epowell Samba Member
Joined: September 23, 2015 Posts: 4733 Location: Czech (mostly) Vancouver (sometimes)
Posted: Thu Sep 05, 2019 8:55 pm Post subject: Shopping list for Vancouver, BC |
Hi Folks
Just got into Vancouver yesterday and tomorrow I begin working on Antonio... out of my element in terms of locating the necessary supplies. So I decided to start a "shopping list" thread. As I need various things I will post here the item, and hopefully those who know will enlighten me as to where in Vancouver I can purchase...
To begin with I am going to be attacking a whole pile of RUST (Vancouver van.... go figure!) >>> I have some rust converter but after that plan to put on some EPOXY PRIMER... or even some POR15. Both of those things I have no idea where to find in Vancouver (West Side if possible).
The other thing I will need very soon is a NEW BATTERY.... any suggestions?
Thanks
Ed _________________ www.edwardpowell.com |
sphet Samba Member
Joined: November 09, 2016 Posts: 345 Location: Vancouver, BC
Posted: Thu Sep 05, 2019 10:53 pm Post subject: Re: Shopping list for Vancouver, BC |
Love 'em or hate 'em, I got my group 41 battery at Canadian Tire on Cambie street last year. _________________ 1982 Diesel Westfalia 1.6 NA - The Shellakabuukiee |
RoryGirl Samba Member
Joined: October 14, 2016 Posts: 784 Location: WestWorld Nanaimo BC
BlueTwo Samba Member
Joined: June 09, 2014 Posts: 63 Location: North Vancouver, B.C.
Posted: Fri Sep 06, 2019 1:43 am Post subject: Re: Shopping list for Vancouver, BC |
Napa, the North Vancouver location on Churchill Cr. but any location should sell for the same price.
41-6 Legend: $157.32 all in, with a $15.00 core credit
It's a squeeze and a battery lift strap is a must but it fits. |
photogdave Samba Member
Joined: April 05, 2004 Posts: 3052 Location: Vancouver Island, B.C.
Posted: Fri Sep 06, 2019 7:51 am Post subject: Re: Shopping list for Vancouver, BC |
still trying to locate epoxy primer in YVR... does it HAVE to be LECHLER? _________________ www.edwardpowell.com |
wesitarz Samba Member
Joined: August 20, 2012 Posts: 1490 Location: Victoria,B.C.Canada
Posted: Fri Sep 06, 2019 8:11 am Post subject: Re: Shopping list for Vancouver, BC |
Walmart for battery. |
Posted: Fri Sep 06, 2019 5:12 pm Post subject: Re: Shopping list for Vancouver, BC |
That's it. You have to check your local stores.Good battery.Lasted longer than rating. On my second one now. |
SlowLane Samba Member
Joined: July 11, 2005 Posts: 1044 Location: Livermore, CA
Posted: Sun Sep 08, 2019 11:38 am Post subject: Re: Shopping list for Vancouver, BC |
Lordco has always been my goto FLAPS when in BC. They can get pretty much any part you need within a day, and their parts quality is better than Crappy Tire. _________________ Present:
'81 Westfalia: 2L, manual. Originally Canadian, now Californiated
Back in the day:
'72 Super Beetle
'69 Camper Van - Corvair powered
'71 Window Van - Transferred Corvair from '69
"With sufficient thrust, pigs fly just fine." - Internet RFC 1925
"They say a little knowledge is a dangerous thing, but it is not one half so bad as a lot of ignorance." - Sir Terry Pratchett |
sphet Samba Member
Posted: Sun Sep 08, 2019 3:07 pm Post subject: Re: Shopping list for Vancouver, BC |
SlowLane wrote: |
Lordco has always been my goto FLAPS when in BC. They can get pretty much any part you need within a day, and their parts quality is better than Crappy Tire. |
What kind of parts are you getting there? I havehad zero luck getting any vw parts through Lordco and have always had to hit up the vanagon vendors.
S _________________ 1982 Diesel Westfalia 1.6 NA - The Shellakabuukiee |
Posted: Sun Sep 08, 2019 10:58 pm Post subject: Re: Shopping list for Vancouver, BC |
next item... does anyone know where in Vancouver to buy high heat rubber hose? I need 5 meters to replace one of my engine to rad. coolant pipes.
Thanks! _________________ www.edwardpowell.com |
CdnVWJunkie Samba Member
Joined: February 01, 2004 Posts: 1110 Location: Sarnia, Ontario, Canada
Posted: Mon Sep 09, 2019 3:03 am Post subject: Re: Shopping list for Vancouver, BC |
epowell wrote: |
Thanks! |
1? or 1.25" ? I might be inclined to check with your local marine supplier. You are in a strong marine area. The last roll I purchased was off amazon. |
Mike Robinson Samba Member
Joined: June 18, 2010 Posts: 386 Location: Nanaimo BC Canada
Posted: Mon Sep 09, 2019 7:42 am Post subject: Re: Shopping list for Vancouver, BC |
My 1982 diesel had a rusted out coolant pipe, which when checked was only the last bit before the engine, the rest was still good.
So if you have the same situation, check a truck supply shop (Peterbilt or Mack type not F150) and get braided 1.25" or 1.5" hose from them.
Mike |
Posted: Mon Sep 09, 2019 7:48 am Post subject: Re: Shopping list for Vancouver, BC |
THX GUYZ! _________________ www.edwardpowell.com |
Posted: Mon Sep 09, 2019 7:57 am Post subject: Re: Shopping list for Vancouver, BC |
CdnVWJunkie wrote: |
epowell wrote: |
Thanks! |
Marine exhaust hose. Also comes in 1 3/8" |
Posted: Sat Sep 14, 2019 1:08 pm Post subject: Re: Shopping list for Vancouver, BC |
Probably a silly question, but where in Vancouver can one purchase just basic NUTS & BOLTS in bulk in many sizes?? I have absolute NONE here in my mom's house. Back in Czech my GF's father had tons everywhere... and they are easily purchased there too...
...I am stuck because I was dropping the spare tire clam shell, which NORMALLY stays "up" via a little hook, even after you remove the bolt... but my little hook doesn't work and it came CRASHING DOWN on my knee... OUCH!!!!!!!!!!!!
...in the chaos and pain the bolt must have gone flying and not it's gone... so I can't even get the clam shell back up.
Does anyone know how to repair that hook?? _________________ www.edwardpowell.com |
