Looking for info on missing engine part- air flap?
mrutatech
mrutatech is offline
PostPosted: Wed Sep 11, 2019 9:03 am    Post subject: Looking for info on missing engine part- air flap? Reply with quote
Hi everyone, I'm trying to get this bus put back together (correctly!), and I just came across a missing part. A new bus friend showed me that the engine is missing a "flap" as shown in the picture.
Can anyone tell me what this is called and possibly any leads on where I can source a replacement?
Thanks!!!!
[/img]
SGKent Premium Member
SGKent is offline
PostPosted: Wed Sep 11, 2019 9:14 am    Post subject: Re: Looking for info on missing engine part- air flap? Reply with quote
there is a cover and a flap on each side. keeps air from pushing back into the shroud when the defrost fan or aux heater if you have one are on.
You also need a pin for each flap. I made pins out of nails I cut off.
They look like this photo from RAtwell.com
Godspeed to all who undertake a journey in a VW Bus.
*You can do it right the first time, or do it over, the choice is yours. It is a free country. As to brakes, steering, tires, axles etc. - you may only get one chance at doing those right.
Bringing back to life, and maintaining a 45 - 50 year old transporter takes a real commitment, and cash. The quality of replacement parts leaves much to be desired, and getting worse.
1971 (sold)
1977
SamboSamba22 Premium Member
SamboSamba22 is offline
PostPosted: Wed Sep 11, 2019 9:17 am    Post subject: Re: Looking for info on missing engine part- air flap? Reply with quote
Flaps are correct as shown above and need to be sourced. I know that Bus Depot sells the covers, which originally came with a type of cork gasket. Not sure if there is aftermarket availability on the flippers.
The Bus Barn Ltd. Co.
Maywood Mountain
Invention is the tool of the adventurer - Jacques Cousteau
Sinning led me to become a saint, which I then learned I wasn't qualified. -S.H.B.
1959 Dove Blue Single Cab - SOLD (undergoing complete restoration)
1965 Ruby Red Standard Beetle - SOLD (currently loved in Oklahoma)
Oct. ’67 Double Cab (’68 Doka) 1835, Weber 40 IDF’s
1974 Brilliant Orange Westfalia “PushPop" The bus that started it all - SOLD
Wildthings
Wildthings is offline
There is a flap under that area that is not needed, what you need is the cover. I think they are available new at this point in time. Try CALLING Bus Depot and see if they have a box of them somewhere. The right and left covers are different in shape.
The cover has a gasket to help it seal, but I just use high temperature silicone. I put a bead on the cover, let is set for a half hour or so until it skims over well but has not fully set. I then install it carefully and tighten the screws down, this gives a nice tight custom fit even with somewhat mangled parts and pieces, it will be removable even if some of the silicone squished out of the joint.
SGKent is offline
PostPosted: Thu Sep 12, 2019 7:19 am    Post subject: Re: Looking for info on missing engine part- air flap? Reply with quote
https://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-021-119-263-APR
https://www.vwheritage.com/021119263a-fan-shroud-air-flaps-pair-1700-2000cc-vw-spare
https://www.csp-shop.com/en/engine/fan-shroud-air-flaps-119-263-021a-29611a.html
1971 (sold)
1977
