ozzmosis Samba Member
Joined: April 06, 2018 Posts: 14 Location: Santa Maria ca
Posted: Tue Nov 12, 2019 12:04 pm Post subject: Heater cable tube's blocked |
Need some wisdom I have been trying to put in my heater cables the right side is clear the driver side cable stops 2 ft before it can exit I have tried BP BLASTER then pushing hanger, went in the back got the thin wire to pop up in the front cab but when trying the cable though the cab it stops again same place. I heard you can uses a speedometer cable and drill but is it just the cable only.does anyone ever had this problem
Ozzmosis |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Tue Nov 12, 2019 12:10 pm Post subject: Re: Heater cable tube's blocked |
Are the swedged on ends of the cable longer than stock? Could be the curve of the tube is too tight, for a longer end.
Can you push the cable going up the rear end past that point? _________________ In Stereo, Where Available! |
Shoyrtt Samba Member
Joined: August 21, 2010 Posts: 1009 Location: Redlands, CA
Posted: Tue Nov 12, 2019 12:19 pm Post subject: Re: Heater cable tube's blocked |
ozzmosis wrote: |
Ozzmosis |
b-man just posted a nice write up on his Velvet Green Single Cab thread (see page 2 on 10-25-19). Soak the tube with gas for a week and use compressed air and an old cable/drill to clean it out.
Here is a link: https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=20 |
Old Paint Samba Member
Joined: May 29, 2010 Posts: 436 Location: Battle Ground, Washington
Posted: Tue Nov 12, 2019 5:38 pm Post subject: Re: Heater cable tube's blocked |
I just put a new accelerator cable in my Single Cab that had been sitting for 20 years. I had to grind out that section of the tube. Bottom line, the swedge was too long to fit where there was a slight bend. Try grinding the swedge. Worse case you have to buy a new cable. OR grind out the tube and realize the swedge was too long after the fact. _________________ Greg
1961 Ragtop
1961 Single Cab (Old Paint) |
Posted: Tue Nov 12, 2019 8:13 pm Post subject: Re: Heater cable tube's blocked |
That is why we asked about the swedge length. Had an Parking brake cable with same problem and found that by bending the swedge end a tad it slide right thru. _________________ In Stereo, Where Available! |
Dustin B Samba Member
Joined: March 29, 2007 Posts: 1017 Location: hesperia, Ca USA
Posted: Tue Nov 12, 2019 8:59 pm Post subject: Re: Heater cable tube's blocked |
Mine was clogged as well. I am an electrician and I has a metal fish tape handy. I started by cutting the end off and putting it in as far as it would go from the clogged side then cutting it off 4" to 6" longer then installing the cut off piece into a cordless drill and slowly working it in and out until the drill bottomed out against the bus then repeating the process until the clog was removed from the tube. It took me and hour or two from start to finish.
This is the style of fishtape I used. You can get them at Lowe's, Home Depot or any electrical supply house in various lengths. I'm suggest a hundred footer to insure you have enough to make as many cuts you need.
https://www.amazon.com/240-Foot-Measuring-Klein-To...6273828218 _________________ Wanted Victoria motors licence plate frame.
62 og paint L469 type 1
61 og paint L31 DD panel type 2
64 heilite viscount tent trailer
71 sears clamshell trailer
I <3 Brazilian busses
Original paint and patina extravaganza http://www.thesamba.com/vw/forum/viewtopic.php?t=187156 |
EverettB Administrator
Joined: April 11, 2000 Posts: 69824 Location: Phoenix Metro
Posted: Tue Nov 12, 2019 9:40 pm Post subject: Re: Heater cable tube's blocked |
Copying this from another post I made...
This is my Double Cab.
One of my tubes was plugged with rock hard dirt and grease, I cleared it out with an old clutch cable in my drill:
It was plugged about 1 foot from the back end
I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there from the rear.
Going from the front did it after a LONG time of going at it
If you do this run the drill in reverse so the cable does not unwind. _________________ How to Post Photos
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Wed Nov 13, 2019 5:59 am Post subject: Re: Heater cable tube's blocked |
Quote: |
If you do this run the drill in reverse so the cable does not unwind. |
THAT is VERY important!!!! Don't ask me how I know.... _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Sun Nov 24, 2019 8:43 pm Post subject: Re: Heater cable tube's blocked |
After some of these awesome wisdom ideas on what might be the issues I tried a few of the suggestion. I notice just where it was being stopped there was a welding spot broken of the frame causing the tube to have a little bend that is what stopped the cable tip from passing. straighten out the tube. I was Doing the happy dance. I made sure the knob was all the way turned and tightened but it's short on both sides should the cable come from a different model OEM # 211.711.629B
1964 TYPE 2 full bench seat
Ozzmosis |
sgellis Samba Member
Joined: July 06, 2016 Posts: 2014 Location: SW Nova Scotia, Canada
Posted: Tue Nov 26, 2019 4:02 pm Post subject: Re: Heater cable tube's blocked |
Thanks you Mr. B
You were right I did have a twist (I corrected). inserted cable back made sure it stayed straight after tightening the knob both sides still short by 1/2 inch I’ll have to purchase some ( CABLE EXTENDER )
Thanks to all Dubs
