sanhozeezee Samba Member
Joined: June 17, 2019 Posts: 171 Location: SF Bay Area
Posted: Mon Aug 05, 2019 7:50 am Post subject: help with strange tapping sound on 67 1600 dp motor |
so recently my 67 started to make this weird noise on the left (drivers) side. i adjusted the valves #1 exhaust valve seems to have stuck with about .004 clearance and won’t adjust no matter how far i back out the set screw. other than that the others were fine.
power seems all there just the tapping sound. any ideas what to check?
btw, here’s a video i found of another persons 67 dp motor that’s making the exact same sound.
YDBD Samba Member
Joined: February 25, 2017 Posts: 891 Location: Bavaria, Germany
Posted: Mon Aug 05, 2019 8:00 am Post subject: Re: help with strange tapping sound on 67 1600 dp motor |
If it does it when cold, it just a loose valve adjuster, if stock set to .006". Drive and get it to operating temp, it should stop. If it doesn't then it's a possible exhaust leak, replace gaskets. _________________ '56 pan Dune Buggy since '69
don't live in the past...but when I did:
'67 bug
'64 baja
'60 dune buggy
'73 Personenkraftwagen Type 182 "Thing" |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3817 Location: Georgia
Posted: Mon Aug 05, 2019 8:03 am Post subject: Re: help with strange tapping sound on 67 1600 dp motor |
Had to tell from cellphone audio.
I had a similar noise.
Turned out to be the oil pump gear and camshaft slot were were so badly worn that they weren’t meshing and would klunck together at a certain point of the revolution.
Yes that engine seized from oil starvation. _________________ Volkswagen!
(Compression 8.7:1) |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15303 Location: Deep in the 405
Posted: Mon Aug 05, 2019 8:26 am Post subject: Re: help with strange tapping sound on 67 1600 dp motor |
If you have solid rocker shafts you need to adjust the side to side clearance of the rockers. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
Posted: Mon Aug 05, 2019 9:55 am Post subject: Re: help with strange tapping sound on 67 1600 dp motor |
posted on the split bus thread and someone asked to post a video of my motor so here it is.
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Tue Aug 06, 2019 5:39 pm Post subject: Re: help with strange tapping sound on 67 1600 dp motor |
Could it be a exhaust leak?
eQ _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
rodjr Samba Member
Joined: October 12, 2015 Posts: 223 Location: stanwood washington
Posted: Tue Aug 06, 2019 6:03 pm Post subject: Re: help with strange tapping sound on 67 1600 dp motor |
sanhozeezee wrote: |
So, #1 exhaust lash does not change if you back the adjuster off? |
ekacpuc Samba Member
Joined: December 08, 2010 Posts: 1414 Location: ketchikan alaska
Posted: Tue Aug 06, 2019 8:19 pm Post subject: Re: help with strange tapping sound on 67 1600 dp motor |
Yeah I would be more concerned with that than what sounds like an exhaust leak.
Top video sounds like lash. Bottom one I would ALMOST bet money that it's an exhaust leak. Doesn't have to be at the head either (that's where I would start) but could be any of the other connections or even a hole that you can't easily see. |
Posted: Mon Aug 12, 2019 7:38 pm Post subject: Re: help with strange tapping sound on 67 1600 dp motor |
thanks guys. i have the bus on stands at the moment working on the brakes. i'll try and hunt down exhaust leaks. any idea where i can check? i noticed the intake boot (orange joiner) is cracked in multiple places. this thing is like a flippin' onion! |
within.1 Samba Member
Joined: October 25, 2017 Posts: 179 Location: Pennsylvania
Posted: Tue Aug 13, 2019 5:47 am Post subject: Re: help with strange tapping sound on 67 1600 dp motor |
If no1 exhaust valve rocker adjust screw wont back out no more then 4 thous i would take the rockers off that side and put a straight edge across the valve tips they should be all even if no1 exhaust is longer its either the valve is stretching or a sunken seat any one is no good and should be repaired asap as far as the strange sound i would be checking the rocker side play as well as a exhaust leak |
Davada66 Samba Member
Posted: Sat Aug 17, 2019 8:18 pm Post subject: Re: help with strange tapping sound on 67 1600 dp motor |
I had the same noise and it was the cam double thrust bearing had burned the shoulders off the bearing and the cam was sliding back and forth banging on the shoulders of the cam seats. Its a tear down to fix a 12 dollar part that did not have enough lash between the gear it needs to be 6thousants or the oil can't get in between the faces causing the shoulders to over heat and disintegrate |
wheel607 Samba Member
Posted: Sun Aug 18, 2019 12:01 am Post subject: Re: help with strange tapping sound on 67 1600 dp motor |
This video you shared is of a single port....not dual port dp as you say. |
