Fix / Prevent Vanagon syndrome / Idle by making a donation
vanis13
vanis13 is offline
PostPosted: Wed Jul 13, 2011 9:33 am    Post subject: Fix / Prevent Vanagon syndrome / Idle by making a donation Reply with quote
Fix or Prevent Vanagon Syndrome and/or smooth out your Idle by making a donation.
I have a number of 16V 22uF Tantalum capacitors which are used to fix or prevent Vanagon syndrome and/or smooth out idle issues which appear in various degrees in the early through late Vanagons.
Search “vanagon syndrome” for a large number of topics on this or here is a good summary - http://www.thesamba.com/vw/forum/viewtopic.php?t=3...highlight=
More detail here - http://www.members.shaw.ca/bilbo/WBafm.html
I’ll mail one of these Tantalum capacitors to you, all I ask is that you make a $5 or greater donation to either –
The USA Hang Gliding Team – They’re off to the biennial World championships wich run 7/16-30/11 - http://www.cucco2011.org/ . Wish them luck. Reporting will happen here – http://ozreport.com/
Home page - http://www.flytec.com/worldteam/index.html
Info page - http://www.flytec.com/worldteam/theteam.html
Donate - http://www.ushgteam.com/support.html
OR
The Cloudbase Foundation – a foundation that supports underprivileged children in the US and abroad. The foundation is run and mostly funded by hang glider and paraglider pilots.
Home page – http://thecloudbasefoundation.org/
Info page - http://thecloudbasefoundation.org/aboutus.html
Donate - http://thecbf.net/Donate.asp
After you make your donation email or PM me your mailing address and I’ll get the capacitor out to you.
Andrew
[email protected]
To learn more about hang gliding or paragliding –
http://www.hanggliding.org/
http://ushpa.org/
pinetreeporsche
pinetreeporsche is offline
PostPosted: Mon Sep 16, 2019 2:34 pm    Post subject: Re: Fix / Prevent Vanagon syndrome / Idle by making a donation Reply with quote
Andrew- I sent you a note on your gmail- need a donation address because the one on your site says no can find. Just realized I didn't send you my mailing address: L. Chris Hager 3611 Pinetree Terr. Falls Church, VA 22041
vanis13
vanis13 is offline
PostPosted: Mon Sep 16, 2019 4:21 pm    Post subject: Re: Fix / Prevent Vanagon syndrome / Idle by making a donation Reply with quote
Thanks chris for letting me know. I'll get it in the mail.
any of these projects will work
https://www.thecloudbasefoundation.org/current-projects
vanis13
vanis13 is offline
PostPosted: Mon Sep 16, 2019 9:19 pm    Post subject: Re: Fix / Prevent Vanagon syndrome / Idle by making a donation Reply with quote
its in the mail. thanks for supporting freeflight and those connected to it
pinetreeporsche
PostPosted: Thu Oct 17, 2019 7:53 am    Post subject: Re: Fix / Prevent Vanagon syndrome / Idle by making a donation Reply with quote
Should have sent this Q a month ago: Do you have a schematic diagram or a brief paragraph on where it gets put into what circuit-- or a link to one Thx -C
vanis13
vanis13 is offline
PostPosted: Thu Oct 17, 2019 12:11 pm    Post subject: Re: Fix / Prevent Vanagon syndrome / Idle by making a donation Reply with quote
The links in the first post is what I have. Seems like the shaw link of dear. The other samba one looks like it could go somewhere. I'm not subi powered so though I still have these electronics I haven't followed the syndrome. I would suggest the helpful samba community. Sorry I can't be more help.
0to60in6min
0to60in6min is offline
PostPosted: Thu Oct 17, 2019 12:24 pm    Post subject: Re: Fix / Prevent Vanagon syndrome / Idle by making a donation Reply with quote
this is the link for Vanagon syndrome
http://www.benplace.com/vanagon_intermittent_syndrome.htm
