Braukuche Samba Member
Posted: Mon Oct 14, 2019 5:42 pm Post subject: New steering box choices |
I am tearing my front end apart because most of the components are original and worn on my 1969 convertible.
The steering was mega sloppy to I'm redoing all the tie rods, ball joints, and of course the front brake rotors are under spec so they are going, too. Calipers are original ATEs and are good.
The shocker was I went to check the fluid level on the steering box and the top of it was loose! As in sliding around, 1/16 gap...how that happens is beyond me, but I figure it's got no oil in it, probably tons of dirt and explains the slop so it's going.
CIP1 sells two boxes, a Chinese one for $90 and a TRW one for $200. My gut says buy they TRW one, but I wonder if anyone has any experience with the Chinese one. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
crocteau Samba Member
Joined: March 31, 2005 Posts: 1204 Location: Philaburbia
Posted: Tue Oct 15, 2019 4:36 am Post subject: Re: New steering box choices |
Braukuche wrote: |
My gut says buy the TRW one... |
I'd say go with your gut. Although there's an good thread somewhere on TheSamba that decries TRW steering boxes and gives a detailed photo essay on rebuilding the one that came with, several years ago I opted to replace the loosey goosey original in my '71 and have had no issues since. YMMV |
bhartwell59 Samba Member
Joined: December 28, 2014 Posts: 791 Location: dallas, tx
Posted: Tue Oct 15, 2019 5:20 am Post subject: Re: New steering box choices |
TRW! If you don't have the time and patience to rebuild your original.
As crocteau said, there is a pretty good and informative thread on rebuilding a steering box (Beetle forums?) _________________ '74 Zambezi green Ghia vert, autostick, 101k
'87 Jeep Wrangler, 4.2, 330k |
scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2661 Location: Long Island, NY
Posted: Tue Oct 15, 2019 5:46 am Post subject: Re: New steering box choices |
crocteau wrote: |
Braukuche wrote: |
It's in the Type 3 section:
https://www.thesamba.com/vw/forum/viewtopic.php?t=660446 _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
– D. Tartt, 'The Goldfinch' |
Ojai63dbl Samba Member
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6595 Location: Houston, Texas
Posted: Tue Oct 15, 2019 9:22 am Post subject: Re: New steering box choices |
Buy a new TRW and sent it off to have it rebuilt correctly. You can also ask the rebuilder to make one for you. _________________ www.vwnos.com [email protected]
Posted: Tue Oct 15, 2019 12:17 pm Post subject: Re: New steering box choices |
Read that thread, thanks for the link.
Made me take a second look at my box. I had my wife move the steering wheel and looks like it is responsive so I think I will bolt it up, add oil and see what happens. If it's sloppy or leaks once I get the front end back together I'll rebuild it myself.
You guys saved me $200! _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
