kuecker2 Samba Member
Joined: September 13, 2019 Posts: 71 Location: Kansas City
Posted: Mon Oct 07, 2019 5:55 pm Post subject: Blaze cut set off in summer heat? |
I have been reading about the Blaze cut. But I will be in Fla. I read they go off just because it is hot? How much of a problem is this? |
WestyWanter Samba Member
Joined: February 15, 2017 Posts: 459 Location: San Diego
Posted: Mon Oct 07, 2019 6:03 pm Post subject: Re: Blaze cut set off in summer heat? |
Wouldn't the temperature in the engine bay be far warmer than at any point weather could cause? Mine was fine in death valley at 110 degrees F... |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Mon Oct 07, 2019 6:07 pm Post subject: Re: Blaze cut set off in summer heat? |
248 degrees is the temperature needed to melt the plug and release the beast.
Has it ever gone over the 100 mark in Miami?
The humidity aspect that can make it uncomfortable for people is irrelevant, so if it would blast off in Miami it would also in Minneapolis.
Just seems a little unlikely.
Like maybe one of those rumors that gets going. _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40
elizer Samba Member
Joined: May 02, 2016 Posts: 1469 Location: Northern Virginia
Posted: Mon Oct 07, 2019 6:20 pm Post subject: Re: Blaze cut set off in summer heat? |
They use it in Dubai. |
kourt Samba Member
Joined: August 13, 2013 Posts: 1949 Location: Austin, TX
Posted: Mon Oct 07, 2019 6:49 pm Post subject: Re: Blaze cut set off in summer heat? |
I have a hot running Bostig, easily topping 245 degrees cylinder head temperature on a hot, 100 degree Texas summer afternoon. No blowout of the Blazecut yet. Mine is mounted around the perimeter of the engine bay.
kourt |
Gangestad Samba Member
Joined: April 15, 2013 Posts: 22 Location: Fletcher, NC
Posted: Mon Oct 07, 2019 6:57 pm Post subject: Re: Blaze cut set off in summer heat? |
I live in south florida and daily drive mine. I’ve had my blaze cut in for a year and a half now with no issues. |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Mon Oct 07, 2019 7:25 pm Post subject: Re: Blaze cut set off in summer heat? |
Same experience in Tucson -- routinely in the 100s, sometimes in 'the teens' - no problem with my Blazecut. |
Westified Samba Member
Posted: Mon Oct 07, 2019 8:45 pm Post subject: Re: Blaze cut set off in summer heat? |
I live in Miami and have had mine installed for 2 years with no problem. The highest temp down here i drove it in was 102 degress. It is unusual to get that hot here. Usually the temp is 90-96 degrees in the summer. Now the heat index is another thing. I have seen 115 degrees heat index. That is the combination of the Temperature and humidity. That is what gets you here, the humidity 80-95 percent in the summer. Brutal. _________________ 1984 Westy Wolfsburg, owned since 1987. FAS 2.0 NA engine conversion in 2022. |
Alaskaberrys Samba Member
Joined: June 19, 2016 Posts: 1001 Location: SE Alaska
Posted: Mon Oct 07, 2019 9:38 pm Post subject: Re: Blaze cut set off in summer heat? |
Last summer we drove out of LA to Sequoia and saw 110° from Palmdale to Mojave. Our indoor/outdoor thermometer was reading over 128° outside as we drove - the bulb is mounted on the undercarriage not far from the scorching asphalt. At a lunch stop - inside temps went up to 135° while we were enjoying the restaurants AC. The engine compartment under all that insulation with bedding and luggage above and hot pavement below must have been well over 250° Nary a problem with the blazecut. Was stressing about the original stock expansion tank however....
(not repeating that adventure) _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
'91 T3 Syncro Doka, Escorial Green 1.9L TD AAZ “Gremian” (to provoke, irritate, exasperate, vex...) |
E1 Samba Member
Joined: January 21, 2013 Posts: 6589 Location: Westfalia, Earth
Posted: Mon Oct 07, 2019 10:34 pm Post subject: Re: Blaze cut set off in summer heat? |
Yep, Blazecut Wives' Tale all right, they'd be out of business by now if true. Engine bays are nowhere near hot enough, and aerated, and vented.
Ours is mounted to the engine cover in a delicate little heart pattern.
Westified wrote: |
I live in Miami and have had mine installed for 2 years with no problem. The highest temp down here i drove it in was 102 degress. It is unusual to get that hot here. Usually the temp is 90-96 degrees in the summer. Now the heat index is another thing. I have seen 115 degrees heat index. That is the combination of the Temperature and humidity. That is what gets you here, the humidity 80-95 percent in the summer. Brutal. |
The Heat Index is how temperature and humidity affect animals -- and has no bearing on the actual stresses on anything else.
Same with wind chill, inversely. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22671 Location: NYC/Upstate/ROW
Posted: Tue Oct 08, 2019 4:16 am Post subject: Re: Blaze cut set off in summer heat? |
Ssdhhh. I sell lots of cold weather batteries on the wind chill number.
I can’t make a living with educated masses. _________________ .ssS! |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Tue Oct 08, 2019 7:21 am Post subject: Re: Blaze cut set off in summer heat? |
Been in Moab, Utah with 106 deg. and in Fort Lauderdale, Florida all summer. Not a problem. _________________ This free advice is worth exactly what you paid for it.
E1 Samba Member
Posted: Tue Oct 08, 2019 7:53 am Post subject: Re: Blaze cut set off in summer heat? |
Abscate wrote: |
I can’t make a living with educated masses. |
Like I said, wind chill makes batteries colder.
Duh. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
