mystreybug65 Samba Member
Joined: April 19, 2012 Posts: 72 Location: Winchester, KY
Posted: Sun Sep 15, 2019 12:38 pm Post subject: Overheated my bug |
So I recently overheated my bug. Going down hwy 80 mph. Passing people like they couldn’t speed up and leave me in the dust. All the sudden started losing power. By the time I got to the ramp I was struggling to go 30 mph. Pulled off side and car died right there. Well not totally. While waiting on a tow truck AAA apparently called from two states over, instead of four miles down the road, the bug cooled down. After about and hour and some change I tried once start her up and bam she fired up and got me home. Now whenever I fire her up, she doesn’t want to keep running, I have to continuously feather the gas or she dies when setting still. Once I get going I don’t have to feather the gas until I come to a stop again. So my question is where would you guys start trouble shooting to find out what’s screwed up. |
Relyt Samba Member
Posted: Sun Sep 15, 2019 12:47 pm Post subject: Re: Overheated my bug |
How do you know it was overheated?
Start with a full tune up:
Adjust valves
Dwell and timing
Adjust the carb
After that I would look at the plugs and check compression. _________________ 69 Beetle - Daily driver
1600 SP (unknown history)
30 PICT 1 w/power circuit (Volkzbitz)
205T (Bill) |
grandpa red Samba Member
Joined: November 23, 2018 Posts: 520 Location: Hollister,Ca.
Posted: Sun Sep 15, 2019 1:34 pm Post subject: Re: Overheated my bug |
Could be fuel or electrical problem. _________________ '72 Beetle |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Sun Sep 15, 2019 1:52 pm Post subject: Re: Overheated my bug |
doubt it's ignition, sounds a lot like a fuel pump not keeping up or possibly some fod in the main jet _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
Xevin Samba Member
Posted: Sun Sep 15, 2019 3:19 pm Post subject: Re: Overheated my bug |
Maybe it’s an injector not firing what kind of bug is this? How is the engine set up? _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
Posted: Sun Sep 15, 2019 5:58 pm Post subject: Re: Overheated my bug |
I had similar symptoms one trip and found this when I took the lid off
sb001 Samba Member
Posted: Sun Sep 15, 2019 6:03 pm Post subject: Re: Overheated my bug |
Are you running a vacuum distributor? If so your canister could be toast. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Posted: Mon Sep 16, 2019 3:32 am Post subject: Re: Overheated my bug |
It is a stock 1600 do with mechanical distributor. I did assume it was overheated mainly because the whole episode did not involve “bad” noises. I also could not touch my dipstick because it was so hot. And finally it started up again after about an hour. I have people tell me that it could be a carb problem or a distributor problem. Is it safe to assume it’s not a valve since it’s not smoking and still no bad/metallic noises. Thanks for all the feedback |
Tom K. Samba Member
Joined: March 10, 2005 Posts: 1605 Location: Central Pennsylvania
eashc Samba Member
Joined: April 10, 2012 Posts: 340 Location: Ventura County
Posted: Mon Sep 16, 2019 8:05 am Post subject: Re: Overheated my bug |
80 mph in a stock 1600, may have overheated especially since it stalled out then started once cooled.
I've heard of fuel pump rods sticking cuz the piece swells up, also I had a cheap distributor that caused timing issues and made the car run hot.
Like it was said start with the basics |
Zundfolge1432 Samba Member
Posted: Mon Sep 16, 2019 11:59 am Post subject: Re: Overheated my bug |
One very sure way to tell of a car has been overheated? When it cools down check the valve adjustment, really bad overheating will make the valves tight. If you see that go ahead and remove the rocker arms and check head torque specs. Severe overheat will loosen the nuts or even pull a stud on the 10mm studs without inserts. I overheated one so bad it had no compression and just windmilled when cranking. |
Posted: Sat Oct 17, 2020 1:51 pm Post subject: Re: Overheated my bug |
Wondering how this situation was resolved. What was the fix? |
vwoldbug Samba Member
Posted: Sat Oct 17, 2020 3:36 pm Post subject: Re: Overheated my bug |
That would be nice to hear what fixed it . It might help someone else. |
Posted: Sat Oct 17, 2020 3:45 pm Post subject: Re: Overheated my bug |
Ya I saw this and forgot I replied!
What did you find? _________________ '72 Beetle |
