aeromech Samba Member
Joined: January 24, 2006 Posts: 16970 Location: San Diego, California
Posted: Sun Sep 01, 2019 8:46 pm Post subject: Re: no oil pressure |
Look at CB Performance _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
SGKent Samba Member
Posted: Sun Sep 01, 2019 9:37 pm Post subject: Re: no oil pressure |
ask Whip618 if he has any blueprinted ones for sale. Don't go back down the type 1 pump in a type 4 engine route again. That is what the last person tried. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Mon Sep 02, 2019 5:22 am Post subject: Re: no oil pressure |
SGKent wrote: |
ask Whip618 if he has any blueprinted ones for sale. Don't go back down the type 1 pump in a type 4 engine route again. That is what the last person tried. |
I second that recommendation. He rebuilt 3 oil pumps for me, and they are better than the original.
Whip618 is a pro and takes pride in his rebuilds. _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
Teammo Samba Member
Posted: Wed Sep 11, 2019 4:15 pm Post subject: Re: no oil pressure |
SGKent wrote: |
Update -I purchase and installed a rebuilt pump from Whip618. Put front of engine back together, left off heat exchangers for now.
I checked the oil pick up and tube and look like everything is installed into the gallery, blow air through and no obstructions.
I took spark plugs out, jacked the front of the bus up to make sure the pump should have oil. installed line to the oil pressure port and put other end in a water bottle, cranked over and still no oil pumping.
I don't understand how I cannot have oil at least pumping a little. Not sure what to do now? |
SGKent Samba Member
Posted: Wed Sep 11, 2019 4:42 pm Post subject: Re: no oil pressure |
Teammo wrote: |
SGKent wrote: |
Did you prime the pump? Take the sender off the hose, squirt some oil down it. Then crank the engine with it aimed at a jar or pan.
Did you make sure the pump gear slid fully into the cam slot? If these things don't get it, there is a long shot that the old pump wore out the cam thrust bearing or broke it when it spun on the slot. I think that the pump just needs a prime. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Sep 11, 2019 4:43 pm Post subject: Re: no oil pressure |
Sure the tang on your new pump is engaging in the slot in the cam? |
Posted: Wed Sep 11, 2019 4:50 pm Post subject: Re: no oil pressure |
Get a Coleman funnel from Walmart, it will be in the camping section and the funnel should have a screen in the bottom of it. Using a bit of hose and a 1/8" pipe fitting from a hardware store, rig up a way to hook the funnel up to the oil pressure sender port. Now pour at least a quarter quart of oil into the funnel filling the oil galleys. Use something like a 0w30 oil so it will flow easily. Now crank the engine and see if it will blow the oil back out.
If you still don't make oil pressure remove the mount for the oil filter and see if the valve is still inside the mount, maybe it came apart and is causing a clog in the system. Yes this is a long shot. |
Posted: Wed Sep 11, 2019 4:52 pm Post subject: Re: no oil pressure |
Going in circles _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Teammo Samba Member
Posted: Wed Sep 11, 2019 5:00 pm Post subject: Re: no oil pressure |
Wildthings wrote: |
Yes the tang is engaged, I also cranked the eng over when the type1 pump was in with the cover plate off and the gears were spinning.
I will try putting oil down the sender gallery tomorrow, I am all cleaned up and little dis-hearted. |
Teammo Samba Member
Posted: Wed Sep 11, 2019 5:02 pm Post subject: Re: no oil pressure |
aeromech wrote: |
Going in circles |
SGKent Samba Member
Posted: Wed Sep 11, 2019 5:11 pm Post subject: Re: no oil pressure |
if you did not prime the pump with oil, it is not going to pick up anything. It will spin forever without pulling oil. You only have to learn that once in your life.
Be 100% sure you put it in so the oil ports aligned with the case. The tangs on the pump should be horizontal when viewed from the outside, and the protrusion at the bottom.
Teammo Samba Member
Posted: Wed Sep 11, 2019 5:42 pm Post subject: Re: no oil pressure |
SGKent wrote: |
yes it is correct but you made me look!
Prime as per Wildthings post, is thats how to prime it ? or should I have done something different when installing it?
thanks again everyone for the help!! |
Posted: Wed Sep 11, 2019 6:57 pm Post subject: Re: no oil pressure |
Teammo wrote: |
SGKent wrote: |
That is one way to prime it, and has the advantage that it fills the oil galleries and gives the bearing a good oiling.
Some people pack the oil pump with grease or vasoline. |
SGKent Samba Member
Posted: Wed Sep 11, 2019 8:32 pm Post subject: Re: no oil pressure |
as long as oil gets down to the oil pump it will pull from the sump. Do make sure that in all this fuss you didn't drain the oil and forget to put some back in. Really. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
timvw7476 Samba Member
Posted: Wed Sep 11, 2019 9:12 pm Post subject: Re: no oil pressure |
The clearances in the pump need a film to work with,
Vaseline was the recommendation years ago, but your oil of choice
or even a little gear lube will do the trick.
But a dry pump isn't a pump. Coat or spray or funnel something down there
to get it to draw. |
Teammo Samba Member
Posted: Thu Sep 12, 2019 8:37 am Post subject: Re: no oil pressure |
aeromech wrote: |
So, the engine started and you saw zero oil pressure or it didn't start? |
yes started and saw zero pressure on gauge when this all first started
Teammo Samba Member
Posted: Thu Sep 12, 2019 8:45 am Post subject: Re: no oil pressure |
Well i put in 300 ml of oil via my intravenous setup and cranked it over and on second crank over it built up 22 psi on gauge!!!!
Needless to say I was very excited and much appreciated the help I received from this post! Now to finish putting her back together.
Posted: Thu Sep 12, 2019 8:47 am Post subject: Re: no oil pressure |
Let's recap
Bus drives fine
park it overnight
Start up = no oil pressure
You try everything you can
Finally change pump
Going in circles
Something got missed and it's not priming the pump _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Teammo Samba Member
Posted: Thu Sep 12, 2019 9:05 am Post subject: Re: no oil pressure |
aeromech wrote: |
Let's recap
Bus drives fine
park it overnight
Finally change pump
Going in circles
Something got missed and it's not priming the pump |
Bus drives fine
park it overnight
Finally change pump
Cranked over (not started) = no oil pressure
Going in circles
I did not prime pump properly = no pressure
Added oil via oil pressure switch gallery as per suggestions= pump built up pressure |
SGKent Samba Member
Posted: Thu Sep 12, 2019 9:16 am Post subject: Re: no oil pressure |
