Fuel pump flange has broken off in engine
Orangitang
Orangitang is offline
PostPosted: Sat Nov 09, 2019 8:45 am    Post subject: Fuel pump flange has broken off in engine Reply with quote
71 Super
The Fuel pump flange has broken off in engine.
Any suggestions on how to get that broken bit out of there? I would like to upload a photo but not sure how to do that. Iím sure you can picture the situation. I get the impression itís fairly common.
Thank yíall.
ashman40
ashman40 is offline
PostPosted: Sat Nov 09, 2019 8:53 am    Post subject: Re: Fuel pump flange has broken off in engine Reply with quote
Found this video on YouTube. Very good tutorial. Lots of good info on this channel for us ACVW lovers.
AshMan40
'67 Beetle {project car that never made it to the road Sad }
Orangitang
PostPosted: Sat Nov 09, 2019 9:15 am    Post subject: Re: Fuel pump flange has broken off in engine Reply with quote
Thank you ashman40.
That is precisely what I imagined the solution would be. I think I just needed a bit of a confidence builder. Thank you so much for that! It was also nice to be reminded that the piece is soft and not necessarily detrimental to the engine.
Cusser
Cusser is offline
PostPosted: Sat Nov 09, 2019 9:27 am    Post subject: Re: Fuel pump flange has broken off in engine Reply with quote
This has happened to many of us....
1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2005 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297
Orangitang
PostPosted: Sat Nov 09, 2019 12:20 pm    Post subject: Re: Fuel pump flange has broken off in engine Reply with quote
So how bad is it if a piece of the fuel pump flange about a half inch long has dropped into the motor?
Can still see it but I canít manage to get it out.
slalombuggy
slalombuggy is offline
PostPosted: Sat Nov 09, 2019 1:20 pm    Post subject: Re: Fuel pump flange has broken off in engine Reply with quote
As long as it doesn't go into the cam gears it will be ok. If it does.......
Cusser
Cusser is offline
PostPosted: Sat Nov 09, 2019 2:11 pm    Post subject: Re: Fuel pump flange has broken off in engine Reply with quote
This will generally not cause any issues; if it gets caught in something will generally grind up and get caught on the oil screen.
Starbucket
Starbucket is offline
PostPosted: Sat Nov 09, 2019 3:08 pm    Post subject: Re: Fuel pump flange has broken off in engine Reply with quote
Put some wheel bearing grease on the end of a piece of wire or something and touch it to the broken piece and it should stick so you can pull it out.
Orangitang
PostPosted: Sat Nov 09, 2019 4:35 pm    Post subject: Re: Fuel pump flange has broken off in engine Reply with quote
Thank y'all.
It is currently out of site. I have turned the motor over by hand and I feel no unusual binding. Just compression.
I may go through the oil pump to see if I can locate it. But first i have to figure out how the tin under the pulley is removed. SMH.
I am trying to take some comfort in the idea that the bake-light piece will just crumble against the steel gears and settle in the oil sump.
Trying.
Still worried.....
wheel607
wheel607 is offline
PostPosted: Sat Nov 09, 2019 6:10 pm    Post subject: Re: Fuel pump flange has broken off in engine Reply with quote
Orangitang wrote:
Thank y'all.
Trying.
Still worried.....
Make sure you put the flange back together when you think you have it all out. You may think it is only in two pieces.....but for your own sanity, put the pieces end to end and check. Even look for the little flecks.
heimlich Premium Member
heimlich is offline
PostPosted: Yesterday 4:09 pm    Post subject: Re: Fuel pump flange has broken off in engine Reply with quote
This happened to me a few times. I pushed it into the engine and let the engine grind it. Then I changed the oil.
www.vwnos.com
New NOS OEM Parts. Classic Brands. Classic Quality
Restored Distributors https://www.vwnos.com/search?q=restored
slalombuggy
PostPosted: Yesterday 10:12 pm    Post subject: Re: Fuel pump flange has broken off in engine Reply with quote
You're lucky, mine busted the cam the one time it happened to me
brad
Parts for sale: https://www.thesamba.com/vw/classifieds/search.php?username=slalombuggy
Lucky Monkey Landspeed Racing
1962 Canadian Buggy 121.253mph - Bonneville 2012
1957 Beetle 118.642mph - Bonneville 2014
1957 LSR Buggy 130.583mph - Bonneville 2018
Orangitang
PostPosted: Today 4:22 am    Post subject: Re: Fuel pump flange has broken off in engine Reply with quote
Every time i read that i have nothing to worry about someone tells me that it destroyed their Cam.
Honestly, It is hard for me to imagine how a piece of plastic could cause any damage to steel gears.
Other than logging some porthole somewhere.
I have been turning the engine over by hand and I don't feel any unusual binding. I'm trying to get up the nerve to cramk it a few times without spark just to assist in grinding it up before full on running the engine.
Starbucket
PostPosted: Today 7:49 am    Post subject: Re: Fuel pump flange has broken off in engine Reply with quote
If it fell into the engine just remove the sump plate (after oil drain) and feel around with your finger along the bottom and you will probably find it. I wouldn't grind it as the cam and distributor drive gears are the only things in there that can grind it.
slalombuggy
PostPosted: Today 7:56 am    Post subject: Re: Fuel pump flange has broken off in engine Reply with quote
It's not the gears that are the problem. It's the relatively fragile camshaft that was never meant to take a load like something going between the teeth of the gears, it doesnt flex at all. By all means leave it in there. I'm just relating my misfortune. I was lucky in that it happened while I was idling into the driveway so nothing else got hurt, the engine just quit
brad
FreeBug
FreeBug is offline
PostPosted: Today 3:05 pm    Post subject: Re: Fuel pump flange has broken off in engine Reply with quote
brad
That makes sense to me. Yes, the plastic is not strong, but it doesn't just liquefy when crushed, like some other plastics might. I see how that could exert a force. And cam blanks are brittle.
