jkidd152 Samba Member
Joined: June 09, 2009 Posts: 408 Location: Portland, OR
Posted: Sat Oct 12, 2019 4:04 pm Post subject: Automatic Transmission nightmare |
At a friends house to help him reinstall his transmission and then this happens
What do you think? Is he screwed? He might try to JB weld it _________________ '85 Syncro Westy |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
Posted: Sat Oct 12, 2019 5:08 pm Post subject: Re: Automatic Transmission nightmare |
Repair in progress
VWagabond Samba Member
Joined: March 19, 2011 Posts: 272 Location: Charlotte, NC
Posted: Sat Oct 12, 2019 7:35 pm Post subject: Re: Automatic Transmission nightmare |
Hope it works....Hey? what-a you got to lose? It's dead already. Good luck, love to hear the results down the road. _________________ The Road Goes Ever On & On……...
VWagabond
87 Camper GL
87 Syncro GL |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Sat Oct 12, 2019 7:57 pm Post subject: Re: Automatic Transmission nightmare |
That's no repair. That is butchery and I know a bit about that. |
Joined: January 01, 2007 Posts: 16883 Location: sticksville, ct.
Posted: Sat Oct 12, 2019 9:04 pm Post subject: Re: Automatic Transmission nightmare |
Butcher wrote: |
X2. that's used car dealer "run it thru the auction" bullshit right there. it may hold for a minute or 2 but I wouldn't go out of walking distance with a 'repair' like that _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
jimf909 Samba Member
Posted: Sat Oct 12, 2019 10:07 pm Post subject: Re: Automatic Transmission nightmare |
I’ve seen JB weld hold parts together for 30 years and counting. In some cases (no pun intended) there’s no chance it will work, in others, it’s an entirely reasonable option. This appears that it may be the latter.
If you’re a pro and banking your reputation on the result using JBweld would be dumb. If you’re fixing your own van and understand the consequences it may be a risk worth taking.
Looking forward to hearing the outcome. _________________ - Jim
Abscate wrote: |
Posted: Sat Oct 12, 2019 10:55 pm Post subject: Re: Automatic Transmission nightmare |
I would have put a nice flat piece of metal under that board and then tightened the crap out of the C-clamp. Don't want the repair to be raise up at all compared to the rest of the surface. |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6360 Location: Honolulu,Hawaii and France
Posted: Sat Oct 12, 2019 11:59 pm Post subject: Re: Automatic Transmission nightmare |
Grease the square o`ring well when assembling, as to not force on your repair and you might be fine. If thers`s room, make a reinforcement from the inside.
Or you could have it welded, ductile iron I believe it is. Not many people know how. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Sun Oct 13, 2019 8:12 am Post subject: Re: Automatic Transmission nightmare |
I have a good used differential I could let go for a good price if it comes to that. Hope the repair works. I’ve seen JB weld perform small miracles. _________________ ☮️ |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9618 Location: Western WA
Posted: Sun Oct 13, 2019 9:03 am Post subject: Re: Automatic Transmission nightmare |
ALIKA T3 wrote: |
Grease the square o`ring well when assembling, as to not force on your repair and you might be fine. If thers`s room, make a reinforcement from the inside. |
Agreed a pro can't do that, but shadetree could be OK, as long as you're OK with taking it all apart again if it leaks.
Doing it then selling right away it is not real nice, but if it goes a few years and no leaks.....
Per AlikaT3 .... (and not seeing it in-person, I don't know the purpose of that gap...) carefully fit some steel supports across to the inside, that fill the gap completely and support the constant 0-ring pressure.
O-ring pressure is trying to break your JB-weld, it's a LOT of force across a couple inches of 0-ring.
Carefully JB-Weld the supports in-place too.
It's a risk but it could work. _________________
....KTMs, GasGas, SPOT mtb
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1858 Location: anchor pt. alaska
Posted: Sun Oct 13, 2019 10:04 am Post subject: Re: Automatic Transmission nightmare |
Too late now, wouldn't brazing it in place have been a good choice here? |
Sodo Samba Member
Posted: Sun Oct 13, 2019 11:45 am Post subject: Re: Automatic Transmission nightmare |
I like brazing too.
That requires a skill, some brazing equipment, probably complete teardown.
I don’t know anything about that housing or if complete teardown is a big deal.
I suppose it can be done later if the JB doesn’t survive. _________________
....KTMs, GasGas, SPOT mtb |
vwfreek61 Samba Member
Joined: May 31, 2004 Posts: 350 Location: Green Bay, WI
Posted: Sun Oct 13, 2019 12:34 pm Post subject: Re: Automatic Transmission nightmare |
That area isn't under any stress, it's just a sealing surface. So as long the JB weld is filed smooth, it should be fine. _________________ Kenneth
1964 Bug with Saxomat
1976 VW/Harley Trike Autostick
1987 Vanagon Westy w/Subaru EJ25 and reversed 4EAT |
SyncroButter Samba Member
Joined: February 02, 2016 Posts: 383 Location: Seattle
Posted: Sun Oct 13, 2019 12:46 pm Post subject: Re: Automatic Transmission nightmare |
vwfreek61 wrote: |
That area isn't under any stress, it's just a sealing surface. So as long the JB weld is filed smooth, it should be fine. |
+1, I would worry less about whether the repair will hold (jb weld is pretty stout and the surfaces should have plenty of tooth) and more about how well the resulting seal surface is planed but seems like a decent shot at a long tern fix here. In any case, nothing to lose and assuming dropping an auto trans on a vanagon is as simple as dropping a standard trans then you're not gambling an insane amount of remove and replace time if it does fail. _________________ Grant
In the stable: 1986 Syncro Westfalia/Bostig, 1989 Doka Tristar, 1974 Vespa Rally 200, 1973 Vespa Primavera 125, 1963 Solex 2200, 1938 Buick Special
Gone but not forgotten: 1989 Porsche 944, 1973 Standard Beetle |
Posted: Sun Oct 13, 2019 3:36 pm Post subject: Re: Automatic Transmission nightmare |
Sodo wrote: |
I like brazing too.
I suppose it can be done later if the JB doesn’t survive. |
Soldering requires less heat and the job could probably be done with nothing more than a propane torch. |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Sun Oct 13, 2019 5:38 pm Post subject: Re: Automatic Transmission nightmare |
It will be fine. Thats not even mid-pack for the things this surprisingly high end epoxy can and will do. Just seal pressure here. Perfect fix though certainly not something a shop should do, as they get paid NOT to do this stuff. Carry on. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2332 Location: Southeast Kentucky
Posted: Sun Oct 13, 2019 7:09 pm Post subject: Re: Automatic Transmission nightmare |
vwfreek61 wrote: |
I agree......... should be fine! _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003. |
