Timwhy Samba Member
Posted: Sat Dec 21, 2013 7:06 pm Post subject: |
westyventures wrote: |
Timwhy wrote: |
Probably if you let it try multiple times it would eventually display a 2-flash fault code. |
Karl is there any chance that by doing this it could hurt the electronics of the unit? I don't want
to take any chances just to see if I get the two flashes when it clearly ignites from the added
tank. |
No, it is normal operation for it to try 3-4 times to do an operation before finally displaying the fault code in the circuitry from 2/2010-on. |
Thanks Karl!! _________________ '15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
http://www.youtube.com/user/TIMWHY2?feature=mhee |
Timwhy Samba Member
Typhon2222 Samba Member
Joined: October 24, 2009 Posts: 363 Location: Berkeley, CA --> Berlin, Germany
Posted: Mon Mar 24, 2014 4:20 pm Post subject: |
From the very beginning (or almost the very beginning -- I can't remember how it sounded the first few days we used it), our Propex has always produced a kind of burbling sound while burning. As if it were burning in fits and starts rather than burning a steady stream of propane consistently. Anybody else have this problem? _________________ Basil — '88 Dove Blue Westy. |
westyventures Samba Member
Joined: December 29, 2004 Posts: 2306 Location: Oregon Outback
Posted: Mon Mar 24, 2014 4:41 pm Post subject: |
Typhon2222 wrote: |
From the very beginning (or almost the very beginning -- I can't remember how it sounded the first few days we used it), our Propex has always produced a kind of burbling sound while burning. As if it were burning in fits and starts rather than burning a steady stream of propane consistently. Anybody else have this problem? |
That is just the reverberation in the exhaust - the burn will still be consistent. Depending on the age, it could be more or less 'smooth' sounding as they did make some minor improvements lately. Also worth checking the gas pressure, it should be 11" w.c. with one appliance operating.
Karl
www.propexusa.com |
Posted: Tue Mar 25, 2014 12:46 am Post subject: |
Typhon2222 wrote: |
Karl
www.propexusa.com |
Thanks Karl. That's good to know.
We just got our van's Propex cleared by the German inspectors for use in Germany. Required replacing all the copper pipes (not sure with what, but they're all a steel-colored metal now) to meet German specs.
Hardly necessary camping in Europe, where almost every camp site provides electrical hook-ups. Normally we just bring along a portable electric space-heater to keep the inside toasty. Since European space heaters typically pull 2000 watts on high (rather than the 1500-watt max common for US space heaters), that allows for some serious winter camping. But occasionally we've found ourselves overnighting on the road, where the Propex will be handy. _________________ Basil — '88 Dove Blue Westy. |
Syncro Jael Samba Member
Posted: Tue Mar 25, 2014 7:11 am Post subject: |
Just a comment about Propex heaters.
I purchased a HS2800 a year ago.
My son just installed his HS2211 about 6 months ago.
His 2211 has been running in Breckenridge CO. for the past winter. His Syncro has seen multiple subzero° nights and has preformed flawlessly. It has run everyday since October of 2013.
I have had no issues with my 2800. I love cold weather camping when you can get inside and have it toasty warm and sleep comfortably without the worry of some gas heaters. Clean reliable heat.
Both were installed as per the instructions and no vent pipes were cut. I understand these are machines and some machines break down. But ours have been flawless.
Great product and wonderful heat when you really need it!
Thanks Westy Ventures! _________________ 1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat) |
LemonCove Samba Member
Joined: July 29, 2010 Posts: 324 Location: Henderson, NV
Posted: Fri Jan 06, 2017 12:28 pm Post subject: Re: Propex: Blinking 5 Times (Are they Lemons?) |
Getting ready to take off for a cold weekend, tested propex (which I havent used in at least a year) and got the "5 flashes." Samba to the rescue! Compressed air in inlet did the trick! _________________ '88 Bostig Westy |
newfisher Samba Member
Joined: January 05, 2012 Posts: 1764 Location: The wet spot--Oregon
Posted: Fri Jan 06, 2017 12:39 pm Post subject: Re: Propex: Blinking 5 Times (Are they Lemons?) |
With ALL HEATERS there is maintenece just like everything else. YOU MUST FIRE THEM ALL UP ONCE A MONTH to keep them going. Letting them sit is asking for problems! |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
ThankYouJerry Samba Member
Joined: September 01, 2012 Posts: 2271 Location: Shakedown Street
Posted: Fri Jan 06, 2017 8:25 pm Post subject: Re: Propex: Blinking 5 Times (Are they Lemons?) |
dobryan wrote: |
newfisher wrote: |
Dang! Time to go out and run mine for a while.... |
It's January, you live in MD, and you haven't fired up your heater?!?! Only excuse is if you're currently in Mexico! _________________ 1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6832 Location: Fort Lauderdale, Fl.
Posted: Fri Jan 06, 2017 9:40 pm Post subject: Re: Propex: Blinking 5 Times (Are they Lemons?) |
I just read part of the thread and saw it mentioned that there is soot in the exhaust.
These things run on clean burning propane...where is the soot coming from? _________________ This free advice is worth exactly what you paid for it.
inorganic Samba Member
Joined: September 26, 2016 Posts: 60 Location: Portland, OR
Posted: Mon Sep 16, 2019 11:15 pm Post subject: |
help! my propex HS2000 is experiencing 5 blinking lights, I've tried blowing out the exhaust, vacuuming the exhaust, cleaning the fan (gently), cleaning the sensor (gently). It has a new board (2 years or so) that was installed by Karl. Tried all the troubleshooting suggestions i could find but still no heat - just 5 lights. ANY HELP APPRECIATED!!!
Typhon2222 wrote: |
Karl
www.propexusa.com |
_________________ '86 SYNCRO Weekender |
Crooked Designer Samba Member
Joined: March 22, 2018 Posts: 323 Location: Chicago, IL
Posted: Tue May 10, 2022 7:45 pm Post subject: Re: Propex: Blinking 5 Times (Are they Lemons?) |
After getting the 5 blinking code, I decided to change out the airflow sensor and see what happens. Van Cafe supplied the Omron sensor and I spent a huge amount of time wrestling the unit out from the high heat silicone in the holes in the floor of the van under the fridge. After that pain in the ass, I figured I'd help out the next person with some photos, because I'm visual and those instructions were pretty vague.
Step 1 is to remove the screws from the housing. Then you need to get a long and very thin but sturdy knife to cut the silicone seals from between the housing and the base of the unit. This was surprisingly difficult as well. Maybe silicone is my nemesis.
If you think about where the silicone is on the right side of this photo and think about how you can only reach that from the back of the unit (the left side) you'll get a sense of how long that knife blade needs to be. I got my propex with the van from the PO and the warranty seals on the bottom were already broken, it also said "heat tested" and a date on the bottom in sharpie, so this may have been an a previous maintenance reseal on of the silicone, so your results may vary.
Now to find the sensor. The orange white and green wires run from the circuit board to the sensor, and I had read about the black and white alternating pie pieces on the spinning wheel, so I knew what I was looking for, but here it is if you don't
Remove the two screws and the fan, wheel, and green board all come out. After looking closely, its filthy. Not surprising, as the whole unit is filthy inside. Problem identified.
to get the wires out of the grommet, I had to cut the top of it. Knowing I was going to silicone it back into place, I wasn't worried about it. Just left the cut facing up, so no chance for wires inside to find a metal edge to rub on. They will be facing the inside of the case on top which is a smooth surface, but will also have silicone in between.
Don't forget to take the tape off the sensor. This is so it doesn't fall off during transit (it eventually will be secured by the screw when you screw it into the heater)
This is it once the tape is off. I don't regret doing this over a box as I dropped the screw, washer, and sensor at least once each trying to maneuver it into place.
The base of the sensor is wider than the opening and there is a huge pipe you need to work it around so the opening on the base sits over the air inlet I had to start it in 90 degrees to where it would eventually sit to get it past the flanges on the outside of the case. fun times turning the new pieces upside down when you're trying to hold a tiny screw, washer and sensor to a board as you wiggle it around.
A micro screwdriver that is magnetic would have been a lifesaver here. Tight fit to get past the things sticking off the board so you can actually screw the new sensor down to the base using the provided shorter screw.
This is what it looks like after a lot of swearing
There is only one screw provided, and I didn't want to fight any more silicone, so I reused one of the older long screws to keep it from rotating. the screw is too long to screw the base down firmly on the left side, but I figured that wasn't that big of a deal given they only think you need one screw in the first place.
The best part of this is I've heard that the wires are sometimes in a different order, so they send the unit without the harness attached, so you can slide the pins in in the correct order for your unit. *High five* whoever thought about sending it that way. Once you have the pins in the harness in the right sequence you just swap the old for new
After adding all the silicone I had on hand to make it really difficult for myself the next time I have to take this apart, I put all the screws back in the cover and wrestled it back into place.
Upside is I got to replace my noisy metal intake pipe for the "paper" one from Van Cafe. It is much quieter now. Also cleaned up how the pipes are run under the van. I never took a photo of that because it started to rain right when I finished putting the last screws into the clamps holding them to the frame.
Works like new now. Very satisfied, as before I would always be optimistic while it was starting up. If you've used one of these, you know it takes a bit before it tells you there is an error. I enjoy hearing it light and start blowing hot air more now than I did when it was working when I originally got the van. Good times. _________________ '85 Westy full camper, Subaru 2.5L, 5 speed SubiGears + 5speedbus shifter kit |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22665 Location: NYC/Upstate/ROW
Posted: Wed May 11, 2022 3:23 am Post subject: Re: Propex: Blinking 5 Times (Are they Lemons?) |
That circuit board manufacturing dates back to bell bottom era. Maybe before. Put some friggin money back into your product , please _________________ .ssS! |
raspyni Samba Member
Posted: Sat Jan 07, 2023 10:45 pm Post subject: Re: Propex: Blinking 5 Times (Are they Lemons?) |
Crooked Designer wrote: |
Works like new now. Very satisfied, as before I would always be optimistic while it was starting up. If you've used one of these, you know it takes a bit before it tells you there is an error. I enjoy hearing it light and start blowing hot air more now than I did when it was working when I originally got the van. Good times. |
Beautiful post... thank you. I am going to check my black/white sensor tomorrow and will probably end up doing this upgrade. And thanks to your post, my brain has already seen it happen.
Barry |
Californio Samba Member
Posted: Mon Jan 09, 2023 11:45 am Post subject: Re: Propex: Blinking 5 Times (Are they Lemons?) |
I have this problem with the black and white sensor. Possibly stems from the fact that there is no air filter anywhere on the heater, kind of amazing when you think about it. One day I'll do the upgrade but the Propex is so deeply lodged in there I don't look forward to it.
My workaround has been to mount the combustion air intake so it points outside the van on the top of the passenger side propane tank. When I get the blinkies, I blow into the air intake and voila, it works. Requires a bit of humility, perhaps not a bad thing. If you don't have a passenger propane tank, mount the air intake just somewhere you can get to it without climbing under the van. |
Posted: Mon Jan 09, 2023 3:51 pm Post subject: Re: Propex: Blinking 5 Times (Are they Lemons?) |
Californio wrote: |
A filter has very little to do with it. The little freewheeling fans had a higher failure rate in the last years of using them, and that's the primary reason they went to the Omron sensor. You can use compressed air blown through the intake, a couple short blasts at <60 psi, that will dislodge any dirt and spin the fan up. If it continues the only way is installing the Omron sensor kit.
The air intake must always point down if you want to avoid dirt and moisture from settling inside it. |
