Matthew Tolbert Samba Member
Posted: Thu Aug 01, 2019 9:25 am Post subject: Omni epoxy primer any good? |
I’ve searched and found mixed reviews on the Omni line of epoxy primers. Most of the threads are a few years old so I’m looking for more recent experiences if possible. I am wanting to start stripping my car to bare metal and apply some sort of epoxy primer as a base to protect the metal while I’m doing any repairs. Is the more expensive DP line worth getting at twice the price?
I also want to mimic the factories method of dark grey, then light grey/white (it’s hard to tell which color it is) then color. The paint store I went to opened a can of the Omni grey and it was a little lighter than the factory dark grey primer. I thought about getting a can of black also to mix in to darken it up a bit. Has anyone tried this before? Do you have a “mix ratio” you think is a close match? I’ve read the tech sheets and it says it CAN NOT be tinted but can be mixed. Also If you have any tips or tricks you can share that might help would be great. _________________ Matthew Tolbert
1958 ragtop
1961 doublecab
1965 Notchback S |
56reddy Samba Member
Posted: Thu Aug 01, 2019 11:54 am Post subject: Re: Omni epoxy primer any good? |
Omni epoxy primer is garbage. I’ve found that Southern Polyurethane incorporated (SPI) makes a great epoxy primer for $200 for two sprayable gallons. I base every paint job on this epoxy. You can get it online shipped to you. Also they are located in GA. _________________ New Vintage Specialist.
1974 ghia convertible
1981 Vanagon Westfalia
Making VW’s Fun Again.(MVFA) |
Posted: Thu Aug 01, 2019 12:19 pm Post subject: Re: Omni epoxy primer any good? |
Thanks for the information. Just curious what you feel is wrong with it? I’ll look into SPI _________________ Matthew Tolbert
1958 ragtop
1961 doublecab
1965 Notchback S |
Posted: Thu Aug 01, 2019 1:24 pm Post subject: Re: Omni epoxy primer any good? |
Omni epoxy is very watery and doesn’t cover near as well as the SPI epoxy. If you decide to go with SPI get the tech book and it explains how to use the SPI system. _________________ New Vintage Specialist.
Posted: Thu Aug 01, 2019 2:04 pm Post subject: Re: Omni epoxy primer any good? |
Good info. You have any insight to my other questions regarding trying to match the factories process? _________________ Matthew Tolbert
1958 ragtop
1961 doublecab
1965 Notchback S |
Igpoe Samba Member
Joined: February 24, 2019 Posts: 853 Location: South Boston, VA
Posted: Mon Sep 16, 2019 1:02 pm Post subject: Re: Omni epoxy primer any good? |
Use a complete system is my recommendation.
If you like ppg paint then use their primers and sealers underneath so that if problems arise the factory reps can understand and help with a solution. If you
Mix products from suppliers, poor results will follow. |
Kiper Samba Member
Joined: August 17, 2019 Posts: 30 Location: San Jacinto CA
Posted: Tue Sep 17, 2019 1:06 pm Post subject: Re: Omni epoxy primer any good? |
I have used several different ones. Unfortunately in Southern California we have strict laws on what we can and cannot use. I use to use PPG's "DP" series epoxy for all of my bare metal cars. Now I just use a quality DTM or " Direct to Metal primer for all the bodywork. The one I use the most of is made by Vintage. It is a polyester hybrid that works great on bare metal and body filler. _________________ I am Matt K. |
Flat4BRM Samba Member
Joined: February 26, 2018 Posts: 22 Location: California
Posted: Mon Sep 30, 2019 11:18 am Post subject: Re: Omni epoxy primer any good? |
Omni primer user here...
56reddy, not sure what problems you've ran into that makes you think Omni is "too watery", but I've personally shot gallons of the stuff with no issues. Guess it's all a personal preference. I also used to shoot PPG's "DP" line (DP40 Gray-Green was my favorite, but the DP401LF stuff WAS TERRIBLE) before it was discontinued, and the Omni stuff seems to do the job decently. It can be shot as a sealer (2:1:2 base/ hardener/ reducer) or a filler primer (2:1:1) which is a nice detail, if you're not looking to buy separate materials. I'm sure others have had bad experiences with Omni... but I'd figure I'd support it here
Regardless of what you shoot, I agree that you should stick with one system / manufacturer for all your substrates & final paint. Less chances of having a substandard paint job.... _________________ - Most car projects are like stray dogs..you want to keep them all and never let any of them go.
- Built, not bought.
- Street is neat...support your local street rodders!
1966 L41 113 | 1965 L456 151 | 1963 L380 113 | 1954 L227 113 | 1949 L51 11A |
Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1048 Location: Jacksonville, FL
Posted: Mon Sep 30, 2019 1:54 pm Post subject: Re: Omni epoxy primer any good? |
I have also heard many good things about SPI. I had a conversation with their tech support personnel and they were extremely helpful.
Two separate options have been expressed in this thread. One is the use of SPI (or third party EPOXY/DTM primer) under every paint job and the other is to go with a complete product system. Option two is self explanatory but option one prompts me to ask the following questions:
@56reddy:
- What product line do you use to complement the SPI base?
- Can you share your process for the less experienced among us?
Emil _________________ “…It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.”
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted |
Posted: Mon Sep 30, 2019 3:11 pm Post subject: Re: Omni epoxy primer any good? |
Evil_Fiz wrote: |
@56reddy:
Emil |
I use SPI product for everything except my base color. Depending on the color, I've used Omni, Limco, and PPG for base coat.
So my process goes.......
SPI epoxy
SPI 2k primer
SPI epoxy (1:1 + 10% reducer) as a sealer
Above mentioned Base color
SPI 20/20 Euro Clear _________________ New Vintage Specialist.
gbfan10 Samba Member
Posted: Tue Mar 31, 2020 9:21 pm Post subject: Re: Omni epoxy primer any good? |
Painted my truck with all omni products, Epoxy primer, omni base and omni clear. this was 7 years ago, and it still looks great.
I've also used SPI with good results as well. |
swelchy Samba Member
Joined: January 07, 2013 Posts: 134 Location: Douglasville, GA
Posted: Wed Apr 01, 2020 1:19 pm Post subject: Re: Omni epoxy primer any good? |
I shoot omni on a regular basis... no complaints or issues here and it is a ppg product... _________________ 1969 Westy 1915cc 044 heads 94 bore 69 stroke scatCWcrank scat lifters C25 cam straight cam gears 1:25 ratio rockers CB weber idf 40's vintage speed sport exhaust. |
