scotty timmerman Samba Member
Joined: January 10, 2010 Posts: 1000 Location: gigharbor W.A
Drewmon Samba Member
Posted: Wed Oct 02, 2019 8:23 am Post subject: Re: 1957 oval build |
I've been busy working on my 57 too.
EverettB Administrator
Joined: April 11, 2000 Posts: 69802 Location: Phoenix Metro
Volksvr6gti Samba Member
Joined: July 22, 2019 Posts: 298 Location: Jacksonville
Posted: Sat Jan 25, 2020 7:25 pm Post subject: Re: 1957 oval build |
very nice that came out clean. excited to see the finished arm rest once it is covered. keep us posted |
Cr430c Samba Member
Joined: December 10, 2019 Posts: 29 Location: Sacramento, CA area
Posted: Sat Jan 25, 2020 7:57 pm Post subject: Re: 1957 oval build |
Beautiful job on every little detail. This thing will be amazing to see done. I'll be following for some inspiration. Has me thinking about how deep I want to get into mine. Keep it coming. _________________ January 1957 oval https://www.thesamba.com/vw/forum/viewtopic.php?t=730746 |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9950 Location: Huntington Beach, CA
Posted: Mon Jan 27, 2020 10:01 pm Post subject: Re: 1957 oval build |
Inspirational! Love the attention to detail.
Is that zinc plating easy to do? Toxic? Thinking I might want to zinc some bolts. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Tue Jan 28, 2020 4:06 am Post subject: Re: 1957 oval build |
Your chassis looks really nice. I am currently working on mine trying to strip all the protective undercoating off. I see from your picture you were using a grinder. This is the same way I have been doing mine. One question is how did you get in all the right areas? Also is that POR-15 that you coated it with? I was talking about coating mine with it and someone here stated it may be better for me to paint or powder coat since my chassis has zero rust and that POR-15 may not stick to the surface of a non rusted chassis. |
Posted: Tue Jan 28, 2020 8:22 am Post subject: Re: 1957 oval build |
Volksvr6gti wrote: |
Yes I was using a grinder with a wire wheel. I only used It on the center tunnel area. The rest I sandblasted with a harbor freight pot blaster. I did coat it with por15. I have used Por15 for many years on lots of projects. I have used it on freshly sandblasted metal, rusty metal, already primed metal and with/without the metal prep. Never have had an issue with it adhering. I also topcoat it with spray paint when it is almost dry and still tacky. Painting or powder coating will result in a nicer finish though. _________________ 71 ghia coupe: Build thread http://www.thesamba.com/vw/forum/viewtopic.php?t=511738&highlight=
71 type 3 fastback auto
71 type 3 fastback manual
73 super beetle
57 oval: build thread: https://www.thesamba.com/vw/forum/viewtopic.php?p=8616563#8616563
63 beetle reassembly: http://www.thesamba.com/vw/forum/viewtopic.php?p=7458619#7458619
2332cc engine build: https://www.thesamba.com/vw/forum/viewtopic.php?p=8608429&highlight=#8608429
84 vanagon westfalia wolfsburg edition |
Posted: Tue Jan 28, 2020 9:51 am Post subject: Re: 1957 oval build |
just curious I was looking at one of those harbor freight pressurized blasters to finish it off and help speed up the process on the hard to reach spots. about how many pounds of sand did you go through? and did you use sand, glassbead, alum oxide? |
Posted: Tue Jan 28, 2020 10:29 am Post subject: Re: 1957 oval build |
oh nice I will look into that then. I plan to do the same thing with setting tarps in my front yard and blasting in the front yard. is that pretty much all you did ... no walls or anything around the blasting area just wide open area? was skeptical about loosing too much of the media with blasting outdoors without anything but a ground tarp. any extra info is appreciated |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Tue Jan 28, 2020 11:35 am Post subject: Re: 1957 oval build |
scotty timmerman wrote: |
Top and bottom of the pan painted in por15 and then a coat of spray paint.
Hello, did you use the brush on por 15 or the spray version?
Thanks |
Posted: Tue Jan 28, 2020 12:56 pm Post subject: Re: 1957 oval build |
Thank you |
Posted: Tue Jan 28, 2020 1:55 pm Post subject: Re: 1957 oval build |
sounds good large tarps and a trip to northern tool it is. thanks for the info and pics they help a lot |
