nmerrill Samba Member
Joined: January 07, 2014 Posts: 388 Location: Vermont
Posted: Sun Aug 18, 2019 6:12 am Post subject: Engine cover re-insulation project- fire in mind |
So, after touching a lighter to a piece of factory lid foam insulation, and watching it catch fire and burn on its own in less than a second, I decided to try something else.
I had seen the link to a product on another thread, and looked into it.
The supplier said that particular product (a PET coated fiberglass) had poor flame contact resistance.
I was pointed towards this product:
Aluminum Foil Coated High Temperature & Radiant Heat Reflective
Fabric / Cloth: MIL Spec & Standard
300°F / 149°C DeltaGlass™ Continuous Standard Grade and 500°F / 260°C
Continuous (600°F / 315°C Intermittent) High Temperature Grade
https://www.abthermal.com/pdffiles/F/F-FG-AL-Fabri...ective.pdf
I also was pointed towards this:
http://www.firesleeveandtape.com/AB-Thermal-catalog-IM-FG-NEEDLED.pdf
To be used as sound insulation, and further heat resistance. I used the 1/2 in material.
My dilemma was how to attach it to the lid.
I didn't think adhesives were going to be a good option, so looked for something else.
I settled on these:
https://www.belmetric.com/metal-hardware-c-12_128_130/d10937-vw-retainer-p-5827.html
And 16mm truss head sheet metal screws
The sound insulation material handled very nicely- cut cleanly with a razor, and held its shape well.
I draped the second fabric over the top, then drilled holes through the whole assembly for the sheet metal screws.
The retainers just caught the 16 mm screws after squishing the sandwich some.
I left the fiberglass fabric long, and used a high temp (wurth) spray adhesive to secure the edges to the flange of the lid. As can be seen, I simply covered right over the rubber seal. I figured this helped reduce the rubber seal as a fire pass through.
Time will tell if this was a good option!
It still sits in place just fine, and the latches close as before.
I was concerned from the beginning about the thermal pass through of the screws, but tried it anyway.
Turns out I was right to worry!
First drive resulted in the screw heads on the top side being very hot!
I went back and covered the retainers with another product I had that was similar (fiberglass with foil cover) but had adhesive already applied to it.
Before I did this, I touched the tips of all the screws with a disc grinder to take the sharp off.
This significantly reduced the temp of the screw heads, but they are still quite warm.
Overall, the experiment worked out pretty good, though I do think there could be a better way to adhere the materials to the lid. But, I'm sure my lid is way more fire-proof than it was. |
Corwyn Samba Member
Joined: December 29, 2009 Posts: 2238 Location: Olympia, Washington
Posted: Sun Aug 18, 2019 8:12 am Post subject: Re: Engine cover re-insulation project- fire in mind |
That's a lot of work for a fireproof engine cover. Why not work on preventing a fire altogether (fuel lines, etc)? _________________ '90 White Westy ("The Longship")
FAS Gen V 2.0
The Annual Baja Rally
~ Captain Ron ~ |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6832 Location: Fort Lauderdale, Fl.
Posted: Sun Aug 18, 2019 8:16 am Post subject: Re: Engine cover re-insulation project- fire in mind |
Good job. Time well spent.
Since your thread title is good for searches let me ad a link to this material I also came across:
https://www.thesamba.com/vw/forum/viewtopic.php?t=722193&start=40
Question: How much weight did it add the engine cover? _________________ This free advice is worth exactly what you paid for it.
Zeitgeist 13 Samba Member
Posted: Sun Aug 18, 2019 9:47 am Post subject: Re: Engine cover re-insulation project- fire in mind |
That’s some good info, which I’ll use as I enjoy the privilege of redoing my half-assed hatch soundproofing job. As a cautionary note, I strongly suggest folks don’t use the HF padding like I did. I recently was welding in rust repair panels and used the stuff as a kneeling pad. It ended up looking like the craters on the moon from all the welding splatter.
Works fine as a sound deadener, but won’t cut it in a fire. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Sun Aug 18, 2019 11:46 am Post subject: Re: Engine cover re-insulation project- fire in mind |
Corwyn wrote: |
That's a lot of work for a fireproof engine cover. Why not work on preventing a fire altogether (fuel lines, etc)? |
That's all new - everything, every last bit.
I don't believe 2 hours in the shop is significant, particularly when I don't believe in "altogether" |
Posted: Sun Aug 18, 2019 11:50 am Post subject: Re: Engine cover re-insulation project- fire in mind |
Whole lid weights 16 lbs - not sure what it did before. |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9609 Location: Western WA
Posted: Sun Aug 18, 2019 1:55 pm Post subject: Re: Engine cover re-insulation project- fire in mind |
nmerrillthere's def'n something to be said for protecting that foam from a fire.
A simple task that increases the amount of time you have to fight a fire, is time well spent.
You got me thinking about a thin sheet of aluminum.
It wouldn't be sealed, but mostly covered.
0.025" Aluminum Sheet 5052-H32 - Part #: 7124
24.0" X 48.0" - $20.54 ea + shipping (or will-call here in Seattle)
https://www.onlinemetals.com/en/buy/aluminum-sheet
I'd want the cover to be easy to use the rest of the time I dive under it (ie mostly "unchanged).
And being a Vanagon, thats kinda often.
.025*23.25*40.5*.1====> 2.3 lbs of aluminum added to the plastic cover.
Not sure how to attach it yet....
nmerrill I see you really sealed yours against the licking flames.
And it's "sound absorbant" whereas an aluminum might be noisy.
But it IS outside the van, and the foam remains. _________________
....KTMs, GasGas, SPOT mtb |
jimf909 Samba Member
Posted: Sun Aug 18, 2019 2:20 pm Post subject: Re: Engine cover re-insulation project- fire in mind |
Bostigs have an aluminum heat shield with hooks inserted into the (apparently highly flammable) foam:
As for the heat transfer through the screws, how about epoxying some studs to the underside of the lid which would poke through the fabrics and then attach the fasteners? _________________ - Jim
Abscate wrote: |
Posted: Sun Aug 18, 2019 2:28 pm Post subject: Re: Engine cover re-insulation project- fire in mind |
Yikes!!! As long as I had my cover off I thought I'd do a burn test. These theee photos may have been taken w/in one second. Flame and toxic smoke ensued.
Looks like we always have fire starter for the next camp out. _________________ - Jim
Abscate wrote: |
Sodo Samba Member
Posted: Sun Aug 18, 2019 3:18 pm Post subject: Re: Engine cover re-insulation project- fire in mind |
What Corwyn is recommending is reasonable. To advance the Vanagon to be as "fire-safe" as the 99.9% of other cars on the road, is the higher goal than minimizing the fuels (the foam etc).
I would LOVE to be so confident to feel no need to minimize engine compartment combustibles. _________________
Posted: Sun Aug 18, 2019 5:12 pm Post subject: Re: Engine cover re-insulation project- fire in mind |
Sodo, I thought about something similar- and I think that would be a pretty good solution.
I couldn't go this route myself since I had already removed my foam!
Obviously, this does leave the rubber gasket exposed though.
Something else could be done to help there I'm sure |
Posted: Sun Aug 18, 2019 5:24 pm Post subject: Re: Engine cover re-insulation project- fire in mind |
I strongly suspect the dimpled surface of the foam contributes to the sound-deadening qualities, so a hard smooth surface might just turn the space into an echo-chamber. _________________ Casey--
y u rune klassik? |
Posted: Sun Aug 18, 2019 5:26 pm Post subject: Re: Engine cover re-insulation project- fire in mind |
There are about 171,000 highway vehicle fires per year which account to 13% of all fires the FDs respond to. Mechanical and electrical failure account for 65% of highway vehicle fires.
According to FEMA..,
https://www.usfa.fema.gov/downloads/pdf/statistics/v19i2.pdf
While Vanagons certainly burn, there are plenty of Honda's and Toyota's on an image search in Google.
https://www.google.com/search?q=highway+vehicle+fi...mp;bih=549
I agree that prevention/reduction is important and it seems that removing this flammable foam is a reasonable tactic.
A few weeks ago I was stopped at a stop light on my 42 year old motorcycle and white smoke started billowing out from behind the fairing. Fortunately, there's not a lot that's quickly flammable so I was able to yank on the harness and eliminate the short to calm it down. Had the foam been there...
Fire bad. _________________ - Jim
Abscate wrote: |
Posted: Sun Aug 18, 2019 5:27 pm Post subject: Re: Engine cover re-insulation project- fire in mind |
jimf909 wrote: |
A few weeks ago I was stopped at a stop light on my 42 year old motorcycle and white smoke started billowing out from behind the fairing. Fortunately, there's not a lot that's quickly flammable so I was able to yank on the harness and eliminate the short to calm it down. The harness is melted back to the coils at the back of the underside of the gas tank. Had the foam been there...
Fire bad. |
Abscate wrote: |
Sodo Samba Member
Posted: Sun Aug 18, 2019 5:46 pm Post subject: Re: Engine cover re-insulation project- fire in mind |
jimf909 wrote: |
While Vanagons certainly burn, there are plenty of Honda's and Toyota's on an image search in Google. |
It’s feasible that fires are more prevalent in vehicles that run long enough to get worked on under the shade of a tree.
There was a point where Vanagons were thought of as another modern disposable car, thus received substandard care during that era.
Or cars that have “internet forums” that keep them on the road “longer than normal”.
Or vehicles wrenched on as a learning exercise etc.
Westfalia has a mattress ontop of the engine cover, hard to believe messing around below 5 inches of foam will be audible. And its easy enough to switch back with another Vanagon to compare sound. _________________
danfromsyr Samba Member
Posted: Mon Aug 19, 2019 5:43 am Post subject: Re: Engine cover re-insulation project- fire in mind |
real world results
I've had 2 vans come through my garage who had engine compartment fires.
and wile the fiberglass lid did eventually succumb to the fire(s) it was certainly not a spontaneous combustion. they in fact delayed the fire from entering the passenger compartment in about the time that you would hope/expect.
a proper method to FIGHT an expected fire would be more prudent..
maybe remove the spring from the license plate door inlieu for a HD magnet. so when you go to spray the extinguisher in there it's not fighting you.
also a blazecut or other on board automatic retardant _________________
Abscate wrote: |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Mon Aug 19, 2019 1:27 pm Post subject: Re: Engine cover re-insulation project- fire in mind |
danfromsyr wrote: |
That's a good idea right there, I think I'll be doing that in the next couple days. Thank you. _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
?Waldo? Samba Member
Posted: Mon Aug 19, 2019 3:14 pm Post subject: Re: Engine cover re-insulation project- fire in mind |
danfromsyr wrote: |
...maybe remove the spring from the license plate door inlieu for a HD magnet... |
I like the thought of a mini gas strut placed appropriately to both hold the door in the closed position and hold it in the open position. |
Posted: Mon Aug 19, 2019 4:45 pm Post subject: Re: Engine cover re-insulation project- fire in mind |
Yes, an active fire suppression system is my next project.
My 5 cylinder makes the license plate hatch a bit less access then wbx , but still a good place to shoot into.
Not implying this project was the end-all. Just an experiment in materials that surely could be improved on.
I still think it's better than the OE foam!
Since all my screw heads are in the troughs of the corrugations, I think I'll probably cover them with another layer of something since it won't interfere with anything. |
dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Mon Aug 19, 2019 4:53 pm Post subject: Re: Engine cover re-insulation project- fire in mind |
What do you think the market would bear for an exchange service for engine covers. Cracks in the fiberglass repaired, top refinished in epoxy gloss white. Bottom, engine side, stripped, cleaned and reformed with fire resistant foam in the original eggshell pattern. _________________ Schau in das Buch |
