TonkaJim Samba Member
Joined: August 07, 2019 Posts: 32 Location: Minnetonka, MN
Posted: Mon Aug 26, 2019 6:27 am Post subject: New build, cylinders 3/4 not responding |
OK, I got the new engine in the Ghia to idle and even drove it around the block a couple of times, but, when I went to tune the dual carbs, I discovered that cylinders 3/4 weren't responding to any speed or mixture adjustments. Cylinders 1/2 responded appropriately. Also, I'd get an immediate response from 1/2 when opening the throttle, but nothing on 3/4 unless I really opened it up... but then it would backfire up through the carb (almost got hit by a flying synchronizer; had to glue it back together). I swapped the carbs and the issue was till with 3/4, so it's not the carbs. Also, I've set the timing (It's not perfect since only 2-ish cylinders, but close), checked compression (120 PSI all around), adjusted the valves several times and confirmed spark to each cylinder. So, by process of elimination, I'm thinking there's something wrong with the valves... especially with the backfiring through the carburetor.
Tonight, I'm going to pull the rocker on that side and see what I find. Any recommendations on how to diagnose this issue?
Engine is a professional rebuild, but I don't know any specs; carbs are dual EMPI 40 HPMX; distributor is a vintage Bosch. _________________ '72 Karmann Ghia stock Ravenna Green (1992 - 1999)
'72 Karmann Ghia modified Ravenna Green (2019-) |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76909 Location: Sneaking up behind you
Posted: Mon Aug 26, 2019 6:32 am Post subject: Re: New build, cylinders 3/4 not responding |
Did you swap the 3 and 4 wires?
I suspect you have the wires on wrong. 1-4-3-2 clockwise.
_________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon Aug 26, 2019 7:37 am Post subject: Re: New build, cylinders 3/4 not responding |
Glenn - I thought the same thing, but I've confirmed the firing order several times.
j _________________ '72 Karmann Ghia stock Ravenna Green (1992 - 1999)
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Mon Aug 26, 2019 7:39 am Post subject: Re: New build, cylinders 3/4 not responding |
If you have decent compression all around I double its a valve problem... Remember cam only has 4 lobes so if its a cam problem the opposing cylinder(s) will have same problem...
Vacuum leak on 3/4 side intake? ... Usually back fire through crab indicates lean condition...
Paul Windisch Samba Member
Joined: September 02, 2009 Posts: 2546 Location: Clinton Township, Michigan
Posted: Mon Aug 26, 2019 8:03 am Post subject: Re: New build, cylinders 3/4 not responding |
Check for plugged idle jets.
Also, make sure UNEQUIVOCALLY that the carburetors are synchronized properly. Make sure the progression ports on one side are not exposed at idle. _________________ *ASE Recertified Master Automotive Tech*
1984 Mexican Beetle
-1914cc
-L3 Heads 35x32 valves 52cc chambers
-0.040" deck for about 9.1:1 Compression
-Engle W110 cam
-CB Super Stock 1.1:1 Rockers
-Stock Heat Exchangers w/ Tri-Mil Muffler
-Dual Weber IDF 40s w/ 26mm venturis
-034 SVDA Distributor
2013 Chevrolet Volt DD
2005 Pontiac Montana SV6
MAHLE Service Solutions
Applications Engineer |
Posted: Mon Aug 26, 2019 8:40 am Post subject: Re: New build, cylinders 3/4 not responding |
Dale - Good point about the cam. I'll check for intake leakage.
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Mon Aug 26, 2019 8:43 am Post subject: Re: New build, cylinders 3/4 not responding |
TonkaJim wrote: |
Engine is a professional rebuild, but I don't know any specs; carbs are dual EMPI 40 HPMX; distributor is a vintage Bosch. |
Take the mixture screws completely out to make sure the seats didn't blow out of the carb body. _________________ Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet |
Posted: Mon Aug 26, 2019 8:45 am Post subject: Re: New build, cylinders 3/4 not responding |
Paul,
I've cleaned the carbs several times and verified the jets are clean. I also swapped the carbs and still have the same problem on the same side. I discovered this problem as I was sync'ing the carbs. I can adjust the idle speed screw to sync the air flow, but it does nothing to the engine speed.
jason Samba Member
My money is on a vacuum leak at base or not synced. |
Posted: Mon Aug 26, 2019 8:47 am Post subject: Re: New build, cylinders 3/4 not responding |
[/quote]Take the mixture screws completely out to make sure the seats didn't blow out of the carb body.[/quote]
Roy, I swapped the carbs and the problem is still with the 3/4 cylinders, so doesn't seem to be a carb issue.
Posted: Mon Aug 26, 2019 9:14 am Post subject: Re: New build, cylinders 3/4 not responding |
j[/quote]
Ok cool. So yeah, it has to be some kind of vacuum leak. Did you do a leakdown test?
Have you measured the exhaust temp to confirm that it's not running on that side? If not, use a simple laser heat gun and measure the temp on each exhaust flange(for consistency) They should all be within 10-25 degrees of each other. _________________ Please "LIKE" us on facebook to see what we are working on.
www.mofoco.com
Posted: Mon Aug 26, 2019 9:42 am Post subject: Re: New build, cylinders 3/4 not responding |
Roy - Thanks. I'm going to do a leak test tonight. And, per your suggestion, i'm going to bring home the thermal imaging camera from work and take some pics!!
Posted: Mon Aug 26, 2019 9:56 am Post subject: Re: New build, cylinders 3/4 not responding |
TonkaJim wrote: |
Paul,
j |
Sorry, I missed that part! Yeah, at this point you are probably looking for a vacuum leak on that side. _________________ *ASE Recertified Master Automotive Tech*
1984 Mexican Beetle
-1914cc
-Engle W110 cam
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2736 Location: Hamble, Hampshire, UK
Posted: Mon Aug 26, 2019 11:42 am Post subject: Re: New build, cylinders 3/4 not responding |
On thing that stays the same side when you swap carburettors over is the fuel supply. Maybe the problem is a blocked fuel fitting.
Or maybe its pinched tinware under the manifold letting in air.
Also treble check spark plug lead order...the big backfires sort of seem familiar. _________________ Ancient vehicles and vessels
Posted: Mon Aug 26, 2019 12:15 pm Post subject: Re: New build, cylinders 3/4 not responding |
mikedjames wrote: |
Also treble check spark plug lead order...the big backfires sort of seem familiar. |
Good call on the fuel supply possibility _________________ Please "LIKE" us on facebook to see what we are working on.
www.mofoco.com
Posted: Mon Aug 26, 2019 1:03 pm Post subject: Re: New build, cylinders 3/4 not responding |
Mike - thanks. I know I i have fuel, but but I'll double check to make sure it's not blocked and even for both carbs. I have a pressure gauge on the 1/2 carburetor. I'll move it over to the 3/4 to see how it reads.
stanthedog Samba Member
Joined: October 11, 2006 Posts: 357 Location: Portland,oregon.
Posted: Mon Aug 26, 2019 1:22 pm Post subject: Re: New build, cylinders 3/4 not responding |
as miked also pointed out. make sure the tin isn't in the way. I had to deal with that myself. on mine, it was mostly on the 3-4 side. felt tight but wasn't. |
Posted: Mon Aug 26, 2019 1:27 pm Post subject: Re: New build, cylinders 3/4 not responding |
Stan - Ah ha ... by that you mean that the tin could be preventing the intake manifold from seating completely on the head? I'll take a look. thanks! _________________ '72 Karmann Ghia stock Ravenna Green (1992 - 1999)
Posted: Mon Aug 26, 2019 3:02 pm Post subject: Re: New build, cylinders 3/4 not responding |
TonkaJim wrote: |
Stan - Ah ha ... by that you mean that the tin could be preventing the intake manifold from seating completely on the head? I'll take a look. thanks! |
Yes....
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3817 Location: Georgia
Posted: Mon Aug 26, 2019 4:39 pm Post subject: Re: New build, cylinders 3/4 not responding |
Do the spray trick!
While it’s running, spray some carb cleaner or WD-40 around the intake manifolds. If the leak is that bad you’ll notice a change right away.
You’ll have a mess to clean up of course _________________ Volkswagen!
(Compression 8.7:1) |
