rokemester Samba Member
Posted: Sun Nov 10, 2019 9:26 am Post subject: 1962 Antenna wire routing |
Can anyone advise on the proper routing for antenna wire to the interior of the car from the right passenger side. I failed to document where the wire came in from!! Thanks. |
Slip356 Samba Member
Posted: Sun Nov 10, 2019 1:11 pm Post subject: Re: 1962 Antenna wire routing |
My stock 62 B Cab has the antenna on the drivers side, sorry can’t help.
Did coupes have it on the pass side? |
Posted: Sun Nov 10, 2019 2:14 pm Post subject: Re: 1962 Antenna wire routing |
Where does the wire come in from the drivers side. |
Posted: Mon Nov 11, 2019 5:59 am Post subject: Re: 1962 Antenna wire routing |
I’ll be at the car later today and take a pic for you. |
Posted: Mon Nov 11, 2019 6:41 am Post subject: Re: 1962 Antenna wire routing |
Awesome! Thanks so much! |
Jacks Samba Member
Joined: July 15, 2006 Posts: 2347 Location: San Clemente, Ca.
Posted: Mon Nov 11, 2019 8:43 am Post subject: Re: 1962 Antenna wire routing |
The hole for the coax cable is about 2” forward of the smaller hole for the dome light door switch wire. _________________ Jack Staggs
Actual name |
Posted: Mon Nov 11, 2019 9:05 am Post subject: Re: 1962 Antenna wire routing |
Great, I’ll check it out when I’m near the car next. Snow will be flying this week in NEO. This radio antenna is mounted on the right side of the car. It is my understanding that it was dealer/owner preference as to location. |
Posted: Mon Nov 11, 2019 3:00 pm Post subject: Re: 1962 Antenna wire routing |
Took the pics today, now trying to upload to this topic. Stay tuned, may not be able until tomorrow |
Posted: Mon Nov 11, 2019 3:31 pm Post subject: Re: 1962 Antenna wire routing |
Thanks! |
Posted: Mon Nov 11, 2019 6:06 pm Post subject: Re: 1962 Antenna wire routing |
Here are the photos. Hope these help. Let me know if you need more specific info |
Posted: Mon Nov 11, 2019 6:11 pm Post subject: Re: 1962 Antenna wire routing |
As I think the pics show the antenna wire goes from the bottom of the spring loaded antenna, through the body (assume a grommet), under the carpet up to under the dash to the radio. |
Posted: Mon Nov 11, 2019 6:13 pm Post subject: Re: 1962 Antenna wire routing |
Ohhhh! If I’m interpreting your pics correctly the coax is going into the frunk then into the cabin. Is that right? |
The black wire next to the hood pull/lock in the third pic is the antenna wire. |
Jacks Samba Member
Posted: Mon Nov 11, 2019 7:22 pm Post subject: Re: 1962 Antenna wire routing |
rokemester wrote: |
No _________________ Jack Staggs
Actual name |
Posted: Mon Nov 11, 2019 9:06 pm Post subject: Re: 1962 Antenna wire routing |
Got it...I think. |
Posted: Tue Nov 12, 2019 7:56 am Post subject: Re: 1962 Antenna wire routing |
It helps to view the images on my computer! I'm still not seeing exactly where the coax enters the car. But these help immensely. |
