aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Wed Aug 07, 2019 2:54 pm Post subject: Re: Oil Leak - Main Seal |
How’s the crankshaft endplay? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
vwnc Samba Member
Posted: Wed Aug 07, 2019 2:59 pm Post subject: Re: Oil Leak - Main Seal |
End play is .005. I checked it Everytime. |
timvw7476 Samba Member
Posted: Wed Aug 07, 2019 3:07 pm Post subject: Re: Oil Leak - Main Seal |
the mention of valve cover venting mentioned by aerotech from the locked
thread, I'm curious what the leakdown #s are for the new(ish) pistons & cyl.? |
vwnc Samba Member
Posted: Wed Aug 07, 2019 3:16 pm Post subject: Re: Oil Leak - Main Seal |
Letdown numbers is something I don't understand. |
Posted: Wed Aug 07, 2019 3:25 pm Post subject: Re: Oil Leak - Main Seal |
Google leakdown test or differential compression test _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
vwnc Samba Member
Posted: Wed Aug 07, 2019 3:39 pm Post subject: Re: Oil Leak - Main Seal |
Will do. |
SGKent Samba Member
Posted: Wed Aug 07, 2019 6:09 pm Post subject: Re: Oil Leak - Main Seal |
in your photos, what is all the oil that appears to be dripping down the passenger side under the pushrod tubes?
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
vwnc Samba Member
Posted: Wed Aug 07, 2019 10:58 pm Post subject: Re: Oil Leak - Main Seal |
The leak is coming from where the tranny bell housing and engine meet even though the pic suggests differently. It's the angle of the picture. |
vwnc Samba Member
Posted: Thu Aug 08, 2019 6:54 am Post subject: Re: Oil Leak - Main Seal |
Well, I'm troubleshooting case pressure. Took oil filler cap off and ran engine at idle and there is a slight puff when I hold cap loose on filler. I left it off and drive a couple of miles and the stopped the bus and cut engine off. Looked underneath 5 minutes later and still have oil dripping between tranny and engine. So in my mind, it's either blow by rings, broken ring (s), or an undetected crack in my new as41 case. Engine doesn't appear to be burning oil. Any thoughts would be appreciated. Jay |
Joined: January 01, 2007 Posts: 16883 Location: sticksville, ct.
Posted: Thu Aug 08, 2019 7:06 am Post subject: Re: Oil Leak - Main Seal |
lets try this again:
skills@eurocarsplus wrote: |
what style RMS tool are you using? that shitty one that is a big washer or the nice machined one with the steps in it?
I use the latter. you draw the seal in till it hits the dowels.
also, what flywheel are you using and are you 1000% sure the graphite o-ring is in there perfectly clean? I have spent upwards of 10 mins just cleaning that groove out.
you MUST replace that o ring any time you take the flywheel off.
you're not using any of the tin/paper gaskets on the dowel/tail of the crank are you? |
what tools are you using to install the seal? you never did give an answer. simply tapping a seal in is suicide here for a lot of reasons which I will go in to if you answer the question _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
SGKent Samba Member
just to be sure we are on the same wavelength - you are saying that this whole area that looks like an oil leak is coming from the bell housing? I have never seen that before where it only concentrates on one side like that running back unless it is coming from above. Normally an oil leak in the flywheel area goes straight back in the middle of the bottom. It would be dripping off the case part line area and the oil strainer nuts.
Posted: Thu Aug 08, 2019 7:18 am Post subject: Re: Oil Leak - Main Seal |
So, you drove with the cap off, parked, still had drips.
Are you certain the drips were fresh or could they possibly be residual oil from before?
Get a bottle of UV dye and add that to your oil. Use 1/2 bottle. Any new leaks with be easy to see _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
vwnc Samba Member
Posted: Thu Aug 08, 2019 7:47 am Post subject: Re: Oil Leak - Main Seal |
Aeromech, I drove it several times and stopped it hoping for less oil dripping results. It's about the same. I've probably have reworked 20 vw engines over the years and never ran across this issue. I'll try the dye and pull motor and see. I really appreciate your input. |
Posted: Thu Aug 08, 2019 9:36 am Post subject: Re: Oil Leak - Main Seal |
evidently you're not going to answer.
best of luck _________________
Jake Raby wrote: |
Brian wrote: |
SGKent Samba Member
Posted: Thu Aug 08, 2019 9:57 am Post subject: Re: Oil Leak - Main Seal |
best of luck |
Skills asks a valid question. That said, here is the issue I am having. The leak is supposedly coming from the main seal. Ok. I accept this is the PO's verdict. However in 500,000 miles in a 1971 bus I have seen almost all the oil leaks from unusual places - oil sender, distributor, cracked case behind #3, shims cut thru to the dowel pins on the crank etc. And I have seen main seal leaks on occasion. What I have never seen on a main seal leak is oil that doesn't drip out the bell housing right at the center and blow straight back all over the part line area and oil strainer. All I see in this photo is oil coming out on the 3-4 side and none in the center of the bell housing. What am I missing here? Yellow arrow is where the oil looks to be. White is where a main seal leak appears usually.
vwnc Samba Member
Posted: Thu Aug 08, 2019 9:59 am Post subject: Re: Oil Leak - Main Seal |
I installed the main seal with the big washer with gland bolt until it tighten slightly. I then took a small round block of would and gently tapped it in until is was all the way back into the case. I've done this on other builds with no issues. |
vwnc Samba Member
Posted: Thu Aug 08, 2019 10:04 am Post subject: Re: Oil Leak - Main Seal |
sgkent, the oil is leaking behind the flywheel and dripping down in middle of split in crankcase where the case and tranny meet. The yellow tint you are pointing to is dry even though it looks wet. |
Posted: Thu Aug 08, 2019 12:01 pm Post subject: Re: Oil Leak - Main Seal |
vwnc wrote: |
ok...here's the deal. toss that washer in the trash and get this:
https://www.amazon.com/DELUXE-FLYWHEEL-SEAL-INSTALLER-buggy/dp/B003LIRJHK
it is far better than the washer.
I agree with steve...almost looks like oil cooler seal. RMS will piss out bad at the notch in the case to trans interface. _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Fri Aug 09, 2019 11:17 am Post subject: Re: Oil Leak - Main Seal |
The dye should lead you to the source
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
vwnc Samba Member
Posted: Fri Aug 09, 2019 1:39 pm Post subject: Re: Oil Leak - Main Seal |
Thanks areomech. |
