Carb screws
zabo
zabo is offline
PostPosted: Sat Aug 10, 2019 12:47 pm    Post subject: Carb screws Reply with quote
anybody have tips.for removing the screws on the throttle butterfly plate?
disassembeling a few and keep running into trouble there.
1960 6 volt sedan- 1978 adventurewagen
–wanted bill spreen atlanta dealer tag frame
kreemoweet
kreemoweet is offline
PostPosted: Sat Aug 10, 2019 4:07 pm    Post subject: Re: carb screws Reply with quote
Those screws are staked by the factory on the non-head end after being screwed into the shaft. Trying to remove them without
removing the staking as best you can with a dremel or similar tool frequently results in damage to the threads in the shaft or
the screw, or both. Doing that also makes their removal vastly easier, and reduces liklihood or damage to the screw-head slots.
'67 bug: seized by the authorities
zabo
zabo is offline
PostPosted: Sat Aug 10, 2019 5:29 pm    Post subject: Re: carb screws Reply with quote
thanks.
zabo
zabo is offline
PostPosted: Tue Aug 13, 2019 8:43 am    Post subject: Re: Carb screws Reply with quote
well i removed the staking and the screws still wouldn't budge.
Soaked with PB blaster over night- no dice.
I ended up filing down the screw heads and then carefully drilling out the screws.
Luckily the threads in the shaft remained intact. Smile
bluebus86
Banned
bluebus86 is offline
PostPosted: Wed Aug 14, 2019 7:17 am    Post subject: Re: Carb screws Reply with quote
just be sure to stake down the replacements, these screws must not be allowed to fall out! Staking them is critical for success!
Bug On!
zabo
zabo is offline
PostPosted: Wed Aug 14, 2019 7:23 am    Post subject: Re: Carb screws Reply with quote
whats the best way to stake them? - seems hard to access that side if i were to use a punch or something. –28pci carbs
red loctite?
bluebus86
Banned
PostPosted: Wed Aug 14, 2019 1:12 pm    Post subject: Re: Carb screws Reply with quote
red loctite?
Place a long enough drift or steel rod sticking up in a vice, this will be the anvil. Then get an assistant to hold the carb, assembled and ready to stake, hold carb such that head of screw is resting FIRMLY and centered well over the anvil, over the vice. Now you take a chisel or punch and using a hammer make the stake on the opposite end of the screw, which should be straight up and down, with its head on the anvil.
Doing this will assure the butterfly shaft does not get bent during staking. Avoid bending the shaft!
Bug On! Like you have a big stake in it!
Dont get bent!
I"ll have mine medium rare!
Pass the A1 please.
Meiang Premium Member
Meiang is offline
PostPosted: Fri Aug 16, 2019 8:13 am    Post subject: Re: Carb screws Reply with quote
I believe the carurettors were staked using a jig to prevent damage to the shaft.
Personally I would resist staking the screws and use Loctite 243 during the assembly. Loctite 243 is fuel resistant and will allow disassembly at a later stage.
There has been enough anecdotal evidence over the years to indicate that this method works well with losing screws into the engine.
