Type 4 engine vs Upgraded Type 1
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Aug 13, 2019 3:26 pm    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
FreeBug wrote:
Maybe it's just me, but here's something I just don't get: people are putting big $$$$ into their engines, etc, but even the best builds here don't have a decent rear apron. At those prices, I would expect well-molded front and back "tins", to make the compartment airtight, like stock.
I'll probably be told that id doesn't matter to any measurable extent, but still, wouldn't you like something like that?
I do understand that the front "tin" is hard to make in fiberglass, owing to thickness issues, and the plethora of pulleys available. But still...
Because they are STOCK. All stock OE German tins.
Glenn
Member #1009
#BlueSquare
jpaull
jpaull is offline
PostPosted: Tue Aug 13, 2019 4:09 pm    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
H2OSB wrote:
APPLEGREENVW wrote:
I don't see anything ugly this photo. Cool Drool
I'm with Vamram...I want this engine. It's beautiful. Imagine it as a 1911 with 36 Dells, or a 2056 with 40s.
H2OSB
Very true. Its best one ive seen. It still looks like a VW. I have noticed alot of german look cars that have a type 4, and owners bragging about their "Porsche Powered" bug. But isnt the type 4 a VW? VW Logo
[email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth.
Mr. 010
Glenn is offline
PostPosted: Tue Aug 13, 2019 4:12 pm    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
Type 4 = 914
Glenn
Member #1009
#BlueSquare
jpaull
jpaull is offline
PostPosted: Tue Aug 13, 2019 4:16 pm    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
Glenn wrote:
Type 4 = 914
Isnt a 914 engine a VW engine that also comes in VW buses?
Wreck
Wreck is offline
PostPosted: Tue Aug 13, 2019 4:17 pm    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
I agree , it is where the top end kits (CSP & DTM) really drop the ball . Sharpbuilt has all the rest of the "Tin" molded in fibreglass shaped like a type one . http://www.sharpbuilt.com.au/sharpbuilt1/page11.htm
But if you use his kit you have the ugly oil filler Very Happy That's why I made my own centre mount with intergral breather tower/AC compressor mount with oil filler . It's all satin black so hard to get a good photo. Also the custom should is centred on the cylinders .
Anyone making there own conversion using Joe's manual can cut down type 1 tin to fit . The joining flange between the upper and lower cylinder tins is the perfect height for type 1 front and rear tins . The breast tin behind the pulley can also be modified to fit .
On the mention on pulleys have a look at the pulley ratio on my upright conversion with the type1 fan on the first page. That is on a 2.6 liter with 10.5 comp making approx 165whp , it is a true daily driver and CHT's stayed cool (140C) when driving in peak hour stop start traffic for 40minutes in +30C tropical summer temps . (measured with an MGL TC-1 with omega sensors on each cylinder ). I'd be surprised if any NA type1 making 200HP could do that on a daily basis and have a good life span .
Erik G
Erik G is offline
PostPosted: Tue Aug 13, 2019 4:18 pm    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
FreeBug wrote:
Erik G wrote:
since everyone is talking about fans, and I learn a lot from this forum
I can see for drag racing, but daily use? Seems... sketch
https://www.thesamba.com/vw/classifieds/detail.php?id=2269517
I find it very hard to imagine that working on a DD.
Right? But who drag races a type4?
Wreck
Wreck is offline
PostPosted: Tue Aug 13, 2019 4:25 pm    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
jpaull wrote:
Glenn wrote:
Type 4 = 914
I'm surprised Ray hasn't chimed in . The type 4 was developed for the VW Type 4 car first . 1700cc . then it went into the bus and 914 joint venture . the 1700 ,1800 type 4's are mostly all the same spec between the makes . the 2lt 914 type 4 got different heads to boost performance . they changed the spark plug angle and gave it bigger valves and a slightly changed exhaust port . I believe the intake manifold runners were bigger than the 2lt bus engine .
Mr. 010
Glenn is offline
PostPosted: Tue Aug 13, 2019 4:31 pm    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
jpaull wrote:
Glenn wrote:
Type 4 = 914
Glenn
Member #1009
#BlueSquare
jpaull
jpaull is offline
Wreck wrote:
jpaull wrote:
Glenn wrote:
Type 4 = 914
Sounds like when someone says their Type 4 is made by Porsche they are just trying to sound cool. But if Porsche actually manufactured Type 4 engines someome speak up.
Wreck
Wreck is offline
PostPosted: Tue Aug 13, 2019 4:59 pm    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
jpaull wrote:
Wreck wrote:
jpaull wrote:
Glenn wrote:
Type 4 = 914
I really don't know why people want to make people think their engine is a Porsche . I much prefer the look on a face when you've smoked them at a set of lights and they ask if it's got a Porsche engine and the reply is "It's just an old VW engine " Very Happy Very Happy Very Happy .
Mr. 010
Glenn is offline
PostPosted: Tue Aug 13, 2019 5:02 pm    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
I tell them why would I want to pay 4 times as much for 1/2 the horse power.
I'm pricing a rebuild of a 912 engine. Pistons and cylinders are $600 per.... OUCH.
Glenn
Member #1009
#BlueSquare
jpaull
jpaull is offline
PostPosted: Tue Aug 13, 2019 5:04 pm    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
Wreck wrote:
jpaull wrote:
Wreck wrote:
jpaull wrote:
Glenn wrote:
Type 4 = 914
Yeah thats what im talking about 💪 VW Logo 💪
LivinInnaVWBus
LivinInnaVWBus is offline
I emailed him a few weeks ago.
"Yes this system was designed for the street the motor in the add is a 2.666L daily driver
Thanks Mr.Bill"
VintageFilm
VintageFilm is offline
PostPosted: Tue Aug 13, 2019 5:13 pm    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
I sure like my little 1.8 type4. Old photo but still looks a bit like this.stays cool in the SoCal summer. Gobs of power and torque, a very happy little motor in a 63 rag.
Grace McKay
vintagefilmchannel.com
electricpictures.tv
1963 Type 4 Ragtop
oprn
oprn is offline
PostPosted: Tue Aug 13, 2019 6:16 pm    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
Wait a minute - I thought the 912 engine was the same as the 914, 411, 412 and the Bus. Why the price difference?
raygreenwood
raygreenwood is offline
PostPosted: Tue Aug 13, 2019 6:20 pm    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
Actually.....technically.....its a VW engine. As noted...it came in the VW 411 first. But it is also the exact same engine to the last part number....as the type 4 engines that NEXT went into the Porsche 914 ( in 1.7L and 1.8L displacements). The only differences are sheet metal and exhaust manifolds.
The 2.0L engine .....914 specific....was the only one that was a Porsche only version of the engine. Different pistons, heads, sheet metal, intake system....and in Europe....a different cam. So yes....technically....if you have a 2.0L Porsche 914 engine....you DO have a Porsche engine.
And....on which factory floor its made has little difference. Its like saying the Ford "Cologne" V6 that went into more brands than Ford....makes those cars either Ford's or German built.
And.....the type 4 was NOT a bus engine. It was LATER made into a bus engine. The versions in the bus....whether 1.7L, 1.8L or 2.0L.....were only the same as 411, 412 and 914 Porsche.....in the overall case castings. 1.7 and 1.8 head castings, crank and rod forgings....were the same. Pistons, cams, induction, ignition, tuning...were a good deal different.
Though the bus engines are "detuned"....they are made the way they need to be for a 4000 lb low geared loaf.
But opt for half hp?....stock at least....about the best that type 1s put out was what....58hp? Maybe 62 hp?....and you could overheat them with extended 65 mph driving in hot climates?....and they typically need a valve job at 50-70k....and have a "best running" service life before a refurb (not a total rebuild).....of 80-100k?
The type 4 is really just the type 1.....that finally got all of the improvements VW learned from building what.....15 million vehicles between about 1949 and 1966 when type 4 hit the drawing boards (it came out in the 411 in 1968).
But.....it has no need for "hoover mods". They are built in. It already has ratio rockers from the factory (1.3:1). Larger oil cooler with dedicated air supply, larger oil galleys, larger crank webs in the case, 40% more head cooling fins, full flow oil filter, crank fed fan....no belts, larger displacement across the board, they rarely need align bore due to better case alloy, no case cracking issues.
All of them came with alternator. All of them came with either twin carbs or fuel injection.
So why would you want one?....well....in type 4 cars....not so much buses....these are typically 150,000 mile engines. No half life valve job needed. Of course all of this dependent on how well you care for it. All day everyday high speed highway in hot weather....no problem. Better low end torque than any of the STOCK type 1 motors....and generally better heating even without gas furnace. And roughly 1.75x tbe hp of the basic bug out of the box.
In the 411/412 and 914...
In the injected 1.7L....82hp
In the injected 1.8L (smog) 76hp....what a detuned waste...because
In the Euro 412 1.8 with twin carbs.....about 85
A 1.8L with proper compression and ignition with stock injection....about 90hp
914 2.0 with injection...same exact injsction with same exact parts as 1.7L except injectors.....95hp.
Euro version with only a cam change and +0.4 compression ratio change....an honest 100hp.
So.....having some versions of a type 4 engine in your car....and calling it a Porsche engine....if its at least Porsche spec.....I have little problem with. Having a beat out 1.8 bus motor in your bug and calling it a Porsche engine.....I have an issue with.
I also keep wondering....not beating on anyone.....if you are NOT racing (thats a different deal).....how you can get hung up in "cost per HP" calculations. You are in the wrong hobby if you are looking at it that way and you are not racing. Ray
Mr. 010
Glenn is offline
PostPosted: Tue Aug 13, 2019 6:33 pm    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
The 912 engine was an evolution of the 356 engine.
The 9176 912E was a 914/T4 put in a stripped down 911.
1966 912 engine
Glenn
Member #1009
#BlueSquare
Mikedrevguy
Mikedrevguy is offline
PostPosted: Tue Aug 13, 2019 6:39 pm    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
I’ve had several T4/Porsche 914 motors fall into my lap.
I’ve 2 2L and an 1.8L and a shell to build up. I’ve a pair of 2L pair of 3bolt heads (1 rebuilt) and a single 3bolt head. Plus, I’ve a line on components for. 2800.
Would I be foolish to not make use of the resources I’ve been given?
74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!!
nextgen
nextgen is offline
PostPosted: Tue Aug 13, 2019 6:54 pm    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
To make is simple, THe 914 was to be called a VW in the U.S and a Porsche with the 6 cylinder in Europe.
Well the it was only a verbal agreement and the head of VW died. The new guy said both engine the 4 and the 6 in the U.S will be under the Porsche name.
The T-4 came out in 1968 in the 914 later in 73 it went into buses.
So is it a Porsche or is it a VW. Is the Rabbit a VW or an AUDI
Is the Toyota BRZ a Subaru or a Toyota
Is the Toyota Supra A Toyota or a BMW
Is the Porsche 912e with a T-4 engine a VW or a Porsche
The 1.7 914 had 80 hp 20 more HP the the most powerful T-1
The 1.8 914 had 84 hp
The 2.0 914 had 100 hp
A fact most guys don't know is the 914-6 was only 2.0 and had only 109 hp
the 914 was almost as fast except on top end.
The 914-6 in one year won 11 out of 12 races, and that one year came in 2nd.
Soooooooo, What engine do you want in your bug does it really matter if it is a Porsche or a VW - it is the HP ya want.
My engine I bought at Manhattan Porsche in NYC - Unused Training engine.
I took the Porsche Emblem off my crashed 914 and put it on my engine.
Porsche sold it as a porsche.
email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs
LivinInnaVWBus
PostPosted: Tue Aug 13, 2019 7:08 pm    Post subject: Re: Type 4 engine vs Upgraded Type 1 Reply with quote
Last edited by LivinInnaVWBus on Tue Aug 13, 2019 7:34 pm; edited 3 times in total
Page 3 of 6
