ICTrains Samba Member
Joined: June 05, 2011 Posts: 95 Location: South Alabama
Posted: Sat Sep 07, 2019 5:47 am Post subject: Axel nut removal and lug patterns |
I need a little advice and opinions from the group.
I have to remove the axle nuts from my Thing and will be replacing the drums with disk brakes. To my knowledge, these nuts have never been removed and they are very stubborn. I’ve already bent a perfectly good bed rail trying to remove one so it’s time to look into a real tool for the job.
It’s down to these two:
Torque Multiplier
https://www.jbugs.com/product/16-9602.html
Axel Nut Removal Tool
https://www.jbugs.com/product/5750.html
Both tools will serve double duty for the axle but and the flywheel nut, but from a practicality and safety standpoint I think the torque multiplier will be the better tool. The axle nut removal tool even has a warning about excessive force bending he tool.
But...my plan is to change my lug pattern to 5x4.5 with the disk brakes simply because of the cost and availability of different style wheels. If I do this, I’m pretty sure the torque multiplier will not fit the new lug pattern and I’ll be back to needing some way to re-tighten the nuts.
One site I found sells the second tool with a description indicating that it will fit a bus narrow five lug pattern which is 5x112mm or 5x4.4ish. Would this possibly still fit the 5x4.5?
So my issue is that I want to buy the best tool for the job and if I weren’t planning to change lug patterns then the torque multiplier would be the better tool hands down.
Am I misguided in my desire to change lug patterns? Does anyone who’s changed patterns have any thoughts on this?
All opinions and advice are welcome!
Thanks. _________________ JohnD
'73 Thing
'16 Wrangler JKU
My Rebuild Project
Thing Rebuild Threads
"If you take something apart and put it back together enough times, eventually you'll have two." |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2770 Location: The World's Motor Capital
Posted: Sat Sep 07, 2019 6:59 am Post subject: Re: Axel nut removal and lug patterns |
If you intend to put those nuts back on, and torque them to the proper spec, then use the torque multiplier tool.
The torque multiplier makes for no drama, and very little armstrong.
I imagine that it would not be too difficult to "adapt" the torque multiplier with some flat steel to accommodate your altered lug pattern.
Good luck, Mondshine |
Posted: Sat Sep 07, 2019 11:24 am Post subject: Re: Axel nut removal and lug patterns |
Thanks Mondshine! I don’t know why I didn’t think of an adapter plate. I guess a thin piece of plate steel wouldn’t offset it enough to create any issues.
Thanks again! _________________ JohnD
'73 Thing
'16 Wrangler JKU
My Rebuild Project
Joe 20 Samba Member
Posted: Sat Sep 07, 2019 7:35 pm Post subject: Re: Axel nut removal and lug patterns |
The add shows the Torque Multiplier as "Out of Stock" at J Bugs and the price seems a little steep. It is available elsewhere and on EBay.
I do highly recommend the tool...30 seconds and my axle nut was off...I couldn't believe how easy it was.
Also, get some longer lug bolts as the stock ones on my 73 were too short. I just used some metric bolts with matching thread. |
Semper_Dad Samba Member
Posted: Sun Sep 08, 2019 11:41 am Post subject: Re: Axel nut removal and lug patterns |
I use the Torque multiplier and won't use anything else. Most civilized way of doing things. Make sure you don't over torque because the multipliers can snap an axle. Ditto on the lug nuts. Make sure they're not too long either. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
wizrod Samba Member
Posted: Mon Sep 09, 2019 6:20 am Post subject: Re: Axel nut removal and lug patterns |
be wary of some of the versions of the torque multiplier. I bought a 'Torque Meister' that has worked perfectly for torquing UP rear axle nuts, but doesn't like to undo them.
I think the problem was partly that the nuts were on over tightly, but also the cast (as opposed to machined) teeth on the tool are not that well formed. As a result - coupled with the play in the mechanism - the teeth slipped.
I ended up using a 3-foot long breaker-bar with a 1" drive socket (this was a replacement for the 3/4" drive bar I broke last time I did this job...). my 200+lb weight at 3' was enough to break the nuts lose without using a cheater bar.
P. |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Mon Sep 09, 2019 8:58 am Post subject: Re: Axel nut removal and lug patterns |
The axle nut on a Bus is 46mm vs the one on a Bug/ghia/Thing being 36mm. If you get one for a bus, it's not likely to work. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Mon Sep 09, 2019 6:50 pm Post subject: Re: Axel nut removal and lug patterns |
Thanks for the advice everyone. I found a site that had the Empi brand tool so I suppose that will be a quality tool... _________________ JohnD
'73 Thing
'16 Wrangler JKU
My Rebuild Project
Posted: Wed Sep 11, 2019 10:05 pm Post subject: Re: Axel nut removal and lug patterns |
ICTrains wrote: |
Thanks for the advice everyone. I found a site that had the Empi brand tool so I suppose that will be a quality tool... |
Empi is a brand to be avoided for most stuff, can't say how their torque multiplier compares to others though. |
