Which Kit? |
GoWesty |
29% |
[ 13 ] |
Burley |
40% |
[ 18 ] |
SmallCar |
6% |
[ 3 ] |
Other |
22% |
[ 10 ] |
Total Votes : 44 |
WestleyTheWesty Samba Member
Joined: October 07, 2015 Posts: 128 Location: Portland, OR
Posted: Fri Oct 11, 2019 4:04 pm Post subject: Re: Which Big Brake Kit? |
We're going to pull the trigger on big brakes in the next few months, so I'm excited to follow this thread. I keep going back to the Burley kit because none of it is really proprietary and probably easier to replace parts than the GW kit (which seems to go out of stock regularly). It looks like Burley recently switched from dual piston to single piston? _________________ 1990 Westy, started stock, not anymore! |
SyncroChrick Samba Member
Joined: January 10, 2005 Posts: 1010 Location: San Francisco, CA
Posted: Fri Oct 11, 2019 4:36 pm Post subject: Re: Which Big Brake Kit? |
I wonder if these work with a Syncro |
SurfaceRust Samba Member
Joined: January 24, 2016 Posts: 160 Location: Los Angeles
Posted: Fri Oct 11, 2019 5:20 pm Post subject: Re: Which Big Brake Kit? |
Thanks for the input everyone. I'm not quite sure I want to do a custom one. Burley is looking good because of the availability of parts |
DigiMatrix Samba Member
Joined: April 20, 2010 Posts: 450 Location: Up North Canada
Posted: Fri Oct 11, 2019 8:21 pm Post subject: Re: Which Big Brake Kit? |
Thanks. Looking at this, it looks like it's using rear calipers. I am not sure how much of an improvement that would be.
Posted: Fri Oct 11, 2019 10:32 pm Post subject: Re: Which Big Brake Kit? |
Yes, I believe you are correct. I have found some details on the piston sizes:
2 x 28mm
2 x 30mm
Seems a little small |
Team WorldTour Samba Member
Joined: September 02, 2010 Posts: 2426 Location: Der Vaterland
Posted: Sun Oct 13, 2019 2:38 am Post subject: Re: Which Big Brake Kit? |
If you buy the GW kit, you don't have to go to them for replacement parts. Yeah, they contracted with a brake part manufacturer to design and build the BBK, but they used off the shelf parts to do it. The caliper bracket and disks are from one car, the caliper and pads from another. They work great together, and with the E36 booster upgrade, I've never been happier with my brakes.
The only time my brakes showed any weakness was last year, driving in the Austrian Alps, we had to follow a farmers tractor down a 3 kilometer, 12% grade hill, with no chance to pass. As in, we were forced to drive his speed, and drag the brakes constantly. Stink, smoke, brake fade, it all happened. The van sits at 2060 kg normally, but packed for a two week driving holiday, it was maybe closer to 2500 kg.
I have to say, this is the only time I ever had any issue with these brakes. When we got back home, I gave the system a thorough once over, and found no issues. Scuffed up the pads a bit, shaved maybe .01mm from the disks, and all was right with the world! _________________ 1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat! |
vik Samba Member
Joined: January 13, 2005 Posts: 204 Location: back in Czech
Posted: Sun Oct 13, 2019 3:31 am Post subject: Re: Which Big Brake Kit? |
Hi
Anybody tried the Burley BBK on Syncro with the CLKs?
Would it fit without spacers?
Thx _________________ T3 Syncro camper in progress |
elizer Samba Member
Joined: May 02, 2016 Posts: 1469 Location: Northern Virginia
Posted: Sun Oct 13, 2019 5:33 am Post subject: Re: Which Big Brake Kit? |
vik wrote: |
Hi
Thx |
I do. No issues. |
vik Samba Member
Posted: Sun Oct 13, 2019 8:54 am Post subject: Re: Which Big Brake Kit? |
Thank you
Actually - the caliper is single pot, right? _________________ T3 Syncro camper in progress |
Vashon Samba Member
Joined: September 23, 2012 Posts: 200 Location: Vashon Island
Posted: Thu Oct 17, 2019 3:52 pm Post subject: Re: Which Big Brake Kit? |
After reading this thread I do like the idea of porsche brakes ,but I fell victum to gowesties 15% off sale last weekend and in a moment of weakness bought their brake kit and hubs. So you can put me down for gowesty. I wanted something uncomplicated. The price and discount and simplicity pushed me over the edge. I hope I was not penny wise and dollar foolish regarding possible proprietary parts needed down the road. At least the brake pads are standard. |
jimf909 Samba Member
Posted: Thu Oct 17, 2019 10:41 pm Post subject: Re: Which Big Brake Kit? |
^^^ I don’t believe you’ll regret this choice. It’s a good solution that works darn well. Different solutions work well for others. Simple as that.
Enjoy. _________________ - Jim
Abscate wrote: |
calsurf Samba Member
Posted: Mon Jan 16, 2023 7:32 pm Post subject: Re: Which Big Brake Kit? |
Considering upgrading the brakes front & rear, any other brake systems to consider or are these the go-to options? |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6361 Location: Honolulu,Hawaii and France
Italjohn Samba Member
Joined: October 29, 2016 Posts: 193 Location: Molde, Norway
Posted: Tue Jan 17, 2023 10:50 am Post subject: Re: Which Big Brake Kit? |
ALIKA T3 wrote: |
calsurf wrote: |
Are you looking for plug and play? |
Open to all ideas. |
Posted: Tue Jan 17, 2023 11:00 am Post subject: Re: Which Big Brake Kit? |
For DIY, I brought up to light the Jaguar 4 piston caliper. Search Jaguar caliper on the forum.
It's a pretty cheap option but will not fit all wheels. It does fit the popular 16" forged Fuchs found on Mercedes CLK.
Some people later found out the Jaguar rotor actually fit well with it.
I can confirm the match is great on a post 85 spindle 2WD. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Franklinstower Samba Member
Posted: Tue Jan 17, 2023 12:21 pm Post subject: Re: Which Big Brake Kit? |
ALIKA T3 wrote: |
I can confirm the match is great on a post 85 spindle 2WD. |
Agreed Alex!
I'm still running the same jag front big brakes I installed a long time ago... 8-10 years?
Matched to the Epytec Eurovan rear disc brakes. This combo is really good! The bias is very well matched. Plus an excellent handbrake. I couldn't be more pleased with the upgrade.
Paul _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug |
