Best replacement front rubber floor mat?
Thompson2
Thompson2 is offline
PostPosted: Mon Aug 12, 2019 4:43 pm    Post subject: Best replacement front rubber floor mat? Reply with quote
Mine managed to rip itself in half when I picked it up from one end (therse things are old... make sure you support it well when you pick them up), so I was scoping out what my stupidity was going to cost...
Looks like they're available from multiple vendors (WW, CIP1, VWISP). All of them are within a few bucks of each other. Anyone have experience with more than one of these? Wondering how they compare...
WW says they make theirs, so do the other vendors buy from them or are there multiple companies making these?
Thanks!
sgellis
sgellis is offline
PostPosted: Mon Aug 12, 2019 4:50 pm    Post subject: Re: Best replacement front rubber floor mat? Reply with quote
I got mine from CIP1.
https://www.cip1.ca/ProductDetails.asp?ProductCode=C24-211-863-711-E
Seams good quality but I don't have an original to compare it to. Had to cut out the dimmer switch though.
My 64 Kombi restoration
My camper interior build
zozo
zozo is offline
PostPosted: Mon Aug 12, 2019 5:29 pm    Post subject: Re: Best replacement front rubber floor mat? Reply with quote
I got mine from WW about a dozen years ago. Itís held up very well. Pretty heavy, waffle back. Zero negatives aside from, as was mentioned, the dimmer switch hole has to be cut.
Thompson2
PostPosted: Wed Aug 14, 2019 9:55 am    Post subject: Re: Best replacement front rubber floor mat? Reply with quote
Any idea why they don't cut them out? And in the area that needs to be cut, is the mat flat on the back or "waffled" like the main portion?
nlorntson Premium Member
Crazy VW Lady
nlorntson is offline
PostPosted: Wed Aug 14, 2019 10:24 am    Post subject: Re: Best replacement front rubber floor mat? Reply with quote
Maybe to accommodate the 66 and 67 buses that don't use a floor mounted switch?
sgellis
sgellis is offline
PostPosted: Wed Aug 14, 2019 12:10 pm    Post subject: Re: Best replacement front rubber floor mat? Reply with quote
Mine was. No big deal to cut out the "waffle" and then make the hole.
https://www.thesamba.com/vw/forum/viewtopic.php?t=...;start=713
Thompson2
PostPosted: Wed Aug 14, 2019 2:20 pm    Post subject: Re: Best replacement front rubber floor mat? Reply with quote
That would make sense. I was wondering which years didn't have them. Guess is was too much trouble to make 2 versions..
Perfect! I've decided to attempt a repair on this one, but if that goes south or is horribly unsatisfactory, I have options.
I just need to find a couple of chunks of a roached one to fix the holes worn by the POs heels...
