*VWFamily* Samba Member
Joined: June 08, 2005 Posts: 18 Location: St. Louis, MO
Posted: Tue Nov 16, 2010 5:34 pm Post subject: |
Actually those r the same wires that I have. The blue are connected together like in the pic but i have one black wire connected to each of the white braided wires.. |
seventyfo Samba Member
Joined: February 13, 2007 Posts: 916 Location: Ocoee FL
Posted: Tue Nov 16, 2010 7:40 pm Post subject: |
here ya go The black wires connect together and the blue wires go to each side of the white ones. |
Posted: Wed Nov 17, 2010 5:07 pm Post subject: |
Success, after messing around with the fridge to no avail, I decided to purchase a multimeter. Well that was a learning lesson of its own, never used one. I messed with that not knowing how to use it correctly and getting incorrect readings. One thing I did learn was how to find out if there is conductivity. So I started to mess around. To my surprise one of the wire to the thermostat, although looked like it was connected, had come loose. Fix the problem, put everything back together and within minutes the element began to heat up and within 20 mins I had an ice cold fridge. If I had a recommendation, I would started with the conductivity test. It would have save me a whole lot of time. Thanks everybody for ur help.. Alex |
Posted: Wed Nov 24, 2010 6:54 pm Post subject: |
Just wanted to post what the correct wiring for the thermostat. Thanks for all the help.
BoltonFTW Samba Member
Joined: February 18, 2017 Posts: 102 Location: San Francisco
Posted: Sun Oct 13, 2019 10:59 pm Post subject: |
Just wanted to thank this thread, BD, and the samba because it helped me fix a non-functional refrigerator in my 78 westfalia. The bartnik link above was crucial in diagnosing my issues with the rectifier underneath the rear seat.
My fridge was working fine on the auxiliary battery power- but when I plugged in the shore power and switched it over to "city power" on the control panel the fridge would no longer function.
First, I checked the 20A (yes "20A MAX" according to the rear sticker on the rectifier) and it was blown. Great! this will be an easy fix. I replaced it with a brand new one but still had no voltage coming out of the rectifier based on this test in the bartnik link:
Look at your converter -- it has a Romex cable from breaker box to right rear corner. Out of left rear corner are three wires -- 2 white + 1 red. The red one is power out with breaker on. You should have 0 volts with breaker off. Flip breaker and you should have 14.5 volts. If you do converter works -- if you don't, replace it.
So I figured my rectifier is dead. But further investigation. I checked for continuity of the circuit when the new fuse was plugged in by using the fuse holder as my contact points.. I had none. Hmm. Turns out the fuse holder was at fault. In my case it was very corroded at its connection points inside the clamps (difficult to see) that hold the fuse. I cleaned the clamps and voila-- fridge light would now come on in the control panel and I was now getting the 14.4V output from the rectifier.
I know there are a variety of things that go wrong with late bay refrigerators but just thought I would add my solution to this thread hoping to help someone else who may have a similar issue. _________________ Drew
1978 Westfalia Campmobile Deluxe 2.0 FI w/hydraulic lifters
1977 Westfalia Weekender Tintop (very first car - SOLD )
1992 VW Corrado VR6 (SOLD) |
Hoody Samba Member
Posted: Mon Oct 14, 2019 9:43 am Post subject: Re: Fridge issues ( refrigerator ) not working |
For anyone who plans on keeping their Westy and using their fridge long term I would strongly reccens purchasing one of the new upgraded heating elements for sale in the classifieds. They are excellent and work better than the originals. A Samba member had these reproduced and hopefully will continue to do so. |
Slip356 Samba Member
Posted: Mon Oct 14, 2019 2:25 pm Post subject: Re: Fridge issues ( refrigerator ) not working |
Who is the vendor with the improved heating elements?
Slip |
Hoody Samba Member
Posted: Wed Oct 16, 2019 5:17 pm Post subject: Re: Fridge issues ( refrigerator ) not working |
Search fridge heating element. It's not a vendor but a Samba member. |
