Skulptorchaz Samba Member
Joined: June 11, 2013 Posts: 839 Location: S.E. Indiana
Posted: Thu Aug 01, 2019 11:24 am Post subject: Unlevel front end. Reasons?? |
This is front of my buggy. I have about 1.25'' difference in height from one side to the other. Passenger side sags. The back is perfectly flat.
Is there some sort of adjustment to straighten this (I'm certainly not familiar with one) or could the springs be bent or ???
I measured points between king pin compared to the h-beam on both sides and it seems to be between them so I'm guessing it has something to do with the springs. The arms do not appear to be tweaked at all.
Thoughts?
Thanks. |
cbeck Samba Member
Joined: January 14, 2014 Posts: 2494 Location: high ridge, mo
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20365 Location: Just a tiny bit west of Yosemite Valley
Posted: Thu Aug 01, 2019 11:34 am Post subject: Re: Unlevel front end. Reasons?? |
Front beams or frame head is bent.... There is no individual adjustment on standard beam.... Also possible broken spring "leaf"... Or possible to much down pressure on rear torsion bar will force direct opposite (diagonal) corner down.... But if rear sits level I would not suspect rear torsion preload....
Bkhansen93 Samba Member
Joined: July 14, 2018 Posts: 207 Location: Coal City, Il USA
Posted: Thu Aug 01, 2019 12:24 pm Post subject: Re: Unlevel front end. Reasons?? |
I had this issue. Couldn't find a clear cut cause after dissecting and looking and measuring. I temporarily fixed it by putting stiffer shocks on the front. doesn't affect the ride too much. |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8689 Location: Sunset, Louisiana
Posted: Thu Aug 01, 2019 1:20 pm Post subject: Re: Unlevel front end. Reasons?? |
Get the rear up in the air and level on 2 jack stands under the rear torsion housing. Raise the front with a floor jack from the center. This should tell you if the frame/tunnel is twisted. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
joescoolcustoms Samba Member
Posted: Thu Aug 01, 2019 5:52 pm Post subject: Re: Unlevel front end. Reasons?? |
Since the rear torsions are much heavier, and there is more weight on the rear, a one side sagging rear can cause the front to tilt. Often leveling the rear will level the front. I have done it several times on buses, beetles, Ghias, and buggies.
Also, a, or a few broken front torsion leaves in the beam on one side can cause it to tilt.
I suggest taking a 4 foot level, locating a concrete slab that is level, park the buggy, not in gear, no parking brake set, push forward empty, push backward to settle the suspension, than have a good look see at both the front and rear.
What I see in the photo is a beam that is not level with the ground. If the chassis is not twisted, the rear torsion tube will have the same slant. Use a floor jack on the down rear side to jack on the edge of the torsion tube to bring it up to level, then re-evaluate the front. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Thu Aug 01, 2019 6:13 pm Post subject: Re: Unlevel front end. Reasons?? |
Q-Dog wrote: |
Get the rear up in the air and level on 2 jack stands under the rear torsion housing. Raise the front with a floor jack from the center. This should tell you if the frame/tunnel is twisted. |
Ditto...
