nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Tue Jul 23, 2019 7:51 pm Post subject: What's the difference in these AA Performance Products 36hp P/C |
I'm curious if anyone has a preference or experience for one or the other of these apparently stock 36hp P/C kits sold by AA Performance products
I don't understand the gigantic price difference and the only obvious difference is compression height.
What would a bone stock 36hp bus engine best use?
https://aapistons.com/products/vw-77mm-36-horse-power-piston-cylinder-kit
Vendor: AA Performance Products
Description:
This is a new set of 77mm Type 1 Pistons for 36HP. This Set comes complete with 4 pistons, 4 wrist pins, and the clips
Engine size: 1200cc
Stroke: 64mm
Cylinders: Cast Iron
Pistons: Hypereutectic
Compression Height: 38.05mm
Kit includes: 4 Cylinders, 4 Pistons, 1 set of piston rings, and 4 wrist pins and clips.
$311.95
Part # VW7700T36
Versus
https://aapistons.com/products/vw-77mm-type-1-piston-kit-36
Description:
Pistons: Hypereutectic aluminum alloy
Compression Height: 38.1mm.
$95.95
Part#: VW7700T36P |
motofly196 Samba Member
Joined: June 01, 2008 Posts: 1467 Location: Eastern WA
Posted: Tue Jul 23, 2019 8:12 pm Post subject: Re: What's the difference in these AA Performance Products 36hp P/C |
Looks like the 1st set listed is for Pistons and Cylinders. 2nd set is Pistons only? |
Mr.Ragtop Samba Member
Joined: February 04, 2010 Posts: 46 Location: colorado
Posted: Wed Jul 24, 2019 10:12 pm Post subject: Re: What's the difference in these AA Performance Products 36hp P/C |
motofly196 wrote: |
You are correct. The cheaper one is Pistons only. You can buy cylinders only as well. I always just do the full kit. If you are into an engine build to that point, might as well do it all. |
JeeWee Samba Member
Joined: February 05, 2011 Posts: 120 Location: Garijp, the Netherlands
Posted: Thu Jul 25, 2019 2:19 am Post subject: Re: What's the difference in these AA Performance Products 36hp P/C |
as far as I can see compression height difference... has a different partnumber as well, end with a P _________________ 1192CC WW okrasa
48,2 DIN PS (58SAE HP)@4430rpm - 83Nm@3610rpm |
