robcy04 Samba Member
Posted: Fri Sep 20, 2019 6:55 pm Post subject: Rear Toe question |
I had my 79 Vert aligned after rebuilding the front and rear suspensions. I lowered my car to the bottom ring on the topline strut's (about 4 inches), and lowered the rear one notch (about 3.5 inches).
Is rear Toe adjustable?
Is there a front camber bolt that allows more adjustment?
I am guessing that front Caster is harder to adjust?
I was told that the rears will wear faster because of the Toe, but that it would not be to much. It does drive so much better now. |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Sat Sep 21, 2019 5:21 am Post subject: Re: Rear Toe question |
The rear toe on our cars is adjustable on the springplates, it’s just that most shops never do anything with it since most VW owners don’t want to pay more than $50 for an alignment.
Topline has an extreme eccentric bolt/bushing kit to give extra camber adjustments.
http://toplineparts.com/vw-front-end/camber-kit-for-74-to-79-super-beetle-88-2511l.html
If I’m reading your screen correctly, it looks as if you have 0.9 degrees positive caster on the right, and and the left has 0.5 degrees negative. This will cause your front end to be EXTREMELY sensitive to ANY abnormal tire wear, and most likely be very sensitive/difficult to drive at highway speeds. I’d again look at what Topline has available to gain caster in the way of eccentric sway bar bushings, and angled sway bars. Worst case scenario, you could have material removed at the end of the sway bar to use some stacked shims/washers to allow the arms to be installed on the ends of the swaybar further. I have a friend that adapted a set of Porsche 944 caster plates used ontop of the strut to allow more adjustment for his drag car. I’d be looking to get at least 1.5-2.0 degrees positive caster. |
beetlenut Samba Member
Posted: Sat Sep 21, 2019 3:00 pm Post subject: Re: Rear Toe question |
[email protected] wrote: |
I think I ran into a knowledge level (lack of) in the part of the tech aligning my car. How do you adjust Toe by the spring plate? Do you loosen the 3 bolts and push the assembly back and forth to adjust?
I did not purchase those items, but I definitely will. Thanks for the links. |
Frodge Samba Member
Posted: Sat Sep 21, 2019 3:19 pm Post subject: Re: Rear Toe question |
robcy04 wrote: |
This is why when I do my tie rod end next week I want to try and dial it in myself. Most people have “lack of knowledge”. |
Posted: Sat Sep 21, 2019 3:48 pm Post subject: Re: Rear Toe question |
Frodge wrote: |
In this case the lack of knowledge also applies to me cause I though I ordered everything, but I missed the Camber, and Caster bolts, and bushings. Looking at the process the angle on the screen changes, but the tires do not appear to move. Its really minuscule, I would try to dial it in, but I would definitely get it on a machine. I will take it back to get the rear toe set as it has a 6 month guarantee, but I will ask for a different tech. |
Posted: Sat Sep 21, 2019 4:33 pm Post subject: Re: Rear Toe question |
I just found the caster-fix bushings the other day while looking for something else. I thought I put them on, but nope. They only move the sway bar forward about 1/8 - 1/4 inch,but I guess that provides enough adjustment for a lowered bug. My car goes into the shop Tuesday for it's first alignment after a total rebuild, including the rear toe. The diagonal arms have slots in them where the spring plates attach, allowing fore and aft movement for the toe adjustment. _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
Posted: Sat Sep 21, 2019 5:21 pm Post subject: Re: Rear Toe question |
robcy04 wrote: |
I think I ran into a knowledge level (lack of) in the part of the tech aligning my car. How do you adjust Toe by the spring plate? Do you loosen the 3 bolts and push the assembly back and forth to adjust? |
Yes.
Depending on how low your rear suspension is, if the spring plates are much past parallel to the ground, they start pulling the wheels inward. You may need to elongate the springplate holes to gain a little more movement for adjustment.
Finding someone knowledgeable about our cars isn’t always the issue. Modern alignment machines HAVE the specs for 60’s/70’s cars, including VW’s. Most simply don’t want to deal with the springplate bolts, or pivot bolt if the camber is off. |
MACJELLY58 Samba Member
Joined: September 26, 2014 Posts: 400 Location: HONOLULU, HAWAII
Posted: Sun Sep 22, 2019 1:26 am Post subject: Re: Rear Toe question |
I was wondering the same thing about the rear Toe. I had recently rebuilt my rear end and I measured and marked the the Spring Plate and stuff like I had read about. Then I got the tires on and the right rear looked like it was noticeable Toe in(positive). I don't have picture right now but here is the before putting it on the ground. You can kinda see it Toeing inward. With the tire on, it's really noticeable.
Here's something like what I got (sorry, not trying to out you Vam. )
My wheel visibly looks worse to me. I'll try and re-seat the Pivot arm and eyeball the Spring Plate bolts and adjust. I must have not done a good job with the marking.
Does anyone have a link to thread that covers a DIY alignment to get it close, so I can get it to an alignment shop? |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Posted: Tue Sep 24, 2019 6:46 pm Post subject: Re: Rear Toe question |
I just got back from the alignment shop this afternoon. I provided them with the specs out of the Bentley, and they did a pretty good job on a 4 wheel alignment. Got the toe pretty close in the rear. They could have used more camber up front, but got it as close as they could with the Camber+ kit by Top Line. I am going to look into the camber plates for the top of the struts to give me more adjustment in the future, but I'm happy with the way it drives after being completely torn apart for the last 10 years. _________________ scrapyards are for quitters
Wetstuff wrote: |
goober Samba Member
Posted: Tue Sep 24, 2019 8:01 pm Post subject: Re: Rear Toe question |
In my non-expert experience, (let me stress non-expert) it's not only the toe in the rear, it's the toe in relation to the centerline of the vehicle.
I use a homemade gauge to set the toe while it points to the centerline. I then rotate the gauge, re-check the toe and note how far the pointer is off to one side or the other. You have to have the trans mounted in place for it's the trans center rib that's the centerline of the car (according to Bentley).
The wheel pair need toe plus be parallel to the centerline (or as close as I can get it). I can have proper toe but if my rear wheels are racked to the right or left of the centerline it will make for a skittish handling car on slick surfaces. |
