slave1pilot Samba Member
Joined: February 22, 2010 Posts: 943 Location: Tehachapi CA
Posted: Thu Apr 16, 2015 10:23 am Post subject: |
I'd like to thank my 63's PO for welding angle iron onto the seat rails so he could bolt in hideous aftermarket seats from some unknown donor car.
Seats:
Angle iron:
The welds:
Before and after cutting them off:
_________________ My Photobucket for my Herbie Project - http://s1288.photobucket.com/user/TK-439/library/Herbie?sort=3&page=1
Currently:
1963 Ragtop Beetle
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
Bret2094 Samba Member
Joined: March 22, 2012 Posts: 665 Location: Linden, Texas or College Station Texas
Posted: Thu Apr 16, 2015 10:47 am Post subject: |
I've got two major P/O disasters, but first I would like to thank the P/O of my 59 Rag for disposing of all 4 fenders, 4 tab hood, and decklid, and then cutting it up into a baja and throwing away the ragtop mechanism.
I would like to sincerely thank my grandfather for holding on to the 67 that I now own, but was putting astroturf really necessary as a replacement carpet choice?
Bret _________________ 1959 baja beetle ragtop( going back to Full body)
1959 beetle
1960 Beetle frame Custom buggy
1962 Karmann Ghia
1967 beetle( august 66, first car)
1967 beetle (parts car)
1977 Westfalia Camper
1972 Plymouth Duster
Just another 22 year old jackass who caught the bug, and lives by the motto " NO fatchicks allowed" , I've got too many cars as is (buses N/A) |
Karmannut Samba Member
Joined: August 05, 2007 Posts: 139 Location: North Canton Ohio
Posted: Sun Apr 19, 2015 6:19 am Post subject: |
Thanks PO for gouging out the serial number on the block so I have no idea what it is and for using what looks like a chisel to cut a hole in the dash for a generic starter switch when you broke the key off in the very cool locking steering column switch and for using same chisel on the right front 1/4 panel for antenna bought at same cheapo store as the ignition switch and way to many wiring issues to even begin to mention. On the other hand also thanks for keeping out the Ohio salt keeping the body and pan very solid! _________________ Rupert- 64 Sea Blue Beetle with 66 Dove Lodgette tent
Bunny- 84 grey Rabbit Convertible
Pepper-18 Habanero Orange Beetle SE Premium
Air and Water do mix! |
codycat Samba Member
Joined: July 18, 2006 Posts: 1163 Location: Mobile, Alabama
Posted: Sun Apr 19, 2015 6:30 am Post subject: |
I'd like to thank my original owner, honestly, for keeping my 67 unmolested and stock. I would like to thank the second owner for NOT chopping the top and turning my sedan into a convertible
when I bought it from him it had the pencil lines already drawn as to where he planned to cut it off - needless to say I am pleased I got it before he destroyed my 67 _________________ Did you ever stop to think, and forget to start again?
Winnie the Pooh
Sometimes the questions are complicated and the answers are simple.
Dr. Seuss |
Hokie87 Samba Member
Joined: May 27, 2010 Posts: 280 Location: Richmond, VA
Posted: Tue Nov 03, 2015 5:46 pm Post subject: |
I'd like to thank the PO of my 67 for installing 68 1/2 + spindles and Pitman arm so my new tie rods don't fit. For the 63 grafted in sun roof (I actually like this one) and for the 1600 DP engine (I like this one too), but buying parts is a crap shoot.
thevinster Samba Member
Posted: Wed Aug 10, 2016 11:37 pm Post subject: Re: I would like to thank my bug's PO for... |
Back in the mid 80s a bought a 63 bug. I looked at the front quarter panel very closely after buying it and realized there was some bondo. Since i was gonna repaint the car anyways i figured I'd see how much there was so i stripped the paint off the area. I swear the must've been 6 inches of bondo with chicken wire in it to support it! They could've SO EASILY kicked the panel out from the inside and it would've been fine. So thanks whatever knuckleheads idea that was |
yammi450 Samba Member
Joined: October 04, 2005 Posts: 149 Location: Las Vegas,Nv
Posted: Sat Aug 13, 2016 12:54 pm Post subject: Re: I would like to thank my bug's PO for... |
Thanks PO, for fixing the rusted sheet metal under the back seat,rear body mount, front heater channel, and front fender wells with fiberglass that is slopped on. Also tack welding the running board mount metal over the rusted original, and welding replacement rear clip at the wrong angle so now the deck lid doesn't fit properly when closed and engine is a major PIA to remove and install. |
Bug-nut Samba Member
Joined: December 20, 2015 Posts: 488 Location: Knoxville, TN
Posted: Sat Aug 13, 2016 4:58 pm Post subject: Re: I would like to thank my bug's PO for... |
I'd like to thank my PO's for swapping out my original 36 hp for a later 36 (not that big a deal, my car is only a '59 and not a split or oval) however throwing away the original 28pci carb and replacing it with a crappy empi reproduction that doesn't fit right and runs terrible and has the wrong vacuum signal was a big no-no! Also was it really nessecary to toss the ignition wire tube?! (part of what makes a 36 hp so cool!) _________________ 1959 Fjord Blue Volkswagen Beetle
http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
1962 Austin-Healey Sprite
Snort wrote: |
A 59 Beetle is just an Oval-Window car with aspirations of modernity. |
bluebus86 Banned
Posted: Sat Aug 13, 2016 8:36 pm Post subject: Re: I would like to thank my bug's PO for... |
the prior owners body shop is damned for reinstalling a pitted and scratched windshield after a full glass out repaint, for installing two left hand head lights, and for not properly installing the window scrapers while leaving off the vapor barrier in the doors, and filling up the door drain holes with bondo, turning my floor pans into a lake. lots of love too for pulling out the motor without removing the heater cables, hell just keep pulling till the heater box arms and their pivot point is ripped off, F you you crappy body shop! ps real nice to leave off the front tin peice to after the engine is installed, at least the sob shoved it back in, oh and no engine tin seal installed .
really nice how they screw over a customer, a dear 90 year old lady. ice way to f up an all orignal 70K mile garage kept car, and they call themselves a professional restoration shop, hacks is more like it. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34002 Location: Conejo Valley, CA
Posted: Sat Aug 13, 2016 10:59 pm Post subject: Re: I would like to thank my bug's PO for... |
bluebus86 wrote: |
really nice how they screw over a customer, a dear 90 year old lady. ice way to f up an all orignal 70K mile garage kept car, and they call themselves a professional restoration shop, hacks is more like it. |
Feel like naming them in the feedback thread? |
Faustling Samba Member
Posted: Sun Aug 14, 2016 1:28 pm Post subject: Re: I would like to thank my bug's PO for... |
For not driving it more than he did. He had someone redo the front end to drop it and add disc brakes. Well, the steering rods weren't tightened down. When I got it home after towing it 330 miles, I found the steering rod laying on the trailer. She wouldn't be in my garage today, and possibly there could have been a terrible accident had it been driven a little more.
I can't imagine how bad of an accident was avoided.
[/img] _________________ My Bug and I are both 1965s. We understand each others aches and pains of getting old. |
Posted: Mon Aug 29, 2016 6:40 pm Post subject: Re: I would like to thank my bug's PO for... |
To whoever replaced body panels for not putting on period correct pieces. No holes for over-rider bumpers. Wrong front fenders so no horn holes. I don't get that part. I never caught it while looking it over. Too much of a noob.
For not greasing the king pins after installing drop spindles. Now they are probably trashed. Seriously, you couldn't grease any of it??? The steering is so tight I'm afraid something is going to break.
For what appears painting the seats. The black is wearing off and red is showing. smh.
While I'm bummed about it, so far the rest seems to be pretty solid and little things need to be done here and there. I mean it IS almost 52 yrs old. _________________ My Bug and I are both 1965s. We understand each others aches and pains of getting old. |
Ruger59 Samba Member
Posted: Wed Aug 31, 2016 9:24 am Post subject: Re: I would like to thank my bug's PO for... |
I'd like to thank the previous owners of my 59 bug for cutting the brake line going to the rear than driving it only on front brakes. Needless to say the entire front braking system was garbage. Also modifying a 1600cc exhaust to fit on a 36hp. However I do thank them for keeping the vehicle all original matching body, engine, fenders even the speedometer is og. _________________ Current Volkswagen's:
*An all original 1959 capri blue beetle nicknamed Ruger
*White 1970's Vert Baja Bug |
67ctbug Samba Member
Posted: Mon Sep 05, 2016 12:07 pm Post subject: Re: I would like to thank my bug's PO for... |
I'd like to thank the previous owners of my '67 for putting half an inch of bondo, fiberglass, and undercoating over these rust holes.
_________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
Rathguten Samba Member
Posted: Mon Sep 05, 2016 1:05 pm Post subject: Re: I would like to thank my bug's PO for... |
... welding the body to the frame at the napoleons hat and then covering it with seam sealer, bondo, flex-seal, and undercoating. Unbelievable.
jwp67 Samba Member
Posted: Mon Sep 05, 2016 3:47 pm Post subject: Re: I would like to thank my bug's PO for... |
Rathguten wrote: |
That one there is a front runner for the most bonehead move of all time |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9756 Location: Oregon
Posted: Mon Sep 05, 2016 4:13 pm Post subject: Re: I would like to thank my bug's PO for... |
jwp67 wrote: |
Rathguten wrote: |
Hey, At least it cured that nasty water intrusion problem into the interior.
What a major F@ck up.
Good Luck with that jwp67. Jeez! _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Ceckert64 Samba Member
Joined: September 16, 2015 Posts: 1956 Location: Manitowoc, WI
Posted: Fri Aug 30, 2019 6:13 pm Post subject: Re: I would like to thank my bug's PO for... |
Bringing this thread back from the dead...
I would first honesty like to thank the PO for saving me the car for a week when he had people offer him 100 more than the $750 he was asking. I’d like to thank him for leaving parked for yoears on a PAVED driveway. Having no clue the engine and transmission were rebuilt 2,000 miles ago. I’d like to thank the PO PO’s for rebuilding the engine and transmission, recovering the seats with TMI original look vinyl and not destroying the wiring. Now I’d like to thank them for cover all of the rust hole and accident damage with bondo and aluminum tape, fiberglassing over the rusted out Heater channels and floor pans, never cleaning the sunroof drain channels so they could clog and rust out part of the roof, for never undercoating in and driving in Michigan, getting rid of the rear one year only interior panel, not fixing the ripped out fender nuts on the left side and attaching the fender with a random assortment of fasteners and bondoing over the damage for it to rust there, and for losing the title to the car, along with the keys. Also for cutting and bending down the radio opening so I didn’t have to weld in a new piece and just had to bend it up, and for installing a key switch and button on the opening to start the car and for cutting a hole in the dash to put in a toggle switch to turn the light on and off for the fuel gauge?!?!? But I’m still happy I bought the car and have learned a lot. _________________ 1964 sunroof Beetle Restoration "Herbie"
1972 Sierra Yellow Tin Top Westfalia Camper
“Fitz” 1971 Westfalia Poptop |
leowagen Samba Member
Joined: October 16, 2018 Posts: 171 Location: Argentina
Posted: Mon Sep 02, 2019 7:36 am Post subject: Re: I would like to thank my bug's PO for... |
I'd like to thank my PO for converting and otherwise complete Oval into a Frankenwagen, swapping the Oval's body for a late 60's-ish Brazilian big window...
I also thank him for at least having the swap done by a VW dealer and keeping the invoice for the cars history documentation.... |
thechief86 Samba Member
Joined: January 18, 2012 Posts: 860 Location: middle tn
Posted: Wed Sep 04, 2019 11:01 am Post subject: Re: I would like to thank my bug's PO for... |
I thank my 62's most recent PO for leaving the car the hell alone.
The guy before that, I applaud your efforts, and you did a few good things.
But please, tape stuff off before you paint another vintage car. _________________ "A poor workman always blames his parts... Ya gotta have skillz to hang junk." -johnnypan |
