe I need to focus more on my suspension. I do run through some pretty rough rock patches and I don't worry about blazing new trails . |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Sat Jul 20, 2019 5:03 am Post subject: Re: "P" rated tires |
Are you running those crappy coil over shocks? _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sat Jul 20, 2019 5:25 am Post subject: Re: "P" rated tires |
Absolutely not... Stock shocks front and rear.
I think the PO cranked the rear torsion bars to the max, as for the front, he put ,imo, wrong back space wheels to make them stick out as wide as the rear. Not sure that makes the front more harsh but imo is hard on front components. |
Posted: Sat Jul 20, 2019 5:54 am Post subject: Re: "P" rated tires |
Since it's a '70, it should have dual spring plates in the rear. See if the inner plates are notched. If they are not, you can regain some suspension travel/compliance by notching them.
Posted: Sat Jul 20, 2019 5:59 am Post subject: Re: "P" rated tires |
Do I need to remove the spring plates to notch them? |
Posted: Sat Jul 20, 2019 6:01 am Post subject: Re: "P" rated tires |
Yes. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sat Jul 20, 2019 6:04 am Post subject: Re: "P" rated tires |
Thanks, how much did you grind off? |
Posted: Sat Jul 20, 2019 6:13 am Post subject: Re: "P" rated tires |
I started by drilling a 3/4" hole in the plate for the radius, then scribed a straight line from there to the radius at the end of the spring plate bushing.
This will require you to also get longer shocks or to cut 1" out of the lower shock mount cup. Cutting an inch out of the shock mount cup also you gain some more clearance over rocks. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sat Jul 20, 2019 6:30 am Post subject: Re: "P" rated tires |
Good suggestions, thank you ! |
Posted: Sat Jul 20, 2019 6:54 am Post subject: Re: "P" rated tires |
Keep in mind, this is testing the maximum angles of the CVs, but I have been running them like this for 23,000 miles now. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sat Jul 20, 2019 7:03 am Post subject: Re: "P" rated tires |
I understand... How much travel did you gain? |
Posted: Sat Jul 20, 2019 7:50 am Post subject: Re: "P" rated tires |
Probably another 1.5" but now I'm not topping out over every transition & rock & gully. It now rides just like it would if it was stock height.
Posted: Sat Jul 20, 2019 8:43 am Post subject: Re: "P" rated tires |
Are you still running your front sway bar? _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
kpf Samba Member
Posted: Sat Jul 20, 2019 9:04 am Post subject: Re: "P" rated tires |
Mickey bitsko wrote: |
...Seem way to stiff for my liking, at least the fronts |
A friend of mine had a sand rail and it’s front torsion bar suspension was locked up solid from neglect. Made for a terrible ride, as you might expect. _________________ 1971 Super Beetle |
Posted: Sat Jul 20, 2019 10:41 am Post subject: Re: "P" rated tires |
Tdctdi, my travels are similar to your power line video.
Your Ghia rides like a Cadillac compared to my bug.
Still running front swaybar. |
KTPhil Samba Member
Posted: Sat Jul 20, 2019 3:06 pm Post subject: Re: "P" rated tires |
To a dog, all tires are p-rated. |
