source for a TDi engine?
0to60in6min
0to60in6min is offline
PostPosted: Sat Sep 28, 2019 8:55 am    Post subject: source for a TDi engine? Reply with quote
I am looking for a new or rebuilt or refurbished TDi engine in PNW - Oregon/Washington.
I have a van with a bad 1.9 TDi 1Z and planning to replace it another one but not sure if it will be the same engine or a newer one such as Boxeer or any other option.
thanks in advance for your help.
dan
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Sat Sep 28, 2019 9:31 am    Post subject: Re: source for a TDi engine? Reply with quote
Assuming it's installed at 50 degrees with some or all of the factory diesel bits, then the 1Z/AHU is fairly unrelated to any of the other TDI variants. You need to consider how much of the current install you want to carry over to the next. If you want an easy swap then another 1Z/AHU is a no-brainer
Casey--
Volkswagens powered by Volkswagen
'01 Weekender VR6 -->2.5 TDI Syncro?
'04 Passat Variant BHW
Oly Bulli
11BC2
11BC2 is offline
PostPosted: Sat Sep 28, 2019 9:36 am    Post subject: Re: source for a TDi engine? Reply with quote
http://www.qualitygermanautoparts.com/
dkoesyncro
dkoesyncro is offline
PostPosted: Sat Sep 28, 2019 9:47 am    Post subject: Re: source for a TDi engine? Reply with quote
Casey is right on the money. The guys at Cascade German had some crate engines but I'm not sure the inventory as of now.
https://www.cascadegerman.com
It's worth an inquiry, the website doesn't have all of their items or what these guys have access too.
mellowslow
mellowslow is offline
PostPosted: Sat Sep 28, 2019 1:16 pm    Post subject: Re: source for a TDi engine? Reply with quote
Cascade German has ALH long blocks
https://www.cascadegerman.com/product/vw-asv-tdi-oem-1-9-long-block/
'87 WBWE FAS Gen V
big swifty
Location: Formally in Republic of VT; now in Hollywood, FL
big swifty is offline
PostPosted: Sat Sep 28, 2019 1:39 pm    Post subject: Re: source for a TDi engine? Reply with quote
I can vouch for Cascade German. Aaron is a standup guy to deal with and knows TDIs. I purchased a factory new ALH long block and other parts from him.
Evan
1987 Vanagon Syncro // Westfalia pop-top graft // Factory new ALH. 11mm IP. AFN 110 RC 2,3,4 // S7 turbo// Titan P502's
2013 Golf 4d TDI. No mods. Yet.
[1991 Jetta coupe TD. Giles Superpump. Custom tall 5 speed. SOLD
