blitzkrieg59 Samba Member
Joined: July 04, 2001 Posts: 873 Location: Davenport, Iowa
Posted: Wed Sep 25, 2019 12:42 pm Post subject: How to keep roof rack feet/clamps from scratching new paint? |
Picking up my Bus next week with a brand new paint job and I'm putting my VWoA 3/4 rack on top as soon as I can for multiple reasons. I just picked up some plasti-dip to coat the feet and clamps with, but I'm wondering if anybody has any better ideas on how to keep the rack of boogering up my new paint. _________________ SST X, XI, XII
'65 Riviera Camper |
sled Samba Member
Posted: Wed Sep 25, 2019 12:55 pm Post subject: Re: How to keep roof rack feet/clamps from scratching new paint? |
use rubber hose over the feet, and plastic dip (thick) the clamps as you mention.
get a few people to help you set the rack on the bus. Pull the feet down into the gutter tight, then tighten the clamp. Don't use the clamp to suck the feet down (if they are held up the roof skin at all). Make sure all the clamps are tight, as the rack will wiggle slightly in the wind, or with a load on it, and scuff the paint over time.
but ultimately they will show signs of wear eventually... _________________ drive your split. |
Posted: Wed Sep 25, 2019 1:10 pm Post subject: Re: How to keep roof rack feet/clamps from scratching new paint? |
Thanks, Sled! _________________ SST X, XI, XII
flemcadiddlehopper Samba Member
Joined: December 05, 2011 Posts: 2332 Location: Kelowna, BC. Canada.
Posted: Wed Sep 25, 2019 6:06 pm Post subject: Re: How to keep roof rack feet/clamps from scratching new paint? |
You could also buy some of the 3M clear protective film and lay it in the gutter and under where the clamps attach. The film can be removed and replaced as needed and no damage to your paint, even over time, should occur.
Gordo. _________________ Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others. |
Drew Ogden Samba Member
Joined: February 19, 2004 Posts: 329 Location: Elbow Cay, Bahamas
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2078 Location: Bulli Klinik, Colorado Springs
Posted: Thu Sep 26, 2019 9:01 am Post subject: Re: How to keep roof rack feet/clamps from scratching new paint? |
I've used plati-dip and it works great. Be sure to apply in thin coats. A heavy coat will shrink and lift. I also use it on my motorcycle brake/clutch levers and other things. _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Thu Sep 26, 2019 6:11 pm Post subject: Re: How to keep roof rack feet/clamps from scratching new paint? |
flemcadiddlehopper wrote: |
Gordo. |
This is the best answer (though coat the rack parts of course). The idea is to have the protection on the surface that's fixed. The rain gutters aren't going anywhere- but the rack is shimmying around ever-so slightly all the time. _________________
EverettB wrote: |
FU#5 |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9789 Location: Exit 7, New Jersey
Posted: Fri Sep 27, 2019 7:47 pm Post subject: Re: How to keep roof rack feet/clamps from scratching new paint? |
Unfortunately, every repainted bus I've encountered has "weak" paint when compared to original paint. I would expect some damage no matter what you do, though the suggestions above will help to minimize it.
The original factory paint was some tough sh*t! _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
