VW Addict Samba Salesman
Posted: Sun Nov 03, 2019 3:21 pm Post subject: 1914cc Built Engine Overheating? Will run Cold not hot Questions |
I bought a 1914cc engine in a car, and it will start and run when it's cold and idle just fine, until it warms up. Dual 44's, the works...
After it warms up, you cannot start it, unless you jump start it. It will die after warming up, or driving it for a few minutes. The only way to start it back up, is to jump start it.
When you try and start it up after it dies... it turns over VERY very slowly...
I have a brand new battery in it.
I am stumped.. any help is appreciated. |
slalombuggy Samba Member
Posted: Sun Nov 03, 2019 3:51 pm Post subject: Re: 1914cc Built Engine Overheating? Will run Cold not hot Questions |
Have you looked at the cable ends, starter bushing, ground strap, had the starter tested? Lots of threads on hard starting engines.
brad |
Posted: Sun Nov 03, 2019 5:35 pm Post subject: Re: 1914cc Built Engine Overheating? Will run Cold not hot Questions |
slalombuggy wrote: |
brad |
But starts very quickly without issue when it's cold...
And seems like it runs HOT. |
bigdaveb Samba Member
Posted: Sun Nov 03, 2019 6:46 pm Post subject: Re: 1914cc Built Engine Overheating? Will run Cold not hot Questions |
VW Addict,
I could be wrong, but it seems like there may be two separate, yet related, issues. You mention that the engine runs hot, so it may be a good idea to make sure that ALL the tins are in place, thermostat flaps are functioning, engine bay is properly sealed, timing is correct, etc. - basically anything that could be out of sorts that would cause the engine to get too hot.
Related to an overly hot engine, there may issues with the fuel system and the starter. From you description, it seems that the starter may be suffering from heat soaking. Excessive heat typically causes increased resistance in conductors, not only in the starter windings, but also the starter solenoid at times. This really depends on how hot the engine and exhaust system gets. The jump start could be helping to create just enough "break over" power to overcome this resistance. As an experiment, you could wrap the starter assembly with heat shielding and see if the symptoms persists.
As Slalombuggy says, check all the basics - but it also may be a good idea to do a thorough inspection of the above-mentioned items, since it seems that there is a chronic thermal issue. Perhaps some photos would also be helpful to identify some of the issues.
Hope this helps. |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3817 Location: Georgia
Posted: Sun Nov 03, 2019 6:59 pm Post subject: Re: 1914cc Built Engine Overheating? Will run Cold not hot Questions |
By won’t start, do you mean the starter isn’t spinning or that it just turns over but won’t fire? Is it spinning and firing but won’t catch? _________________ Volkswagen!
(Compression 8.7:1) |
Posted: Sun Nov 03, 2019 7:12 pm Post subject: Re: 1914cc Built Engine Overheating? Will run Cold not hot Questions |
jeffrey8164 wrote: |
By won’t start, do you mean the starter isn’t spinning or that it just turns over but won’t fire? Is it spinning and firing but won’t catch? |
When warm... turns over like a 6v, or slower... and not enough to start it.
New battery. No issues starting when cold. Idles great... but once hot, dies. |
Posted: Sun Nov 03, 2019 8:13 pm Post subject: Re: 1914cc Built Engine Overheating? Will run Cold not hot Questions |
Electrical resistance goes up with temperature. IF you have a bad cable or end and it's hot it might not pass enough amperage to turn over a starter. Also if the starter motor is bad or if it is dragging due to a bad bushing it will be dragging the available voltage to power things like coils down and can cause a no start.
brad |
Posted: Sun Nov 03, 2019 8:36 pm Post subject: Re: 1914cc Built Engine Overheating? Will run Cold not hot Questions |
VW Addict wrote: |
When it dies, is it sudden stop or is a gradual sputtering? This may be helpful to determine if an electrical issue or fuel issue is causing the engine to die. I'm still under the impression that the hot starting issue is related to heat saturation. |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Mon Nov 04, 2019 3:41 am Post subject: Re: 1914cc Built Engine Overheating? Will run Cold not hot Questions |
check the timing? _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Mon Nov 04, 2019 5:08 am Post subject: Re: 1914cc Built Engine Overheating? Will run Cold not hot Questions |
madmike wrote: |
check the timing? |
And we have a winner!!! _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Posted: Mon Nov 04, 2019 8:58 am Post subject: Re: 1914cc Built Engine Overheating? Will run Cold not hot Questions |
I have adjusted the valves. A few were tight.
I have adjusted the timing, to where it needs to be, It was off a little.
It seems like it may be running better, but my problem still exists. |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Mon Nov 04, 2019 9:31 am Post subject: Re: 1914cc Built Engine Overheating? Will run Cold not hot Questions |
VW Addict wrote: |
I have adjusted the timing, to where it needs to be, It was off a little. |
And that is? |
Posted: Mon Nov 04, 2019 6:15 pm Post subject: Re: 1914cc Built Engine Overheating? Will run Cold not hot Questions |
I’m going on the electrical gremlin bandwagen as well, for now.
Clean all the ground points including the tranny strap.
If it persists then I would suspect the starter motor.
I’ve seen timing and valve errors cause a slow rotation on start but there was always coughing involved and they would be evident cold or hot.
My money is on the starter. When it gets hot (ie. engine temperature) either the inductance of the windings change or a bearing starts to drag.
Interestingly enough, my old 1914 started to barely turn over as well.
Turned out it was on its way to seizing completely. Lots of internal problems. Anyway, that turned over slowly cold as well so I’m not trying to suggest that your engine is shot.
Holy Cow!
I didn’t realize starters are that expensive now!
I paid $59.95 for a new Bosch SR15. Granted, that was 15 years ago but now they’re $100.00 more?
I should’ve bought a pallet of them back then. It could fund my retirement. _________________ Volkswagen!
nextgen Samba Member
Joined: August 19, 2004 Posts: 6025 Location: CONGERS, N.Y.
Posted: Mon Nov 04, 2019 7:16 pm Post subject: Re: 1914cc Built Engine Overheating? Will run Cold not hot Questions |
Years ago ----- LIke 45 years ago I had a similar problem. Would drive from 35 miles to my parent home and the car started fine cold. When i arrive and shut it off and tried to restarted it, it would not start. If I very slowly started with a garden hose, pm light spray to slowly cool the engine and not crack something, it would start.
THe problem was a compression issue. Lack of Compression. Yours , Yes maybe starter, but can be mechanical??? _________________ email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13270 Location: Tejas!
Posted: Tue Nov 05, 2019 6:22 am Post subject: Re: 1914cc Built Engine Overheating? Will run Cold not hot Questions |
Changed the starter and bearing this morning and it's running SO much better. Thank you so much! |
Posted: Tue Nov 05, 2019 11:13 am Post subject: Re: 1914cc Built Engine Overheating? Will run Cold not hot Questions |
My money is on the starter. |
Yay! I Win! _________________ Volkswagen!
Posted: Tue Nov 05, 2019 11:57 am Post subject: Re: 1914cc Built Engine Overheating? Will run Cold not hot Questions |
brad |
I was first past the post
brad |
