turbotype1 Samba Member
Posted: Wed Jun 27, 2018 6:30 pm Post subject: Re: Engine gasket layout |
use a single port intake manifold gasket there instead….. _________________
117harv wrote: |
This new fad of get it the lowest, or run it with the worst looks, (patina) isn't cool, it's for the hey everyone look at me crowd, i'm driving a beat down ratty, unsafe, VW, how cool am I ???...your not....
Pissing off the purists since 1997
Wanted: Boyd Motors plate frame
57 Turbo Oval Sliding rag
67 13 window delux walk-thru- now 21
64 all original for the misses
83 Sinka m-TDI diesel |
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
crankbait09 Samba Member
Joined: October 10, 2016 Posts: 1304 Location: Cincinnati, Ohio
Posted: Thu Jun 28, 2018 4:57 am Post subject: Re: Engine gasket layout |
that would explain why I don't see it. Thanks for that.
but isn't the single port intake manifold gasket "metal/tin/aluminum"? _________________ 1963 Ragtop |
Posted: Thu Jun 28, 2018 8:47 am Post subject: Re: Engine gasket layout |
Yes it is but I never had trouble with it leaking anything.
I guess if it got a lot of fluid I could see it more prone to leakage over a paper/cardboard seal.
It does crush though, same as the seal for the large center nut on the oil drain plate and that doesn't leak. _________________ How to Post Photos
Posted: Thu Jun 28, 2018 9:08 am Post subject: Re: Engine gasket layout |
EverettB wrote: |
It does crush though, same as the seal for the large center nut on the oil drain plate and that doesn't leak. |
good point. I didn't think of the oil drain seal. _________________ 1963 Ragtop |
tzepesh Samba Member
Posted: Mon Jul 02, 2018 10:56 pm Post subject: Re: Engine gasket layout |
Here is the gasket set for type 4 engine I got for my 2056. Picture is from CSP website. There are several variations of the parts inside the kit, depending on the type 4 engine (1.7l, 1.8-2.0l 74-78, 2.0l 914, 2.0l 79-83).
And here is a description of the gaskets in the kit:
http://www.ratwell.com/technical/GasketSet.html _________________ '74 1303S, L98B Viperngrun (extra glitter), German Look
'64 1200, Sea Blue, under restoration |
TryToBeOriginal Samba Member
Joined: July 23, 2012 Posts: 266 Location: Georgetown, Texas
Posted: Fri Sep 14, 2018 4:36 pm Post subject: Re: Engine gasket layout |
Looking at the 40hp gasket kit from WW what are the copper rings? there are 2 sizes, 4 of each. Just right of the head gaskets and then just below to the right of the exhaust gaskets. |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Tue Sep 18, 2018 8:28 pm Post subject: Re: Engine gasket layout |
#1 Four rocker stud seals (do not use on heads which only have a chamfer around the base of the stud)
- can someone expound upon this? A buddy of mine got new 040 CB heads and they have an indent for these o-rings. I have a new set of 041's from Mofoco and there isnt an indent. Am I supposed to use these o-rings? _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
chrswlsn Samba Member
Joined: October 13, 2009 Posts: 160 Location: New Jersey
Posted: Mon Feb 04, 2019 8:21 pm Post subject: Re: Engine gasket layout |
The big copper hollow rings are for the "stale air" motors. There's a lip on the head and cylinders where it goes. Look up stale air motors There's some good pics and the differences |
dennismcd707 Samba Member
Joined: October 09, 2017 Posts: 517 Location: Burbs of Detroit
Posted: Sat Sep 07, 2019 10:37 am Post subject: Re: Engine gasket layout |
I have a couple of questions about the type 1 dual port intake manifold gaskets. Are they metal/tin? Why do I have a pair of felt/cardboard gaskets in my set?
And what's the best type of gasket sealer to use here, if any? _________________ 1971 Super Beetle, 1776, dual Weber's, roller crank, big valve modified racing heads, close ratio trans, lowered suspension, 4 wheel disc brakes, car has over 368,000 actual miles. (RIP 1970 Beetle/Baja, 1986 GTI, 1999 Jetta, 2002 Jetta) |
superstarvw Samba Member
Joined: July 23, 2015 Posts: 26 Location: Indianapolis
Posted: Tue Sep 17, 2019 9:33 am Post subject: Re: Engine gasket layout |
This is a very useful post, especially for people like me who build a motor every decode or so...
Like the previous poster, I think it would also be really useful to know where to use Gaskacinch (or other sealants) together with the gaskets (or when not to). I have read many articles, and watched videos, read the books, and its not always clear. And probably there is not always a best practice, just opinions.
based on a previous posted diagram, I just quickly 'drafted' a version (below). I would love some feedback. This is probably one of those can'o'worms like which particular sealer to use between case halves, or what oil to use, but I would find the focused discussion useful, and perhaps others would too.
My motor is almost done. Though all summer long I have learned not to expect a finish date, I think it's going in next weekend!
_________________ '74 Cabriolet (current)
'70 Ghia (sold), '72 Fastback (sold), '73 Super (sold), '71 Std (sold), '75 Std (MIA) |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Fri Sep 27, 2019 6:02 pm Post subject: Re: Engine gasket layout |
Useful thread, thanks for putting here years ago. Gasket part numbers would be neat, but I’m too much of a douche to contribute!
Can’t believe no one has ever raged about the title of this thread not specifying which type of engine the gasket set is for, or how we need separate threads for Type 1 Fuel Injected engines, Industrial engines, Type 3 engines...
What was the last page count on the Crimps vs. Soldering saga? Like 16 pages?
