2000 GTI - Check Engine Light - code P0442 - small evap leak
Forum Index -> Water-cooled VW Share: Facebook Twitter
mtsipe
mtsipe is offline
PostPosted: Fri Nov 08, 2019 1:29 pm    Post subject: 2000 GTI - Check Engine Light - code P0442 - small evap leak Reply with quote
I have a 2000 GTI VR6. My check engine light came on and code P0442 small evap leak came up. I pulled the purge valve off near Power steering fluid reservoir and as per my mechanicís advice that with the engine off, I should not be able to blow through it. I could not blow through, so I know my purge valve is closed and works. I smoked it at that point and couldnít see any leaks.
Next, with the rear right fender wheelwell off with access to the charcoal canister, I smoked it at the fuel tank. With it completely sealed at the fuel cap opening, no smoke was escaping. I tightened the gas cap and light was still on after days of driving.
Next I replaced the gas tank cap. If the cap is the problem, How long should I have to drive for the light to go off?
Any advice would be greatly appreciated. Thanks
pondoras box
pondoras box is offline
PostPosted: Fri Nov 08, 2019 2:02 pm    Post subject: Re: 2000 GTI - Check Engine Light - code P0442 - small evap leak Reply with quote
I had the same problem with a Honda so take into advisement, but your car has to go through three testing cycles without the code being present to turn the light off.
This took about a week of around town driving, to and from work about 15 miles each way.
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Fri Nov 08, 2019 2:46 pm    Post subject: Re: 2000 GTI - Check Engine Light - code P0442 - small evap leak Reply with quote
The light will not go off on it's own, it has to be reset.
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
