Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Sat Dec 29, 2018 12:00 am Post subject: Instrument cluster dust cover / foil cover Part No. 251957085B |
No idea why I cannot seem to find information on this... I know how to use the search engine/feature. Seems like there are no photos or information. I need to replace two of these.
Maybe I'm not searching it by the correct name? I call this 'Instrument cluster dust cover' and it rests above the dashboard instruments under the plastic cover.
UPDATED TITLE OF THREAD to help others in their solo quest for militant adherence to stock Vanagon dedication...
Anyone know the part number and where to get new ones?
Last edited by Wasted youth on Sun Dec 30, 2018 2:30 am; edited 2 times in total |
kamzcab86 Samba Moderator
Posted: Sat Dec 29, 2018 12:29 am Post subject: Re: Instrument cluster dust cover - Help with info! |
Part #251957085B
Names:
Mask film for instrument housing
Foil for instrument housing
Drip cover for instrument housing
Abdeckfolie Fuer Instrumentengehaeuse
It's NLA; thus, you may have to source a used one. _________________ ~Kamz
2016 Golf GTI S
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9800 Location: Mt Lemmon, AZ
Posted: Sat Dec 29, 2018 7:08 am Post subject: Re: Instrument cluster dust cover - Help with info! |
Seems to me like it was there because many owners may spill some brake fluid when topping up -- nasty stuff to have splashed about. I still have mine but set it aside when working with brake fluid (so I can see the reservoir) and instead just be very careful and always 'Know where your towel is'. |
Posted: Sat Dec 29, 2018 7:09 am Post subject: Re: Instrument cluster dust cover - Help with info! |
kamzcab86 wrote: |
...Abdeckfolie Fuer Instrumentengehaeuse... |
Really? Sometimes I just love the language of Goethe. |
Posted: Sat Dec 29, 2018 8:19 am Post subject: Re: Instrument cluster dust cover - Help with info! |
kamzcab86 wrote: |
Part #251957085B
Names:
It's NLA; thus, you may have to source a used one. |
Thanks! |
Paulbeard Samba Member
Posted: Sat Dec 29, 2018 11:26 am Post subject: Re: Instrument cluster dust cover - Help with info! |
Mine is long gone…any reason you couldn't roll your own with some cling film, if you are worried about sloshing brake fluid over your wiring? _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1841 Location: Vancouver Island, BC
Posted: Sat Dec 29, 2018 12:57 pm Post subject: Re: Instrument cluster dust cover - Help with info! |
Whenever I plan to play with brake fluid, I wrap everything in a 50 cm radius in rags. I typically roll a rag around the brake reservoir, so any dripping will be caught and absorbed by the fabric. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Posted: Sun Dec 30, 2018 2:19 am Post subject: Re: Instrument cluster dust cover / foil cover |
I never considered it an apron for brake fluid games. Just figured it was a dust cover. As I searched it out with fresh information given by kamzcab86, I keep seeing it referenced as 'foil' and 'foil cover'
Here is the diagram... Item 8
cmayna Samba Member
Joined: August 18, 2014 Posts: 1147 Location: SF Bay area, CA
Posted: Sun Dec 30, 2018 8:50 am Post subject: Re: Instrument cluster dust cover / foil cover Part No. 251957085B |
Item 8 is the plastic guard which you show in your original photo. I've given you two sources for this item. _________________ '90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig |
Posted: Sun Dec 30, 2018 9:34 am Post subject: Re: Instrument cluster dust cover / foil cover Part No. 251957085B |
cmayna wrote: |
Item 8 is the plastic guard which you show in your original photo. I've given you two sources for this item. |
Yes! Thank you for your replies! The point of adding this information is to help other people in the future in their quest. In this thread, I added the part number given by kamzcab86, which led me to the diagram... information that I did not have before and quickly clears up the search.
The Samba search engine is pretty good, so it seems logical to add useful information here. |
creative native Samba Member
Posted: Sun Dec 30, 2018 9:46 am Post subject: Re: Instrument cluster dust cover / foil cover Part No. 251957085B |
Just a few days ago, I saw someone post these for sale in the Samba classified section. I believe they were listed as "plastic dust covers." If I find them, I'll come back with a link. |
Posted: Sun Dec 30, 2018 9:52 am Post subject: Re: Instrument cluster dust cover / foil cover Part No. 251957085B |
creative native wrote: |
https://www.thesamba.com/vw/classifieds/detail.php?id=1998290 _________________ ~Kamz
2016 Golf GTI S
SyncroHead Samba Member
Joined: May 23, 2005 Posts: 1141 Location: Northern Nevada
Posted: Thu Aug 22, 2019 5:21 pm Post subject: Re: Instrument cluster dust cover / foil cover Part No. 251957085B |
Does anyone know of a current source for this "foil", "dust cover" item?
Part no. 251957085B
There's one here:
https://www.thesamba.com/vw/classifieds/detail.php?id=2221319
I was hoping to get one that's new or in better shape than the one in the ad.
None found at GoWesty, Van-Café, or VanAgain.
Bus Depot lists one as "special order" with no photo, so I'm less than confident they can actually supply it.
Jim _________________ "A Vanagon? It's not a car or a van. It's a hobby!"
Check out:
www.VANAVATION.com
www.SyncroSafari.org and
www.Vanagons.org
sphet wrote: |
I have *no* idea what the previous owner carried in his Westy... angry donkeys? |
Posted: Thu Aug 22, 2019 6:43 pm Post subject: Re: Instrument cluster dust cover / foil cover Part No. 251957085B |
SyncroHead wrote: |
...I was hoping to get one that's new or in better shape than the one in the ad... |
That one doesn't appear to be torn, just dirty. I would think some Simple Green and a toothbrush (maybe your wife's) would do wonders with it. |
Brower001 Samba Member
Joined: April 28, 2021 Posts: 5 Location: Brooklyn, NY
Posted: Wed May 19, 2021 8:09 am Post subject: Re: Instrument cluster dust cover / foil cover Part No. 251957085B |
Hi- I’m new to the forum; I’m looking for this dust cover too. I have a little machine shop where I make specialty stuff and I can see from videos and photos of this item that it would be fairly easy for me to reproduce with my vacuum former. Would anyone be willing to lend me theirs so I can make a master to pull the forms from? If they work out we could make lots of them. |
jlrftype7 Samba Member
Posted: Wed May 19, 2021 1:43 pm Post subject: Re: Instrument cluster dust cover / foil cover Part No. 251957085B |
Brower001 wrote: |
If you have no takers, try getting one from a Salvage yard Vanagon, then it's yours to play around with. Getting reproduction versions new would be sweet... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Posted: Wed May 19, 2021 1:49 pm Post subject: Re: Instrument cluster dust cover / foil cover Part No. 251957085B |
yes- I live in a dense city, so all the salvage yards are on my computer! But yeah, in theory even a damaged one could work for me since I'll be making a new tool from it; I can patch it up as long as its geometry is intact. I'll put whatever results I come up with here. |
