xzener Samba Member
Posted: Sun Oct 20, 2019 11:14 am Post subject: Re: The Aufgeladen Ghia |
Car is on jacks. Finishing up wiring the electric pump and relay. Then the engine will be removed to install the supercharger setup. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
xzener Samba Member
Posted: Sun Oct 20, 2019 3:19 pm Post subject: Re: The Aufgeladen Ghia |
Alright. Fuel pump/relay wired up and functioning properly. Only turns on when the engines is cranking/running. Tied in to air ride breaker switch, so it is an emergency cutoff as well. The engine is pulled. Taking everything not needed off. SP intake, mechanical fuel pump, etc. Mocking up the new intake ports. Will be adding vacuum ports to both of them to tie into the Black Box and Boost gauge. Will post pictures after I get done competing the AMR500/Weber DCOE 40 install. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
xzener Samba Member
Posted: Mon Oct 21, 2019 5:33 pm Post subject: Re: The Aufgeladen Ghia |
Quick update. Replaced the long fuel pump studs with shorter ones allowing the supercharger mounting bracket to fit and tighten properly. Have the bracket and pulleys installed. Had to buy a pulley removal tool to get the stock crank pulley off. Bought a 5mm .80 tap to drill/tap the vacuum ports on the manifold. Will get those drilled/tapped tomorrow and install the intake manifold. Things are coming along nicely. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
xzener Samba Member
Posted: Wed Oct 23, 2019 6:11 pm Post subject: Re: The Aufgeladen Ghia |
Ok... Not sure if anyone is following, but I'm documenting my build as I go. Vacuum ports are drilled, tapped and lines are installed. I used JB Weld on the threads. Seen it in another thread, I think it was in performance/engine/transmission forum. Intake manifold is in place. Started putting the AMR500 on, but I need to tap the mounting holes. Don't think they were used in the past. Here is a teaser pic...
TRS63 Samba Member
Joined: December 17, 2017 Posts: 1000 Location: Stuttgart - Germany
xzener Samba Member
Posted: Thu Oct 24, 2019 9:38 am Post subject: Re: The Aufgeladen Ghia |
AMR500 mounting holes tapped. Got everything mocked up, now to tighten everything down. Have the Weber DCOE 40 in place just to see the overall look. This thing looks bad ass! This was fairly easy to install, some of the manifold bolts on the intake side were difficult to start. Easier to remove the intake manifold off the boot, after that, no problem.
Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1049 Location: Jacksonville, FL
Posted: Thu Oct 24, 2019 2:05 pm Post subject: Re: The Aufgeladen Ghia |
I love the look and sound of a twin screw blower.
Keep the updates coming.
Emil _________________
It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted |
xzener Samba Member
Posted: Thu Oct 24, 2019 6:16 pm Post subject: Re: The Aufgeladen Ghia |
Me too Emil! Cant wait to hear what she sounds like. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
xzener Samba Member
Posted: Thu Oct 24, 2019 9:05 pm Post subject: Re: The Aufgeladen Ghia |
Forgot to mention, while the engine is out, I will be installing a truss bar. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Inchpincher61 Samba Member
Joined: February 05, 2016 Posts: 141 Location: Germany
Posted: Fri Oct 25, 2019 12:44 pm Post subject: Re: The Aufgeladen Ghia |
Looks really nice man
I am really excited if this is really going to work plug and play without any carb-science!
Keep us up to date!
xzener Samba Member
Posted: Sat Oct 26, 2019 10:28 am Post subject: Re: The Aufgeladen Ghia |
Without carb-science... It's been fully re-jetted, new much smaller chokes. Recommend initial setup by Mick from Joeblow. Will probably have a lot of trial and error to achieve best performance though I'm sure. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
thomas. Samba Member
Joined: July 31, 2010 Posts: 1291 Location: South West (Pa.)
Posted: Sun Oct 27, 2019 4:17 am Post subject: Re: The Aufgeladen Ghia |
It will definitely work. I had one on my '62 bug with a 1385 cc, You will have to address the distributor advance. Meaning you don't want advance with boost. You will also want a boost gauge. You can pick these up for almost nothing , You just need a port somewhere after the supercharger. I drilled a hole in the bottom plate of mine and installed one of those barbed brass fittings. |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Sun Oct 27, 2019 7:06 am Post subject: Re: The Aufgeladen Ghia |
Nice work thus far, but the SC mount looks a bit flimsy... I'm used to seeing more support.
http://thedubshop.com/amr500-mounting-bracket/
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
xzener Samba Member
Posted: Sun Oct 27, 2019 9:57 am Post subject: Re: The Aufgeladen Ghia |
Thanks Thomas. Yes, I have a boost gauge. Haven't installed it yet. The advance is controlled by CB Performance Black Box. The dizzy is locked out, and the BB controls the spark with a fully customizable MAP table. I've installed vacuum ports on both SP intake manifolds. Will connect them via a T fitting and tie them into the BB and boost gauge. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
xzener Samba Member
Posted: Sun Oct 27, 2019 5:07 pm Post subject: Re: The Aufgeladen Ghia |
So after measuring for a new belt and placing one on order, I decided to run fuel and vacuum lines in preparation of getting the engine ready for reinstallation... I have unfortunately found a vacuum leak on the T manifold. Have to take everything apart to fix it. Ugh... This sucks.
UPDATE: Mick from Joeblow Superchargers is sending out another T manifold at no cost! How's that for customer service? _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
xzener Samba Member
Posted: Tue Oct 29, 2019 6:14 pm Post subject: Re: The Aufgeladen Ghia |
New pulley installed. It will work, plenty of adjustment. Just need to bend and reposition the accelerator cable guide.
PeteSC Samba Member
Posted: Tue Oct 29, 2019 6:32 pm Post subject: Re: The Aufgeladen Ghia |
Stout looking engine! Nice job, looking forward to hearing it! |
xzener Samba Member
Posted: Thu Oct 31, 2019 5:38 pm Post subject: Re: The Aufgeladen Ghia |
Loosened up the tranny and got the truss bar linkage installed on the frame horns. Unfortunately, didn't pull the tires when I lifted the car to remove the engine. Don't have an impact wrench to remove the lugs... So have to finish installing the boost gauge (painted the mounting bracket), install the air ride tank setup so I can lower the car on the ground to loosen the lugs. What a bother. Still awaiting the T manifold from Australia, so no hurry... Happy Halloween everyone, have a safe night out. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
xzener Samba Member
Posted: Sat Nov 09, 2019 11:33 am Post subject: Re: The Aufgeladen Ghia |
New T manifold installed. No more vacuum leak. Question... I bought CB Performance's alternator pulley. I have no shims installed, and the belt is still a tad loose. Can the fan belts be ordered smaller than stock? Or should I buy a new belt and go from there?
crocteau Samba Member
Joined: March 31, 2005 Posts: 1204 Location: Philaburbia
Posted: Sat Nov 09, 2019 3:31 pm Post subject: Re: The Aufgeladen Ghia |
xzener wrote: |
... the belt is still a tad loose. |
Looking good!
I'm thinking in anticipation of some awesome throttle response a fan belt that's a tad loose might save your fan |
