Sometimes knocking sound when braking.
Ovally
Ovally is offline
PostPosted: Thu Nov 07, 2019 2:51 am    Post subject: Sometimes knocking sound when braking. Reply with quote
Early Oval, same hydraulic brakes as a Zwitter.
Sometimes there is a slight knocking noise when braking.
The sound comes from the right rear brake.
I removed the drum and everything looks good.
The drums are checked for ovality.
The entire braking system was renewed not long ago.
I think I have this problem.
Someone who is familiar with these types of washers / spacers?
They look square.
A picture with dimensions would be welcome.
VW part number is 11 609 161
Thanks and regards.
VW Bug Oval 1953
VW Bug 1200 D motor
Porsche 911S 1970
Mazda 929 Hardtop 1977
Mercedes SLC 180 Roadster 2018
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Thu Nov 07, 2019 9:14 am    Post subject: Re: Sometimes knocking sound when braking. Reply with quote
I found that loose shoes can knock or slap the drum on the trailing edges, after a brake job when the drums are new or turned. I believe it to be the cause of the additional friction between the new shoes and fresh surface area in the drums. They are seating. The additional friction “grabs” onto the leading edge and causes the trailing edge to “slap” the drum.
So, are the shoes adjusted correctly? To a light drag. I typically adjust out till the wheel locks up then back off three clicks. Go pump the brake pedal, 3 or 4 times. That recenters the shoes. Then go readjust for slight drag on each shoe.
Should take care of your noise, if it is what I believe it to be. This same noise can be made to disappear when you slam on the brakes. During that hard braking. The shoe never is allowed to relax, it is continually being forced into the drum with very high pressure.
Hope that’s it!
Jimbo
ASE Master Technician
Ricksurfin wrote:
First world fast guy problems. Sheesh. Lol
67rustavenger wrote:
Ovally
Ovally is offline
PostPosted: Fri Nov 08, 2019 12:49 am    Post subject: Re: Sometimes knocking sound when braking. Reply with quote
Thanks, that's what I do but never readjusted the shoes for slight drag.
I always readjusted the shoes until they just do not touch the drums.
Had no problems before but will try that.
I will also check the backing plate where the shoes rides.
If it is grooved or worn out too much, it's possible that the shoes are getting hung up.
Always use some copper grease there but who knows after 66 years.
Regards.
VW Bug Oval 1953
VW Bug 1200 D motor
Porsche 911S 1970
0nebadbug
0nebadbug is offline
PostPosted: Fri Nov 08, 2019 7:31 am    Post subject: Re: Sometimes knocking sound when braking. Reply with quote
Not sure if when you say "knock" if it might be chatter...
We had this just after rebuilding everything (in the rear). We also thought a few clicks back from locked up to not touching the drum & also got an errant chatter. After a few days of head scratching trying to figure it out we came up with the same fix as outlined by Jimbo above. Soon as we had some light friction, it immediately went away... And then after 100 miles of driving, readjusted & it's been smooth sailing ever since...
Now, if you were saying "knocking" and were hearing it upon acceleration as well them maybe you might check the axle splines or the drum spline axle holes for wear then, possibly.
::: Slowoval ::: LaDawri Sebring ::: '61 Creampuff ::: Dust Storm '66 :::
Ovally
Ovally is offline
PostPosted: Fri Nov 08, 2019 9:47 am    Post subject: Re: Sometimes knocking sound when braking. Reply with quote
Thanks, no knocking upon acceleration.
There is no wear in the axle / drum splines or fulcrum plates.
I only hear it sometimes (not always) during soft/gentle braking on the right rear side.
I will also look at the right rear parking brake mechanism.
Regards.
VW Bug Oval 1953
VW Bug 1200 D motor
Porsche 911S 1970
VW_Jimbo is offline
PostPosted: Fri Nov 08, 2019 12:25 pm    Post subject: Re: Sometimes knocking sound when braking. Reply with quote
[quote="Ovally"]
Regards.
The cable should be preloaded. Thus keeping the mechanism in check, IF installed correctly.
However, I have seen where the lock plate on the lever stud breaks off due to over crimping. Also have seen the cross bar installed back asswards. Also, check shoe to adjusters and at wheel cylinder interaction. Have seen both installed incorrectly and also worn out enough to have a large amount of side play, that will make noise or lock up.
Jimbo
Ovally
Ovally is offline
PostPosted: Sat Nov 09, 2019 7:37 am    Post subject: Re: Sometimes knocking sound when braking. Reply with quote
I will check the rear brakes and the entire handbrake mechanism again.
Strange, just driven the car and everything now seems normal during gentle braking.
Intermittent errors are sometimes difficult to find.
Regards.
VW Bug Oval 1953
VW Bug 1200 D motor
Porsche 911S 1970
VW_Jimbo is offline
PostPosted: Sat Nov 09, 2019 11:33 am    Post subject: Re: Sometimes knocking sound when braking. Reply with quote
Regards.
They are referred to as “Drivability Complaint(s)”. They are some of the worst problems to find and locate. It is what I specialized in as a mechanic. I worked primarily on fuel and spark management system issues, but was often handed other out of the normal, issues.
I did not find them all. I had about a 88% record for finding them. I thought it was fun!
Part of a brake system check is slamming on the brakes a few times. Maybe the issue is in the higher heat range, as well. Worth going for a drive to determine.
Jimbo
Mr. OGPaint
Mr. OGPaint is offline
PostPosted: Sun Nov 10, 2019 10:29 am    Post subject: Re: Sometimes knocking sound when braking. Reply with quote
Do you have original rear wheels /lugnuts? Is the axlenit tight/torqued to spec and are the drum splines in good condition and not “undercut”?
https://instagram.com/mr_ogpaint
Patrick Hall
Ovally
Ovally is offline
PostPosted: Sun Nov 10, 2019 11:56 am    Post subject: Re: Sometimes knocking sound when braking. Reply with quote
Yes, original wheels/nuts, axle nut tight and torqued to 300 Nm, no wear or play in axle and drum splines, drums not undercut.
Regards.
VW Bug Oval 1953
VW Bug 1200 D motor
Porsche 911S 1970
Ovally
Ovally is offline
PostPosted: Wed Nov 13, 2019 9:45 am    Post subject: Re: Sometimes knocking sound when braking. Reply with quote
I have re-checked and adjusted both rear brakes and the handbrake mechanism.
I noticed that the right handbrake cable sometimes did not come all the way back.May have been the cause.
To exclude other things, I replaced the brake shoe levers(12), the brake shoe push bars(13) and the upper and lower return springs(9,10) on both sides with VW NOS parts that I had collected as spare parts.
Drove the car a few times, braked gently and so far everything seems to be fine.
Regards.
VW Bug Oval 1953
VW Bug 1200 D motor
Porsche 911S 1970
VW_Jimbo is offline
PostPosted: Thu Nov 14, 2019 6:04 pm    Post subject: Re: Sometimes knocking sound when braking. Reply with quote
Sounds like you got it!
Jimbo
Ovally
Ovally is offline
PostPosted: Fri Nov 15, 2019 7:26 am    Post subject: Re: Sometimes knocking sound when braking. Reply with quote
Thanks, I think so and hope so.
During the brake job, I saw that the left torsion bar cover started to rust again.
The inner and outer bushings have been replaced with WW ones.
At that time, there were no reproduction covers available.
Now I see that Mika makes them : https://www.thesamba.com/vw/classifieds/detail.php?id=1368858
What do you think it's the best way to replace the left cover?
Car with wheels on the ground or jacked up till the spring plate is at the stop?
In both situations there is enough room to do this.
I would think with the wheels on the ground?
Regards.
VW Bug Oval 1953
VW Bug 1200 D motor
Porsche 911S 1970
VW_Jimbo is offline
PostPosted: Fri Nov 15, 2019 9:38 am    Post subject: Re: Sometimes knocking sound when braking. Reply with quote
I would disagree with installing fully with the car on the ground. I would speculate that the original car was assembled on a production line and those seals were installed before there was a load on the suspension. I have always installed them while the vehicle was in the air. Never have had an issue.
I use a light smearing of silicon grease on the inner and outer surfaces to allow the bushing to slip in rather than drag into place. When fully seated. I bounce the car, using the rear bumper before final tightening. Drive it around a few hundred loosen the bolts back up a few turns and retighten them.
Jimbo
Ovally
Ovally is offline
PostPosted: Fri Nov 15, 2019 10:20 am    Post subject: Re: Sometimes knocking sound when braking. Reply with quote
OK thanks, will do it that way.
Regards.
VW Bug Oval 1953
VW Bug 1200 D motor
Porsche 911S 1970
